| » Washer makes ratcheting sound |
Model Number: LSQ8243HQ Brand: Whirlpool Age: More than 10 years
My whirlpool washer makes a loud ratcheting sound when agitating. I have changed the 4 dogs inside the agitator, but it still makes the sound sometimes. The strange thing is I can stop the sound by grabbing the agitator and pulling up on it. It will be quiet for a while or for the rest of that cycle. But the sound will still come back, so I pull up on the agitator again. What else do I need to change?
The splines up inside the bottom of the agitator may be stripping out. They mate with the splines of the gearcase agitator shaft. Grab the bottom fins of the agitator and see if you can rotate to see if it is slipping.
Eric |
I checked further, when it makes the ratcheting sound it is mechanical. I watched inside the agitator, the dogs are engaging. When the noise starts the steel agitator shaft rotates counter clockwise. It does not alternate rotation direction. And when in spin mode it seems to unbalance easily, based on the sounds it makes, but the basket does not rotate out of center more than 3/4". Admittedly I may not have reassembled correctly and that could cause the out of balance problem.
Any ides. |
Hi.
Most likely it's a bad transmission Part number: 3360629 Here are the breakdown diagrams and Brake / Clutch / Gearcase / Motor / Pump parts for Whirlpool LSQ8243HQ0 - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Washer makes buzzing sound | divamsann | Washer Repair | 2 | 04-01-2012 08:14 PM |
| Washer With Ratcheting Sound Wont Spin Or Drain | DANI1 | Washer Repair | 3 | 03-27-2012 11:11 AM |
| Washer makes buzzing sound | eaglemtn | Washer Repair | 1 | 02-16-2011 06:43 AM |
| Washer motor won't run and makes no sound | rcraighead | Washer Repair | 1 | 12-18-2010 05:06 PM |
| GE washer makes clicking sound | Kyle | Washer Repair | 5 | 01-13-2008 01:41 AM |
