Discuss
fill problem
 in
Washer Repair
Whirlpool Washer llc7244aqo begins filling normally. After about a minute, flow rate slows down to a trickle. Acts like a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » fill problem
  #1 (permalink)
Old 11-30-2012, 08:27 AM
Junior Member
dennisjdwyer is on a distinguished road
Default fill problem
Model Number: llc7244aqo   Brand: Whirlpool   Age: 5 - 10 years
Whirlpool Washer llc7244aqo begins filling normally. After about a minute, flow rate slows down to a trickle. Acts like a voltage drop to fill valve solenoids so they partially close. Is this possible? Doesn't matter if temp setting is hot, cold, or warm. Doesn't matter where water level switch is set. Doesn't matter which wash cycle is used. If machine is shut off for a minute, then turned back on, same thing happens. Strong flow slows to trickle. Same fill symptoms when timer is turned to start rinse cycle. When I turn timer to spin, machine spins, empties and shuts off properly. I have not tried filling machine manually to see if washer or rinse cycle kicks in. Fill valve replaced - it was dripping while machine off. Water level switch replaced - no change. I have seen electrical parts malfunction only when they have heated up in other situations. If this unit had a power supply, I would suspect that issue. I am somewhat baffled here.
Ads By Google
Related Models
Whirlpool LLC7244AW0
Whirlpool LLC7244AZ0
Whirlpool LLC7244BQ0
Whirlpool LLC7244BQ1
Whirlpool LLC7244BZ0
Whirlpool LLC7244BZ1
Whirlpool LLC8244DQ0
Whirlpool LLC8244DZ0
Whirlpool LLN8233BN0
Whirlpool LLN8233BN1
Whirlpool LLN8233BQ0
Whirlpool LLN8233BQ1
Whirlpool LLN8233BW0
Whirlpool LLN8233BW1
Whirlpool LLN8244AN0
Whirlpool LLN8244AW0
Whirlpool LLN8244BN0
Whirlpool LLN8244BW0
Admiral LLR1100AJQ RANGE- F/S STD GAS
Admiral LLR1100AJW RANGE- F/S STD GAS
Admiral LLR1415AJS RANGE- F/S STD GAS
Admiral LLR1415AJW RANGE- F/S STD GAS
Admiral LLR4451AJS RANGE- F/S STD GAS
Admiral LLR4451AJW RANGE- F/S STD GAS
Whirlpool LLR5144BQ0
Whirlpool LLR5144BQ1
Whirlpool LLR5144BW0
Whirlpool LLR6144AN0
Whirlpool LLR6144AQ0
Whirlpool LLR6144AW0
Whirlpool LLR6144BN0 WASHER
Whirlpool LLR6144BN1 AUTOMATIC WASHER
Whirlpool LLR6144BQ0 WASHER
Whirlpool LLR6144BQ1 AUTOMATIC WASHER
Whirlpool LLR6144BW0 WASHER
Whirlpool LLR6233AN0
Whirlpool LLR6233AN1
Whirlpool LLR6233AQ0
Whirlpool LLR6233AW0
Whirlpool LLR6233AW1
Whirlpool LLR7144DQ0
Whirlpool LLR7144DW0
Whirlpool LLR7144DZ0
Whirlpool LLR8233BN0 AUTOMATIC WASHER
Whirlpool LLR8233BN1 AUTOMATIC WASHER
Whirlpool LLR8233BQ0 AUTOMATIC WASHER
Whirlpool LLR8233BQ1 AUTOMATIC WASHER
Whirlpool LLR8233BW0 AUTOMATIC WASHER
Whirlpool LLR8233BW1 AUTOMATIC WASHER
Whirlpool LLR8233DQ0 AUTOMATIC WASHER
Whirlpool LLR8233DW0 AUTOMATIC WASHER
Whirlpool LLR8233DZ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ1 DIRECT-DRIVE WASHER
Whirlpool LLR8233EZ0 AUTOMATIC WASHER
Whirlpool LLR8233EZ1 DIRECT-DRIVE WASHER
Whirlpool LLR8245AW0 Washers
Whirlpool LLR8245BN0 AUTOMATIC WASHER
Whirlpool LLR8245BN1 AUTOMATIC WASHER
Whirlpool LLR8245BW0 AUTOMATIC WASHER
Whirlpool LLR8245BW1 AUTOMATIC WASHER
Whirlpool LLR8245DQ0 AUTOMATIC WASHER
Whirlpool LLR8245DZ0 AUTOMATIC WASHER
Whirlpool LLR9245AQ0
Whirlpool LLR9245BQ0
Whirlpool LLR9245BQ1 WASHERS DIRECT-DRIVE
Whirlpool LLR9245DQ0
Whirlpool LLR9245DQO WHIRLPOOL WASHER
Whirlpool LLR9245DZ0
Whirlpool LLR9245DZO WHIRLPOOL WASHER
Whirlpool LLT7144AN0 Washers*
