Discuss
Drum in washer out of balance on spin cycle
 in
Washer Repair
Need to know why my washers drum spins so unbalanced in spin cycle. It will vibrate violently while in spin
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Drum in washer out of balance on spin cycle
  #1 (permalink)
Old 11-30-2012, 09:18 AM
Junior Member
Lawrence Zielinsky is on a distinguished road
Default Drum in washer out of balance on spin cycle
Model Number: 1104680290   Brand: Kenmore   Age: 5 - 10 years
Need to know why my washers drum spins so unbalanced in spin cycle. It will vibrate violently while in spin cycle even with no clothes in the drum. I have checked suspension springs, counter balance spring, and even checked the motor coupler between the motor and tranmission, and find everything to be in order. Please help.
Related Models
Kenmore 11047081600 WASHER
Kenmore 11047081601 RESIDENTIAL WASHER
Kenmore 11047081602 RESIDENTIAL WASHER
Kenmore 11047086600 WASHER
Kenmore 11047086601 RESIDENTIAL WASHER
Kenmore 11047086602 RESIDENTIAL WASHER
Kenmore 11047087600 WASHER
Kenmore 11047087601 RESIDENTIAL WASHER
Kenmore 11047087602 RESIDENTIAL WASHER
Kenmore 11047088600 WASHER
Kenmore 11047088601 RESIDENTIAL WASHER
Kenmore 11047088602 RESIDENTIAL WASHER
Kenmore 11047089600 WASHER
Kenmore 11047089601 RESIDENTIAL WASHER
Kenmore 11047089602 RESIDENTIAL WASHER
Kenmore 11047091600 WASHER
Kenmore 11047091601 RESIDENTIAL WASHER
Kenmore 11047091602 RESIDENTIAL WASHER
Kenmore 11047511700 RESIDENTIAL WASHER
Kenmore 11047511701 RESIDENTIAL WASHER
Kenmore 11047511702 RESIDENTIAL WASHER
Kenmore 11047512600 RESIDENTIAL WASHER
Kenmore 11047512601 RESIDENTIAL WASHER
Kenmore 11047512602 RESIDENTIAL WASHER
Kenmore 11047512603 RESIDENTIAL WASHER
Kenmore 11047512604 RESIDENTIAL WASHER
Kenmore 11047512605 RESIDENTIAL WASHER
Kenmore 11047531700 RESIDENTIAL WASHER
Kenmore 11047531701 RESIDENTIAL WASHER
Kenmore 11047531702 RESIDENTIAL WASHER
Kenmore 11047532600 RESIDENTIAL WASHERS
Kenmore 11047532601 RESIDENTIAL WASHER
Kenmore 11047532602 RESIDENTIAL WASHER
Kenmore 11047532603 RESIDENTIAL WASHER
Kenmore 11047532604 RESIDENTIAL WASHER
Kenmore 11047532605 RESIDENTIAL WASHER
Kenmore 11047542600 RESIDENTIAL WASHER
Kenmore 11047542601 RESIDENTIAL WASHER
Kenmore 11047542602 RESIDENTIAL WASHER
Kenmore 11047542603 RESIDENTIAL WASHER
Kenmore 11047542604 RESIDENTIAL WASHER
Kenmore 11047542605 RESIDENTIAL WASHER
Kenmore 11047561600 RESIDENTIAL WASHERS
Kenmore 11047561601 RESIDENTIAL WASHER
Kenmore 11047561602 RESIDENTIAL WASHER
Kenmore 11047561603 RESIDENTIAL WASHER
Kenmore 11047561604 RESIDENTIAL WASHER
Kenmore 11047562700 RESIDENTIAL WASHER
Kenmore 11047566600 RESIDENTIAL WASHERS
Kenmore 11047566601 RESIDENTIAL WASHER
Kenmore 11047566602 RESIDENTIAL WASHER
Kenmore 11047566603 RESIDENTIAL WASHER
Kenmore 11047567700 RESIDENTIAL WASHER
Kenmore 11047567701 RESIDENTIAL WASHER
Kenmore 11047571600 RESIDENTIAL WASHERS
Kenmore 11047571601 RESIDENTIAL WASHER
Kenmore 11047571602 RESIDENTIAL WASHER
Kenmore 11047571603 RESIDENTIAL WASHER
Kenmore 11047571604 RESIDENTIAL WASHER
