Discuss
E59 Error Code, No Tach Signal in 3 sec
 in
Washer Repair
Our Kenmore front loading washer failed to spin on the final spin cycle. I followed the diagnostic procedures and retreived
Appliance Repair Forum > Appliance Repair Help > Washer Repair » E59 Error Code, No Tach Signal in 3 sec
  #1 (permalink)
Old 11-29-2012, 06:15 PM
Junior Member
Joseph A Stanko is on a distinguished road
Default E59 Error Code, No Tach Signal in 3 sec
Model Number: 417.44052400   Brand: Kenmore   Age: 5 - 10 years
Our Kenmore front loading washer failed to spin on the final spin cycle. I followed the diagnostic procedures and retreived the above error code, E59, no tach signal in 3 seconds. The instructions said to first make various resistance measurements on the motor. I tested the three windings and found low resistance as expected. However the measurement of the resistance in the motor tachometer circuit between pins 4 & 5, was also low, whereas the instructions said "if it is not in the 105 to 130 ohm range, replace the motor". I ordered one from Appliance Parts Pros and they had it to me in one day! Before installing it, I checked the resistances on the new motor and found them to be identical to the original! I expected the higher, called for resistance in the tach circuit.
Am I making a mistake somewhere, or could there be an error in the diagnostic instructions? I am hesitant to install the new motor, when it does not seem to be giving the correct resistance value. Any suggestions?
Ads By Google
Related Models
Kenmore 41715644 OUTDOOR GRILL
Kenmore 41724182300 WASHER
Kenmore 41724182301 WASHER
Kenmore 41727182700 WASHER
Kenmore 41727182701 WASHER
Kenmore 41727182702 WASHER
Kenmore 41727182703 WASHER
Kenmore 41727182704 WASHER
Kenmore 41729022890 FREESTANDING WASHER
Kenmore 41729042990 FRONTLOAD WASHER
Kenmore 41729042991 KENMORE WASHER
Kenmore 41729042992 FRONT LOAD WASHER
Kenmore 41729052990 KENMORE WASHER
Kenmore 41729052991 WASHER
Frigidaire 41739012890 Frg(v0) / Washer
Kenmore 41739012890 STACK WASHER
Kenmore 41739012891 WASHER
Frigidaire 41739012891 WASHER
Frigidaire 41739022890 Frg(v0) / Washer
Kenmore 41739022891 WASHER
Frigidaire 41739022891 Frg/washer
Kenmore 41740032990 WASHER
Kenmore 41740042990 WASHER
Kenmore 41740052990 WASHER
Kenmore 41740142000 WASHER
Kenmore 41740412700 WASHER
Kenmore 41740412701 WASHER
Kenmore 41740412702 SEARS/FRONT LOAD WASHER -0582
Kenmore 41740412703 WASHER
Kenmore 41741042000 WASHER
Kenmore 41741052000 FRONTLOAD WASHER
Kenmore 41741100000 WASHER
Kenmore 41741101000 WASHER
Kenmore 41741102000 WASHER
Kenmore 41741142000 RESIDENTIAL WASHER
Kenmore 41742042100 WASHER
Kenmore 41742052100 WASHER
Kenmore 41742142100 WASHER
Kenmore 41743042200 SEARS/FRONTLOAD WASHER
Kenmore 41743042300 WASHER
Kenmore 41743052200 SEARS/FRONTLOAD WASHER
Kenmore 41743142200 SEARS/FRONTLOAD WASHER
Kenmore 41743142300 WASHER
Kenmore 41744042400 WASHER
Kenmore 41744052400 WASHER
Kenmore 41744052401 WASHER
Kenmore 41744052500 WASHER
Kenmore 41744072300 WASHER
Kenmore 41744082400 WASHER
Kenmore 41744082500 WASHER
Kenmore 41744092500 WASHER
Kenmore 41744102300 WASHER
Kenmore 41744102301 WASHER
Kenmore 41744130000 WASHER
Kenmore 41744131000 WASHER
Kenmore 41744132000 WASHER
Kenmore 41744142400 WASHER
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
Last edited by Joseph A Stanko : 11-29-2012 at 06:17 PM. Reason: Mistake in description of the washer
  #2 (permalink)
Old 11-30-2012, 12:44 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
I think you should install a new motor and see if that will fix it.
