Discuss
maytag washer fills then stops
 in
Washer Repair
Washer fills with water then stops. If you lower the water level and turn it back on, it fills back
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag washer fills then stops
  #1 (permalink)
Old 09-27-2009, 12:05 PM
Junior Member
Terryens is on a distinguished road
Default maytag washer fills then stops
Model Number: LSE7806ACQ   Brand: Maytag   Age: More than 10 years
Washer fills with water then stops. If you lower the water level and turn it back on, it fills back to the correct level then stops. If you open the lid, the washer stops filling, when the lid is closed it continues to fill again. It doesnt mater which setting the washer is on, it does the same thing. I've checked other posts, it seems that the possibilities are the lid swich or the timer. I cant hear the timer running. Any help is much appreciated.
Ads By Google
Related Models
Maytag LSE7806ACQ Stacked Laundry - Ele
Maytag LSE7806ADE Stacked Laundry - Ele
Maytag LSE7806ADM Stacked Laundry - Ele
Maytag LSE7806ADQ Stacked Laundry - Ele
Maytag LSE7806AEE Stacked Laundry - Ele
Maytag LSE7806BCE Stacked Laundry - Ele
International LSE7806GGE Stacked Laundry - Ele
Whirlpool LSE9355BQ0
Whirlpool LSE9355BZ0
Maytag LSE9900 Stacked Laundry - Ele
Maytag LSE9900ACE Stacked Laundry - Ele
Maytag LSE9900ACL Stacked Laundry - Ele
Maytag LSE9900ACW Stacked Laundry - Ele
Maytag LSE9900ADE Stacked Laundry - Ele
Maytag LSE9900ADL Stacked Laundry - Ele
Maytag LSE9900ADW Stacked Laundry - Ele
Maytag LSE9900AEE Stacked Laundry - Ele
Maytag LSE9900AEL Stacked Laundry - Ele
Maytag LSE9900AEW Stacked Laundry - Ele
Maytag LSE9900AFE Stacked Laundry - Ele
Maytag LSE9900AFL Stacked Laundry - Ele
Maytag LSE9900AFW Stacked Laundry - Ele
Maytag LSE9904ACE Stacked Laundry - Ele
Maytag LSE9904ACL Stacked Laundry - Ele
Maytag LSE9904ACM Stacked Laundry - Ele
Maytag LSE9904ADE Stacked Laundry - Ele
Maytag LSE9904ADL Stacked Laundry - Ele
Maytag LSG1000 Stacked Laundry - Gas
Maytag LSG1000T Stacked Laundry - Gas
Jenn-Air LSG2700W Stacked Laundry - Gas
Jenn-Air LSG2704W Stacked Laundry - Gas
Maytag LSG7800 Stacked Laundry - Gas
Maytag LSG7800AAE Stacked Laundry - Gas
Maytag LSG7800AAL Stacked Laundry - Gas
Maytag LSG7800AAW Stacked Laundry - Gas
Maytag LSG7800ABE Stacked Laundry - Gas
Maytag LSG7800ABL Stacked Laundry - Gas
Maytag LSG7800ABW Stacked Laundry - Gas
Maytag LSG7804AAE Stacked Laundry - Gas
Maytag LSG7804AAL Stacked Laundry - Gas
Maytag LSG7804AAM Stacked Laundry - Gas
Maytag LSG7804ABE Stacked Laundry - Gas
Maytag LSG7804ABL Stacked Laundry - Gas
Maytag LSG7804ABM Stacked Laundry - Gas
Maytag LSG7806AAE Stacked Laundry - Gas
Maytag LSG7806AAM Stacked Laundry - Gas
Maytag LSG7806AAQ Stacked Laundry - Gas
Maytag LSG7806ABE Stacked Laundry - Gas
Maytag LSG7806ABM Stacked Laundry - Gas
Maytag LSG7806ABQ Stacked Laundry - Gas
Maytag LSG9900 Stacked Laundry - Gas
Maytag LSG9900AAE Stacked Laundry - Gas
Maytag LSG9900AAL Stacked Laundry - Gas
Maytag LSG9900AAW Stacked Laundry - Gas