Kenmore 11047572700 RESIDENTIAL WASHERS
Kenmore 11047576600 RESIDENTIAL WASHERS
Kenmore 11047576601 RESIDENTIAL WASHER
Kenmore 11047576602 RESIDENTIAL WASHER
Kenmore 11047576603 RESIDENTIAL WASHER
Kenmore 11047577700 RESIDENTIAL WASHER
Kenmore 11047577701 RESIDENTIAL WASHER
Kenmore 11047581600 RESIDENTIAL WASHERS
Kenmore 11047581601 RESIDENTIAL WASHER
Kenmore 11047581602 RESIDENTIAL WASHER
Kenmore 11047581603 RESIDENTIAL WASHER
Kenmore 11047581604 RESIDENTIAL WASHER
Kenmore 11047602940 WASHER
Kenmore 11047661950 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11047662950 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11047701800 RESIDENTIAL WASHER
Kenmore 11047701801 WASHER
Kenmore 11047711800 RESIDENTIAL WASHER
Kenmore 11047711801 WASHER
Kenmore 11047751800 WASHER
Kenmore 11047751801 WASHER
Kenmore 11047761800 RESIDENTIAL WASHER
Kenmore 11047761801 WASHER
Kenmore 11047781700 RESIDENTIAL WASHER
Kenmore 11047781701 RESIDENTIAL WASHER
Kenmore 11047781702 WASHER
Kenmore 11047787800 WASHER
Kenmore 11047787801 WASHER
Kenmore 11047788800 WASHER
Kenmore 11047788801 WASHER
Kenmore 11047789700 RESIDENTIAL WASHER
Kenmore 11047789701 RESIDENTIAL WASHER
Kenmore 11047789702 WASHER
Kenmore 11047791700 RESIDENTIAL WASHER
Kenmore 11047791701 RESIDENTIAL WASHER
Kenmore 11047791702 WASHER
Kenmore 11047797800 RESIDENTIAL WASHER
Kenmore 11047797801 WASHER
Kenmore 11047798800 RESIDENTIAL WASHER
Kenmore 11047798801 WASHER
Kenmore 11047799701 RESIDENTIAL WASHER
Kenmore 11047799702 WASHER
Kenmore 11047852700 WASHER
Kenmore 11047852701 RESIDENTIAL WASHER
Kenmore 11047852702 RESIDENTIAL WASHER
Kenmore 11047852703 RESIDENTIAL WASHER
Kenmore 11047882700 WASHER
Kenmore 11047882701 RESIDENTIAL WASHER
Kenmore 11047882702 RESIDENTIAL WASHER
Kenmore 11047882703 RESIDENTIAL WASHER
Kenmore 11048182790 AUTOMATIC WASHER
Kenmore 11048182791 AUTOMATIC WASHER
Kenmore 11048184790 AUTOMATIC WASHER
Kenmore 11048184791 AUTOMATIC WASHER
Kenmore 11048722790 COMPACT AUTOMATIC WASHER
Kenmore 11048722791 COMPACT AUTOMATIC WASHER
Kenmore 11048724790 COMPACT AUTOMATIC WASHER
Kenmore 11048724791 COMPACT AUTOMATIC WASHER
Kenmore 11049182990 AUTOMATIC WASHER
Kenmore 11049182991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049182992 WASHER
  #2 (permalink)
Old 12-01-2012, 05:00 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
You should also check the pads that the tub support rests on, one or more of them could be gone.
If you cannot find anything wrong go ahead and change out the springs. They can be without any visual evidence of a problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Washer is out of balance on the Spin Cycle videoproco Washer Repair 1 02-06-2011 08:30 AM
Washer Balance Spin Cycle chalcongdon Washer Repair 0 03-13-2010 11:22 AM
whirlpool washer bangs during spin cycle like its out of balance joekelli Washer Repair 2 01-01-2010 07:12 AM
My Washer Is Terribly Off Balance On Spin Cycle ROBYNZ66 Washer Repair 1 12-09-2008 07:16 AM
washer out of balance spin cycle mcoffman5 Washer Repair 8 11-12-2008 06:43 AM
