Discuss
Frigidaire Affinity front loader problem
 in
Washer Repair
hello all- i have received code E38, air chamber is clogged, error and the washer does not work. i have
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire Affinity front loader problem
  #1 (permalink)
Old 12-01-2012, 07:00 PM
Junior Member
stumpy1216 is on a distinguished road
Default Frigidaire Affinity front loader problem
Model Number: #ATF8000FS1   Brand: Frigidaire   Age: 1 - 5 years
hello all-
i have received code E38, air chamber is clogged, error and the washer does not work. i have disassembled it and found out we had a rodent living in the bottom. clean and bleach, check for gnawed wires and fixed them, clean clean clean, re-assemble and i still get the error.
i checked the air chamber and cannot remove it. the pressure sensor appears to be fine as well. i have disconnected the pressure sensor, attempted to reset the machine, and have attempted to remove and clean the air chamber. thus far, no success.
suggestions? should i just order a new air chamber and pressure sensor?
thanks in advance!
-eric
Related Models
Hoover 021
Hoover 0510
Hoover 0513
Hoover 0515
Hoover 0517-10
Hoover 0517-20
Hoover 0517-30
Hoover 0519
Hoover 0519-10
Hoover 0519-30
Hoover 0519-60
Hoover 0519-70
Hoover 0519-80
Hoover 0610
Hoover 0611
Hoover 0612
Hoover 0613
Hoover 0617
Hoover 0617-61
Hoover 0617-64
Hoover 0620
Hoover 0622
Hoover 0630
Hoover 0632
Hoover 0710
Hoover 0750
Roper 0773B10 Range Hood
Roper 0783B10 Range Hood
Hoover 0810
Hoover 0811
Hoover 0914
Hoover 0914-61
Hoover 0914-64
Hoover 0916
Hoover 0916T
Hoover 0916T-01
Hoover 0920
Amana 10-2NM ROOM AIR CONDITIONER
Frigidaire 1005 DISHWASHER
Frigidaire 1006 DISHWASHER
Amana 1008.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1009.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 100A-20 ROOM AIR CONDITIONER
Amana 100A-2M ROOM AIR CONDITIONER
Amana 100A-2N ROOM AIR CONDITIONER
Amana 100A-30 ROOM AIR CONDITIONER
Amana 100A-30H ROOM AIR CONDITIONER
Amana 100A-356 ROOM AIR CONDITIONER
Amana 100A-3A ROOM AIR CONDITIONER
Amana 100A-3HN ROOM AIR CONDITIONER
Amana 100A-3M ROOM AIR CONDITIONER
Amana 100A-3N ROOM AIR CONDITIONER
Amana 100A-3P ROOM AIR CONDITIONER
Amana 100A-3PH ROOM AIR CONDITIONER
Amana 100A-3R ROOM AIR CONDITIONER
Amana 100A-3RH ROOM AIR CONDITIONER
Amana 100A-556 ROOM AIR CONDITIONER
Amana 100A-8R ROOM AIR CONDITIONER
Amana 100B-3A ROOM AIR CONDITIONER
Amana 100C-2N ROOM AIR CONDITIONER
Amana 100C-2N1 ROOM AIR CONDITIONER
Amana 100C-2P ROOM AIR CONDITIONER
Amana 100C-2PH ROOM AIR CONDITIONER
Amana 100C-2R ROOM AIR CONDITIONER
Amana 100C-2RH ROOM AIR CONDITIONER
Amana 100C-2RHL ROOM AIR CONDITIONER
Amana 100C-2RL ROOM AIR CONDITIONER
Amana 100C-3N ROOM AIR CONDITIONER
Amana 100C-3N1 ROOM AIR CONDITIONER
Amana 100C-3P ROOM AIR CONDITIONER
Amana 100C-3PH ROOM AIR CONDITIONER
Amana 100C-3R ROOM AIR CONDITIONER
Amana 100C-3RH ROOM AIR CONDITIONER
Amana 100C-3RHL ROOM AIR CONDITIONER
Amana 100C-3RL ROOM AIR CONDITIONER
Amana 100C-8P ROOM AIR CONDITIONER
Amana 100C-8R ROOM AIR CONDITIONER
Amana 100C-8RH ROOM AIR CONDITIONER
Amana 100C-8RHL ROOM AIR CONDITIONER
Amana 100C-8RL ROOM AIR CONDITIONER
Amana 100D-356 ROOM AIR CONDITIONER
Amana 100D-556 ROOM AIR CONDITIONER
Amana 100LA-20 ROOM AIR CONDITIONER
Amana 100LA-2N ROOM AIR CONDITIONER
Amana 100LC-2N ROOM AIR CONDITIONER
Amana 100LC-2P ROOM AIR CONDITIONER
Amana 100LC-2R ROOM AIR CONDITIONER
Amana 100LC-2RH ROOM AIR CONDITIONER
Amana 100LCS-2N ROOM AIR CONDITIONER
Amana 100LCS-2P ROOM AIR CONDITIONER
Hoover 1010
Amana 1010.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1011.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1015.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1018.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 102.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 102.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 102.002 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1020
Amana 1020.0 MWAVE - FAMILY SIZE (60 HZ)
Amana 1020.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1021.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1022
Amana 1022.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 1026 DISHWASHER
Hoover 1030
Frigidaire 1031-005A DISHWASHER
Hoover 1032
Frigidaire 1032-005A DISHWASHER
Craftsman 10322161 TABLE MITRE SAW
Craftsman 10322180 CRAFTSMAN BENCH SAW
Craftsman 10322181 CRAFTSMAN BENCH SAW
Craftsman 10322420 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10322450 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10322451 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10323150 CRAFTSMAN JIG SAW
Craftsman 10323151 JIG SAW 18 INCH
Craftsman 10323390 CRAFTSMAN JIG SAW
Craftsman 10323420 BENCH SAW
Craftsman 10323440 JIG SAW
  #2 (permalink)
Old 12-03-2012, 03:22 PM
Junior Member
Default
quick update - i bought a new pressure sensor and installed it just to see if that would solve it. installed, pulled plug, plugged back in, got error code 38 again.
ordered the air chamber just in case.
any suggestions?
  #3 (permalink)
Old 12-05-2012, 05:21 PM
Junior Member
Default
nothing? nobody?
air chamber and hose is on the way... hoping that will fix it. i guess the next step after is to put together the $300 to have a service man come out...
  #4 (permalink)
Old 12-08-2012, 02:20 PM
Junior Member
Default
quick update - i ended up replacing the air chamber and hose, put it all back together and then got an E43 error. ran through the entire diagnostic sequence, reset the washer, ran codes again and the code went away. washing laundry today, so i guess i musta done something right.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire front loader seminole Washer Repair 2 07-19-2010 06:20 AM
Frigidaire Front Loader Spin Problem wvscreamingeagle Washer Repair 1 04-12-2010 03:15 PM
Frigidaire Affinity Front Loader Leaking issues newangelslife Washer Repair 3 03-06-2010 09:11 AM
Frigidaire Front Loader Problem jmontgom Washer Repair 6 10-22-2009 05:45 PM
Frigidaire Front Loader won't run hguyette Washer Repair 3 06-29-2009 11:15 AM