You can return it to APP even if you installed it.
If the problem still exists check the connector plugs at the motor control and main board, replace the motor control board.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-02-2012, 11:03 AM
Junior Member
Default
Dear Simon,
Thank you for replying. I followed your advice and cleaned the contacts on the motor, where the 5-pin cable from the motor controller board plugs in, but the motor still does not budge during the spin diagnostic test.
I then took the new motor, cleaned its contacts, and plugged the 5-pin cable into it and ran through the diagnostic tests. It showed no response either.
I then removed the plug to the motor and tested the AC voltage in succession between pins 1-3, 2-3, and 1-2 which supply the motor windings (I think). The meter only budged a little in the during the diagnostic tests--no where near the 120 v (?) expected. Seems like no electrical power is being applied to the motor?
Do you think I should go ahead and order a new motor controller board and return the new motor? Also I had a further thought on the interpretation of the original E59 code. From what I have read, the tachometer leads, 4 and 5, to the end shaft of the motor produce an impulse to send back to the controller board to tell it the motor speed. So when the mc board doesn't receive anysignal within 3 seconds, it must assume the motor shaft is not turning or that the tach sensor is bad. What do you think?
Joseph A. Stanko
Last edited by Joseph A Stanko : 12-02-2012 at 12:12 PM. Reason: Not finished; added something
  #4 (permalink)
Old 12-02-2012, 04:59 PM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Simon.
Dear Simon,
I am so excited. Got the washer working again. Your last suggestion above worked! In anticipation of having to order a new motor control board, after eliminating the motor as the problem, I figured I better try taking it out to see if I hit any unanticipated obstacles. It came out prettry easy, one hold down screw, and two plastic feet through the bottom. Once I got it out and opened the hinged door to see the connection, I noticed one connector dangling. I thought I may have dislodged it taking the unit out. It was a connector that slide onto contacts on the edge of the control board. After making this connection and with the board outside the back of the washer, I put it through the diagnostic cycle again, and lo and behold, the drum tosssed and spun at the appropriate points. I was elated! I put the mcb unit back in and put all the panels back on and ran a test load. It was so sweet to see those clothes tossing a turning once again and with the water being spun out of them so completely on that last spin!
Thank you so much for your helpful comments(particularly about checking for any faulty contacts on the board). Thanks to Appliance Parts Pros for establishing this repair forum. I have learned a lot from all the posts. Best wishes to others still trying to resolve their issues. You just have to take it one step at a time under the guidance of you "Pro's".
Joseph A. Stanko
  #5 (permalink)
Old 12-03-2012, 06:16 AM
Junior Member
bleonard is on a distinguished road
Default
also glad to see you got your machine back up and running with a simple fix. the only thing i see is that when i was checking the pins 1-2, 1-3, 2-3 i was checking for ohms and it measured exactly like it was suppose to, 6 ohms each, and the 4-5 was the 120 ohms. now checking the 1, 2, and 3 to ground, i got weird voltages which ended up being the problem.
hopefully you will not have to use this info. but good luck anyway
  #6 (permalink)
Old 12-03-2012, 11:23 AM
Expert
Default
Hi.
Congratulations on the good job done and thank you for shearing with us useful information.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ERROR CODE F6E5 Cancel key error tammike Oven Repair (including Ranges and Cooktops) 8 08-06-2012 08:54 AM
Duet error code FH and diagnostic code C03 angelo78 Washer Repair 0 03-21-2012 08:12 AM
LG error code OE - drain error JPotter Washer Repair 0 04-01-2011 07:20 AM
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
F4 error signal nanandlee Oven Repair (including Ranges and Cooktops) 0 07-30-2009 08:58 AM
