Discuss
Will not complete Spin cycle or finish draining.
 in
Washer Repair
Recently replaced motor coupling gear. Before this, the machine functioned perfectly. Now the washer works great until the spin cycle.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Will not complete Spin cycle or finish draining.
  #1 (permalink)
Old 11-30-2012, 03:35 PM
Junior Member
hctp91 is on a distinguished road
Default Will not complete Spin cycle or finish draining.
Model Number: LBR4132JQ1   Brand: Whirlpool   Age: 5 - 10 years
Now the washer works great until the spin cycle. It will spin for 30-45 seconds and then stops completely and will not drain.
Sometimes if I turn the control back to the beginning of the cycle it will start again, but always stops once it reaches spin cycle. Sometimes the machine dies completely and I have to let it sit for a few minutes before it will do anything again.
I figured since I just replaced that coupling maybe a connection was loose somewhere. I double checked all connections and they seem okay. The connection at the motor seems a little loose, but I pressed it on as tight as it would go.
What should I check next?
Ads By Google
Related Models
Whirlpool LBR4132JQ1
Whirlpool LBR4132JQ2 Automatic Washer
Whirlpool LBR4132PQ0 Automatic Washer
Whirlpool LBR4132PQ1 Automatic Washer
Whirlpool LBR4132PQ2 Automatic Washer
Whirlpool LBR4221EW0
Whirlpool LBR4221EW1
Whirlpool LBR4232DW0
Whirlpool LBR5132JQ1
Whirlpool LBR5133AG0
Whirlpool LBR5133AG1
Whirlpool LBR5133AN0
Whirlpool LBR5133AN1
Whirlpool LBR5133AW0
Whirlpool LBR5133AW1
Whirlpool LBR5232EQ0
Whirlpool LBR5232EQ1
Whirlpool LBR5232EQ2
Whirlpool LBR5232EZ0
Whirlpool LBR5232EZ1
Whirlpool LBR5232EZ2
Whirlpool LBR5432JQ0
Whirlpool LBR5432JQ1
Whirlpool LBR5432JT0
Whirlpool LBR5432JT1
Whirlpool LBR5432LQ0
Whirlpool LBR5432LQ1 Automatic Washer
Whirlpool LBR5432PQ0 Automatic Washer
Whirlpool LBR5432PQ1 Automatic Washer
Whirlpool LBR5432PQ2 Automatic Washer
Whirlpool LBR5432PT0 Automatic Washer
Whirlpool LBR5432PT1 Automatic Washer
Whirlpool LBR5432PT2 Automatic Washer
Whirlpool LBR6133DQ0
Whirlpool LBR6133DZ0
Whirlpool LBR6233AG0
Whirlpool LBR6233AN0
Whirlpool LBR6233AW0
Whirlpool LBR6233AW1
Whirlpool LBR6233DQ0
Whirlpool LBT6133AG0
Whirlpool LBT6133AN0
Whirlpool LBT6133AW0
Whirlpool LBT6133AW1
Whirlpool LBT6233DQ0
Whirlpool LBV5133AG0
Whirlpool LBV5133AN0
Whirlpool LBV5133AW0
Amana LC-10.000 Commercial Microwaves
Amana LC-10VP.000 Commercial Microwaves
Amana LC-14.000 Commercial Microwaves
Amana LC-14.001 Commercial Microwaves
Amana LC-14VP.000 Commercial Microwaves
Amana LC10EVP.000 Commercial Microwaves
Frigidaire LC120DH5 Frg(v2) / Laundry Center
Frigidaire LC120DL5 Frg(v3) / Laundry Center
Frigidaire LC120DW5 Frg(v1) / Laundry Center
Frigidaire LC120FH1 Frg(v3) / Laundry Center
Frigidaire LC120FL0 Frg(v2) / Laundry Center
Frigidaire LC120FL1 Frg(v2) / Laundry Center
Frigidaire LC120FW0 Frg(v1) / Laundry Center
Frigidaire LC120FW1 Frg(v1) / Laundry Center
Frigidaire LC120JL5 Frg(v1) / Laundry Center
Frigidaire LC120JW5 Frg(v2) / Laundry Center
Amana LC14EVP.000 Commercial Microwaves
Frigidaire LC248DH5 Frg(v2) / Laundry Center
Frigidaire LC248DL5 Frg(v3) / Laundry Center
Frigidaire LC248DW5 Frg(v1) / Laundry Center
Frigidaire LC248EH0 Frg(v2) / Laundry Center
Frigidaire LC248EL0 Frg(v3) / Laundry Center
Frigidaire LC248EW0 Frg(v1) / Laundry Center
Frigidaire LC248FL0 Frg(v2) / Laundry Center
Frigidaire LC248FW0 Frg(v1) / Laundry Center
Frigidaire LC248H1 Frg(v2) / Laundry Center
Frigidaire LC248JL6 Frg(v3) / Laundry Center
Frigidaire LC248JW6 Frg(v4) / Laundry Center
