| » washer is not draining |
Model Number: 110. 22922 101 Brand: Kenmore Age: 5 - 10 years
Recently my washer had spinning issues but after I replaced the lid switch the machine started spinning again but then a few weeks later it stopped again. I opened the machine and looked into the couplers, even if they were not broken or damaged, I decided to replace them with new ones.
Now after replacing the lid switch and the couplers, the washer doesn't drain and does not spin either but it does agitate. I am looking for some help. Thanks a million Haas Ads By Google Related Models |
Hi.
Disengage the motor from the transmission and the pump, lay it down, bypass the lid switch and see if it will work without the load. Does it make any noise? Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Please do so.
Simon.
__________________
@Simon, no it doesn't make any noise
@Fairbank56, Yes tried different speed modes and no change. Basically the wash cycle fills and agitates just fine but when it gets to the spin cycle, it completely shuts down as if there is no electric connection. There is absolutely no response from the machine in the spin cycle, this is in addition to the no drain issue. Hope that helps Thanks Haas |
Have you bypassed the lid switch?
Simon.
__________________
Simon, I believe I did but I can try again. Right now I am out of town for work assignment and won't able to do it soon. I may have to just hire someone to fix the washer for me but I will try again and see what happened.
Thanks for your time and help. Last edited by haas : 12-06-2012 at 02:08 PM. Reason: typos |
You are welcome and good luck.
Simon.
__________________
| Display Modes | |
| the washer isn't draining | Richard211 | Washer Repair | 1 | 03-25-2011 06:28 PM |
| washer not draining | chriskar | Washer Repair | 1 | 03-17-2011 07:13 PM |
| Washer not draining | bertschj | Washer Repair | 4 | 08-19-2010 01:29 PM |
| Washer not draining | MTMiller | Washer Repair | 1 | 02-10-2009 03:42 AM |
| Washer is not draining | MMBell | Washer Repair | 2 | 02-25-2008 10:56 AM |