Whirlpool LLT7144BN0
Whirlpool LLT7144BQ0
Whirlpool LLT7144BQ1
Whirlpool LLT7144BW0
Whirlpool LLT7144DQ0
Whirlpool LLT8233AN0
Whirlpool LLT8233AQ0
Whirlpool LLT8233AW0
Whirlpool LLT8233AW1 AUTOMATIC WASHER
Whirlpool LLT8233AW2
Whirlpool LLT8233DQ0
Whirlpool LLT8233DZ0
Whirlpool LLT8244AN0
Whirlpool LLT8244AQ0
Whirlpool LLT8244AW0
Whirlpool LLT8244AZ0
Whirlpool LLT8244BQ0
Whirlpool LLT8244BQ1
Whirlpool LLT8244BZ0
Whirlpool LLT8244BZ1
Whirlpool LLT8244DQ0
Whirlpool LLT8244DZ0
Whirlpool LLV6144AG0
Whirlpool LLV6144AN0
Whirlpool LLV6144AW0
Whirlpool LLV6144BN0
Whirlpool LLV6144BW0
Whirlpool LLV7233AW0
Whirlpool LLV7244AG0
Whirlpool LLV7244AN0
Whirlpool LLV7244AW0
Whirlpool LLV8233BN0
Whirlpool LLV8233BQ0
Whirlpool LLV8233BW0
Whirlpool LLV8245AG0
Whirlpool LLV8245AN0
Whirlpool LLV8245AW0
Whirlpool LLV8245BN0
Whirlpool LLV8245BW0
Whirlpool LLV8245DQ0
Whirlpool LLV8245DZ0
 LM-1830C2L Air Conditioner
 LM-2430C2L Air Conditioner
 LM-2430H2L Air Conditioner
 LM360CE Air Conditioner
Whirlpool LMA1053LQ0
  #2 (permalink)
Old 11-30-2012, 04:32 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Check the voltage directly across the solenoid terminals while its filling to see if it drops.
Eric
  #3 (permalink)
Old 12-01-2012, 01:59 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
See the attachment for the wiring diagram.
It is worth checking the voltage Fairbank56 said.
But I doubt that is your problem.
I have never see a water valve that will partially open due to low voltage.
They are basically a solenoid so are fully open or fully closed though they can leak, they cannot be partially opened by varying the voltage.
I also doubt that it is the level switch.
Besides you have replaced both of them.
I would do the following before checking the voltage just because it is a bit easier and a lot safer than doing a live voltage test.
I would look at the water supply.
Do you have the same problem with other plumbing fixtures in the house?
Are you on city water or is this a well? Could be a problem with your water system.
Is the washer protected with a burst pipe system? These can cause problems.
That it effects both hot and cold is a puzzling.
My first thought was that it is a bad cold water fill hose.
They can de-laminate internally. Then when water flows the flap (de-lamination) is pushed inward and shuts off or reduces water flows.
Remove the hoses from the washer .
And try running them into a pail to see if the flow still reduces.
Remove the hoses and check both ends. Some hoses have a screen filter built into the sealing washer that you should check/clean.
Swap the hoses (Hot/cold) to see if that makes any difference.
__________________
  #4 (permalink)
Old 12-10-2012, 02:55 PM
Junior Member
Default solved
There was a problem in the unilever style shut off valve in the washer box in the wall. When it was replaced, problem went away. Thanks for the suggestions. DD
  #5 (permalink)
Old 12-11-2012, 02:37 AM
Senior Expert
APP Volunteer
Default
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher fill problem 14617aj Dishwasher Repair 1 10-02-2011 10:33 AM
Intermittent fill/drain problem nele Dishwasher Repair 1 04-22-2011 07:17 AM
Water fill problem redsunding Dishwasher Repair 2 09-03-2009 06:22 AM
Amana Washer fill problem porter5224 Washer Repair 1 03-28-2009 06:02 AM
Ge profile fill problem Danfros Dishwasher Repair 2 04-15-2008 05:59 AM
