Discuss
Help - need soution - w/d stack removal from tight fit alcove
 in
Washer Repair
We're in the middle of major remodel of a hall bath. An alcove (i.e. closet without a door) for a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Help - need soution - w/d stack removal from tight fit alcove
  #1 (permalink)
Old 12-02-2012, 09:49 AM
Junior Member
elphalba is on a distinguished road
Unhappy Help - need soution - w/d stack removal from tight fit alcove
Model Number: WF219ANW   Brand: Samsung   Age: 1 - 5 years
We're in the middle of major remodel of a hall bath. An alcove (i.e. closet without a door) for a washer/dryer stack is part of the requirements. In the middle of that now when I realize because it is a tight fit, it is going to be a HUGE DEAL if and when we decide to replace machines or if they need maintenance to the extent they need to be pulled out of alcove. Doesn't help that these machines are fairly large Samsung, not compact.
Opinions?
I think I've got SOME help with this problem because I am requiring access panels in back (on wall in a spare room).
BUT the REAL problem is if these machines need to be removed. I could give space dimensions but I will not unless someone feels they need it. What I'm thinking is that casters might be the solution. Stack could be rolled out and then moved sideways down a 36 inch aisle out the door which is also 36 inches.
Problem is I can't find anywhere on the web where this has been done before. I'm particularly worried about vibration with the casters. Think I need REALLY heavy duty casters attached to some kind of platform? Do I need to worry about ventilation (on the sides as well as from below?)?
Also, some issues with stability if both are rolled out together? Anyone with experience on this? Maybe wall on the side of alcove which borders a hallway could be made to be easily "destroyed"? (Hopefully this last option isn't only one because that "ship may have already sailed".)
Washer is Samsung WF219ANW and
dryer stacked above washer is: Samsung DV2194GW
Ads By Google
Related Models
 WF306BHW WASHER- HORIZONTAL AXIS
 WF306BHW/XAA WASHER- HORIZONTAL AXIS
 WF306LAW WASHER- HORIZONTAL AXIS
 WF306LAW/XAA WASHER- HORIZONTAL AXIS
 WF316BAC WASHER- HORIZONTAL AXIS
 WF316BAC/XAA WASHER- HORIZONTAL AXIS
 WF316BAW WASHER- HORIZONTAL AXIS
 WF316BAW/XAA WASHER- HORIZONTAL AXIS
 WF316LAS WASHER- HORIZONTAL AXIS
 WF316LAS/XAA WASHER- HORIZONTAL AXIS
 WF316LAW WASHER- HORIZONTAL AXIS
 WF316LAW/XAA WASHER- HORIZONTAL AXIS
White Westinghouse WFC0510DW1 White Westinghouse/freezer
White Westinghouse WFC05K0DW0 White Westinghouse/freezer
Frigidaire WFC05M2AW0 Wwh(v1) / Chest Freezer
Frigidaire WFC07M2AW0 Wwh(v1) / Chest Freezer
White Westinghouse WFC07M2AW1 White Westinghouse/freezer
White Westinghouse WFC07M2AW2 White Westinghouse/freezer
White Westinghouse WFC07M2AW3 White Westinghouse/freezer
White Westinghouse WFC07M2AW4 White Westinghouse/freezer
White Westinghouse WFC07M2AW5 White Westinghouse/freezer
White Westinghouse WFC07M2AW6 White Westinghouse/freezer
White Westinghouse WFC07M2AW7 White Westinghouse/freezer
White Westinghouse WFC07M2AW8 White Westinghouse/freezer
White Westinghouse WFC07M2AW9 FREEZER
Frigidaire WFC07M3HW0 Whi(v0) / Freezer
White Westinghouse WFC07M3HW1 White Westinghouse/freezer
White Westinghouse WFC09K0DW0 White Westinghouse/freezer
Frigidaire WFC09M2AW0 Wwh(v1)
White Westinghouse WFC09M3BW0 White Westinghouse/freezer
White Westinghouse WFC09M3BW1 Whitewestinghouse/freezer
White Westinghouse WFC09M3BW2 White Westinghouse/freezer
White Westinghouse WFC09M3BW3 White Westinghouse/freezer
White Westinghouse WFC09M3BW4 FREEZER
White Westinghouse WFC09M3BW5 FREEZER
White Westinghouse WFC09M3BW6 FREEZER
Frigidaire WFC09M3HW0 Wwh(v0) / Freezer
White Westinghouse WFC09M3HW1 White Westinghouse/freezer
White Westinghouse WFC1310EW0 White Westinghouse/freezer
White Westinghouse WFC15K2BW0 White Westinghouse/freezer
White Westinghouse WFC15K2BW1 White Westinghouse/freezer
White Westinghouse WFC15K2BW2 White Westinghouse/freezer