Frigidaire LC248L1 Frg(v3) / Laundry Center
Frigidaire LC248W1 Frg(v1) / Laundry Center
Frigidaire LC400RXD1 Wwh(v2) / 24 " Washer
Frigidaire LC400RXD2 Wwh(v2) / 24 " Washer
Frigidaire LC400RXD3 Wwh(v2) / 24 " Washer
Frigidaire LC400RXW1 Wwh(v1) / 24 " Washer
Frigidaire LC400RXW2 Wwh(v1) / 24 " Washer
Frigidaire LC400RXW3 Wwh(v1) / 24 " Washer
Whirlpool LC4500XKW0
Whirlpool LC4500XMW0
Whirlpool LC4500XMW1
Whirlpool LC4500XSW0
Whirlpool LC4500XTF0
Whirlpool LC4500XTG0
Whirlpool LC4500XTG1
Whirlpool LC4500XTM0
Whirlpool LC4500XTN0
Whirlpool LC4500XTN1
Whirlpool LC4500XTW0
Whirlpool LC4500XTW1
Whirlpool LC4600XKW0
Whirlpool LC4900XKW0
Whirlpool LC4900XMW0
Whirlpool LC4900XMW1
Whirlpool LC4900XSW1
Whirlpool LC4900XTF0
Whirlpool LC4900XTG0
Whirlpool LC4900XTM0
Whirlpool LC4900XTN0
Whirlpool LC4900XTW0
Whirlpool LC4900XTW1
Frigidaire LC550EXD3 Wwh(v1) / Top Loading Washer
Frigidaire LC550EXP3 Wwh(v2) / Top Loading Washer
Frigidaire LC550EXW3 Wwh(v3) / Top Loading Washer
Frigidaire LC550LXD0 Wwh(v2) / Washer
Frigidaire LC550LXD1 Wwh(v2) / Washer
Frigidaire LC550LXW0 Wwh(v1) / Washer
Frigidaire LC550LXW1 Wwh(v1) / Washer
Frigidaire LC590EXD2 Wwh(v4) / Top Loading Washer
Frigidaire LC590EXD3 Wwh(v5) / Top Loading Washer
Frigidaire LC590EXW2 Wwh(v6) / Top Loading Washer
Frigidaire LC590EXW3 Wwh(v7) / Top Loading Washer
Frigidaire LC590LXD0 Wwh(v2) / 24 " Top Load Washer
Frigidaire LC590LXD2 Wwh(v2) / 24 " Top Load Washer
  #2 (permalink)
Old 12-01-2012, 03:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
This washer should completely drain out all water and pause before it will start to spin. Does it do it or it starts to spin while it's full of water?
What was the reason to replace the motor coupling?
Here are the breakdown diagrams and Parts for Whirlpool LBR4132JQ1 Washer - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-01-2012, 10:59 PM
Junior Member
Default
Thanks for the diagrams! I believe it trys to drain but still has a good but if water in it.
  #4 (permalink)
Old 12-11-2012, 11:20 AM
Junior Member
Default
It starts to spin while it is still full of water.
I replaced the motor coupling because the gear on one side was broken. I believe my roommate overloaded it and caused this gear to break, although he denies it.
The washer also leaks a pretty serious amount of water while running.
  #5 (permalink)
Old 12-11-2012, 11:21 AM
Junior Member
Default
Should I try replacing the pump?
  #6 (permalink)
Old 12-11-2012, 02:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by hctp91 View Post
...The washer also leaks a pretty serious amount of water while running...
It is very possible that the pump is the culprit.
- The drain pump Part number: 3363394
P.S. Click on the part number and you will be able to watch the repair video.
__________________
  #7 (permalink)
Old 12-11-2012, 06:38 PM
Junior Member
Default
Is there a way I can test the pump?
  #8 (permalink)
Old 12-12-2012, 03:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If the pump is leaking, you will see it.
Disconnect the hoses from the pump and check for a foreign objects inside.
P.S. Taking the washer apart will eliminate most of questions.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer wont complete spin cycle OMGITS BROKE Washer Repair 1 11-18-2011 06:06 PM
Will not finish spin cycle JEFF POPE Washer Repair 1 12-09-2010 02:58 PM
Washer Will Not Complete Spin Cycle wsminmaine Washer Repair 0 11-09-2010 05:09 AM
Washer won't finish the rinse and spin cycle zamboy Washer Repair 3 05-08-2009 08:41 AM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 07:44 AM