Maytag LSG9900ABE Stacked Laundry - Gas
Maytag LSG9900ABL Stacked Laundry - Gas
Maytag LSG9900ABW Stacked Laundry - Gas
Maytag LSG9904AAE Stacked Laundry - Gas
Maytag LSG9904AAL Stacked Laundry - Gas
Maytag LSG9904AAM Stacked Laundry - Gas
Whirlpool LSH9264HQ0
Whirlpool LSL9244EQ0
Whirlpool LSL9244EZ0
Whirlpool LSL9345EQ0
Whirlpool LSL9345EQ1
Whirlpool LSL9345EZ0
Whirlpool LSL9345EZ1
Whirlpool LSL9355DQ0
Whirlpool LSL9355EQ0
Whirlpool LSL9355EQ1
Whirlpool LSN1000HQ0
Whirlpool LSN1000HZ0
Whirlpool LSN1000JQ0
Whirlpool LSN1000JQ1
Whirlpool LSN1000JT0
Whirlpool LSN1000JT1
Whirlpool LSN1000KQ0
Whirlpool LSN1000KT0
Whirlpool LSN1000LG0
Whirlpool LSN1000LG1 Automatic Washer
Whirlpool LSN1000LG2 Automatic Washer
Whirlpool LSN1000LG3 Automatic Washer
Whirlpool LSN1000LW0
Whirlpool LSN1000LW1 Automatic Washer
Whirlpool LSN1000LW2 Automatic Washer
Whirlpool LSN1000LW3 Automatic Washer
Whirlpool LSN1000PQ0 Automatic Washer
Whirlpool LSN1000PQ1 Automatic Washer
Whirlpool LSN1000PQ2 Automatic Washer
Whirlpool LSN1000PQ3 Automatic Washer
Whirlpool LSN2000JQ0
Whirlpool LSN2000JQ1
Whirlpool LSN2000JQ2
Whirlpool LSN2000JT0
Whirlpool LSN2000JT1
Whirlpool LSN2000JT2
Whirlpool LSN2000LG0
Whirlpool LSN2000LG1 Automatic Washer
Whirlpool LSN2000LW0
Whirlpool LSN2000LW1 Automatic Washer
Whirlpool LSN2000PG0 Automatic Washer
Whirlpool LSN2000PG1 Automatic Washer
Whirlpool LSN2000PG2 Automatic Washer
Whirlpool LSN2000PG3 Automatic Washer
Whirlpool LSN2000PG4 Automatic Washer
Whirlpool LSN2000PW0 Automatic Washer
Whirlpool LSN2000PW1 Automatic Washer
Whirlpool LSN2000PW2 Automatic Washer
Whirlpool LSN2000PW3 Automatic Washer
Whirlpool LSN2000PW4 Automatic Washer
Whirlpool LSN3000PG0 Automatic Washer
Whirlpool LSN3000PG1 Automatic Washer
Whirlpool LSN3000PG2 Automatic Washer
Whirlpool LSN3000PG3 Automatic Washer
Whirlpool LSN3000PG4 Automatic Washer
Whirlpool LSN3000PW0 Automatic Washer
Whirlpool LSN3000PW1 Automatic Washer
Whirlpool LSN3000PW2 Automatic Washer
Whirlpool LSN3000PW3 Automatic Washer
Whirlpool LSN3000PW4 Automatic Washer
  #2 (permalink)
Old 09-27-2009, 02:54 PM
Junior Member
Default addition to problem
Ok, I took the lid switch out and it checked out ok. However the small white micro switch that's in the same area as the lid switch was bad. If i tap on the white micro switch I can get continuity thru it, unfortunately now the washer will not fill but it will spin. Also, the timer turns but only in the spin cycle, it does not turn if you set it anywhere in the wash cycle. If the bad micro switch has anything to do with that it would be great but im not sure how to test it.
Please advise, Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag 300 starts, fills, stops kctay Dishwasher Repair 5 04-27-2012 02:39 PM
Maytag MAV-1 fills for a few seconds and stops DIY girl Washer Repair 4 09-11-2011 08:19 PM
Washer Fills, Then Stops yogivic54 Washer Repair 5 04-11-2011 06:57 PM
Maytag washer fills then stops kate59 Washer Repair 1 10-04-2009 12:35 PM
Maytag Washer fills then stops Tazman Washer Repair 4 01-23-2008 12:44 PM