White Westinghouse WFC15K2BW3 White Westinghouse/freezer
Frigidaire WFC15M3AW0 Wwh(v1) / Chest Freezer
Frigidaire WFC15M3AW1 Wwh(v1) / Chest Freezer
White Westinghouse WFC15M4BW0 White Westinghouse/freezer
White Westinghouse WFC15M4BW1 White Westinghouse/freezer
White Westinghouse WFC15M4BW2 White Westinghouse/freezer
White Westinghouse WFC15M4BW3 White Westinghouse/freezer
White Westinghouse WFC15M4BW4 FREEZER
White Westinghouse WFC15M4BW5 FREEZER
Frigidaire WFC15M4HW0 Whi(v0) / Refrigerator
White Westinghouse WFC15M4HW1 White Westinghouse/freezer
Frigidaire WFC18M4AW0 Wwh(v1) / Chest Freezer
White Westinghouse WFC20M3AW0 White Westinghouse/freezer
Frigidaire WFC20M4AW0 Wwh(v1) / Chest Freezer
Frigidaire WFC20M4AW1 Wwh(v1) / Chest Freezer
White Westinghouse WFC20M4BW0 White Westinghouse/freezer
White Westinghouse WFC20M4BW1 White Westinghouse/freezer
White Westinghouse WFC20M4BW2 White Westinghouse/freezer
White Westinghouse WFC20M4BW3 White Westinghouse/freezer
White Westinghouse WFC20M4BW4 White Westinghouse/freezer
White Westinghouse WFC20M4BW5 White Westinghouse/freezer
White Westinghouse WFC20M4BW6 FREEZER
Frigidaire WFC20M4HW0 Whi(v1) / Freezer
White Westinghouse WFC20M4HW1 White Westinghouse/freezer
White Westinghouse WFC25M3AW0 White Westinghouse/freezer
White Westinghouse WFC25M4BW0 White Westinghouse/freezer
White Westinghouse WFC25M4BW1 White Westinghouse/freezer
White Westinghouse WFC25M4BW2 White Westinghouse/freezer
White Westinghouse WFC25M4BW3 White Westinghouse/freezer
White Westinghouse WFC25M4BW4 White Westinghouse/freezer
White Westinghouse WFC25M4BW5 FREEZER
White Westinghouse WFC25M4BW6 FREEZER
White Westinghouse WFC25M4BW7 FREEZER
Frigidaire WFC25M4HW0 Whi(v2) / Freezer
White Westinghouse WFC25M4HW1 White Westinghouse/freezer
White Westinghouse WFC25M4HW2 White Westinghouse/freezer
Frigidaire WFC25M7AW0 Wwh(v1) / Chest Freezer
Frigidaire WFC25M7AW1 Wwh(v1) / Chest Freezer
Whirlpool WFC7500VW0 COMPACT AUTOMATIC WASHER
Whirlpool WFC7500VW1 WASHER
Whirlpool WFE114LWS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE115LXB0 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE115LXQ0 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE260LXS0 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE301LVB0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE301LVQ0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE301LVS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE321LWB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE321LWQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE321LWS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWB1 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE324LWQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWQ1 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE324LWS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWS1 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE361LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVB1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVD0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVD1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVQ1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVS1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVT1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE364LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVD0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE366LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE366LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE366LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE366LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Door does not close tight sgsiegel Refrigerator & Freezer Repair 1 09-24-2012 12:46 PM
door will not close tight btk4962 Oven Repair (including Ranges and Cooktops) 1 04-29-2012 01:57 AM
Door will not close tight rvorama Refrigerator & Freezer Repair 1 05-20-2010 04:47 AM
Maytag SE1000 stack dryer motor removal Lynn Finch Dryer Repair 0 12-23-2009 01:06 PM
cant figure how to get belt on tight kc.58 Dryer Repair 1 10-31-2007 03:46 AM
