| » Agitator wont work |
Model Number: LA778OXSW1 Brand: Whirlpool Age: 1 - 5 years
Washer Fills up with water, But Agitator wont work, I turned to spin water out water drains out But still Agitator wont work, Motor sounds good. Any Help would be great, Thanks
So it spins ok but in agitate mode, the motor runs but no agitation? Suggest you pull the agitator and observe top of agitate shaft to see if it goes back and forth while in agitate mode. If it does, the splines in the agitator are likely stripped out. If it doesn't and your sure the motor is running, pull the motor and inspect the drive coupling. Usually, if it's shot, it won't agitate or spin. If it looks good rotate the gearcase input shaft CCW by hand while someone observes the agitator shaft. If the input shaft rotates freely and the agitator shaft doesn't move, the gearcase is bad.
Eric |
| Display Modes | |
| agitator won't work | gardner crocker | Washer Repair | 15 | 10-31-2012 02:15 PM |
| Agitator does not work | joemorin | Washer Repair | 0 | 03-30-2011 05:50 PM |
| Dryer wont work/light wont work | kyleh | Dryer Repair | 0 | 12-28-2010 03:36 PM |
| agitator won't work | gaylynn | Washer Repair | 0 | 04-08-2009 10:40 AM |
| Agitator doesn't work | west1950 | Washer Repair | 1 | 11-23-2008 02:46 PM |
