Discuss
Erratic display times, won't drain water, won't spin properly
 in
Washer Repair
Washer goes through the cycles properly, but the displayed times will increase or decrease, then go to the next cycle
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Erratic display times, won't drain water, won't spin properly
  #1 (permalink)
Old 11-27-2012, 08:11 PM
Junior Member
Turbobob is on a distinguished road
Post Erratic display times, won't drain water, won't spin properly
Model Number: wtw5600xw0   Brand: Whirlpool   Age: 1 - 5 years
Washer goes through the cycles properly, but the displayed times will increase or decrease, then go to the next cycle and do the same thing. Water stays in the tub and during the spin cycle, does not have enough time to drain properly, and the displayed times are erratic. The result is a wet load when it is done.
I suspect a faulty control board since that is the only thing I see that would control the cycles and times. Any thoughts?
Related Models
Whirlpool WTW5600XW0 AUTOMATIC WASHER
Whirlpool WTW5600XW1 AUTOMATIC WASHER
Whirlpool WTW5600XW2 WASHER
Whirlpool WTW5610XW0 AUTOMATIC WASHER
Whirlpool WTW5610XW1 AUTOMATIC WASHER
Whirlpool WTW5610XW2 WASHER
Whirlpool WTW5640XW0 AUTOMATIC WASHER
Whirlpool WTW5640XW1 AUTOMATIC WASHER
Whirlpool WTW5640XW2 WASHER
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
Whirlpool WTW5790VQ2 AUTOMATIC WASHER
Whirlpool WTW57ESVH0 AUTOMATIC WASHER
Whirlpool WTW57ESVH1 AUTOMATIC WASHER
Whirlpool WTW57ESVW0 AUTOMATIC WASHER
Whirlpool WTW57ESVW1 AUTOMATIC WASHER
Whirlpool WTW5800SG0 AUTOMATIC WASHER
Whirlpool WTW5800SW0 AUTOMATIC WASHER
Whirlpool WTW5810SW0 AUTOMATIC WASHER
Whirlpool WTW5820SW0 AUTOMATIC WASHER
Whirlpool WTW5821SW0 AUTOMATIC WASHER
Whirlpool WTW5830SW0 AUTOMATIC WASHER
Whirlpool WTW5840SG0 AUTOMATIC WASHER
Whirlpool WTW5840SW0 AUTOMATIC WASHER
Whirlpool WTW5850SG0 AUTOMATIC WASHER
Whirlpool WTW5850SW0 AUTOMATIC WASHER
Whirlpool WTW5860SG0 AUTOMATIC WASHER
Whirlpool WTW5860SW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW1 AUTOMATIC WASHER
Whirlpool WTW5900SB0 AUTOMATIC WASHER
Whirlpool WTW5900SW0 AUTOMATIC WASHER
Whirlpool WTW5900TB0 AUTOMATIC WASHER
Whirlpool WTW5900TW0 AUTOMATIC WASHER
Whirlpool WTW6200SW0 AUTOMATIC WASHER
Whirlpool WTW6200SW1 AUTOMATIC WASHER
Whirlpool WTW6200SW2 AUTOMATIC WASHER
Whirlpool WTW6200SW3 AUTOMATIC WASHER
Whirlpool WTW6200VW0 AUTOMATIC WASHER
Whirlpool WTW6200VW1 AUTOMATIC WASHER
Whirlpool WTW6300SB0 AUTOMATIC WASHER
Whirlpool WTW6300SB1 AUTOMATIC WASHER
Whirlpool WTW6300SB2 AUTOMATIC WASHER
Whirlpool WTW6300SG0 AUTOMATIC WASHER
Whirlpool WTW6300SG1 AUTOMATIC WASHER
Whirlpool WTW6300SG2 AUTOMATIC WASHER
Whirlpool WTW6300SW0 AUTOMATIC WASHER
Whirlpool WTW6300SW1 AUTOMATIC WASHER
Whirlpool WTW6300SW2 AUTOMATIC WASHER
Whirlpool WTW6300WW0 AUTOMATIC WASHER
Whirlpool WTW6340WW0 AUTOMATIC WASHER
Whirlpool WTW6400SW0 AUTOMATIC WASHER
Whirlpool WTW6400SW1 AUTOMATIC WASHER
Whirlpool WTW6400SW2 AUTOMATIC WASHER
Whirlpool WTW6400SW3 AUTOMATIC WASHER
Whirlpool WTW6500WW1 AUTOMATIC WASHER
Whirlpool WTW6600SB0 AUTOMATIC WASHER
Whirlpool WTW6600SB1 AUTOMATIC WASHER
Whirlpool WTW6600SB2 AUTOMATIC WASHER
Whirlpool WTW6600SB3 AUTOMATIC WASHER
Whirlpool WTW6600SG0 AUTOMATIC WASHER
Whirlpool WTW6600SG1 AUTOMATIC WASHER
Whirlpool WTW6600SG2 AUTOMATIC WASHER
Whirlpool WTW6600SG3 AUTOMATIC WASHER
Whirlpool WTW6600SW0 AUTOMATIC WASHER
Whirlpool WTW6600SW1 AUTOMATIC WASHER
Whirlpool WTW6600SW2 AUTOMATIC WASHER
Whirlpool WTW6600SW3 AUTOMATIC WASHER
Whirlpool WTW6700TU1 AUTOMATIC WASHER
Whirlpool WTW6700TU2 AUTOMATIC WASHER
Whirlpool WTW6700TW0 AUTOMATIC WASHER
Whirlpool WTW6700TW1 AUTOMATIC WASHER
Whirlpool WTW6700TW2 AUTOMATIC WASHER
Whirlpool WTW6800WB1 AUTOMATIC WASHER
Whirlpool WTW6800WE1 RESIDENTIAL WASHER
Whirlpool WTW6800WL1 AUTOMATIC WASHER
Whirlpool WTW6800WU1 RESIDENTIAL WASHER
Whirlpool WTW6800WW1 AUTOMATIC WASHER
Whirlpool WTW7300XW0 AUTOMATIC WASHER
Whirlpool WTW7300XW1 AUTOMATIC WASHER
Whirlpool WTW7300XW2 AUTOMATIC WASHER
Whirlpool WTW7320YW0 WASHER
Whirlpool WTW7340XW0 AUTOMATIC WASHER
Whirlpool WTW7340XW1 AUTOMATIC WASHER
Whirlpool WTW7340XW2 AUTOMATIC WASHER
Whirlpool WTW7600XW0 AUTOMATIC WASHER
Whirlpool WTW7600XW1 AUTOMATIC WASHER
Whirlpool WTW7600XW2 AUTOMATIC WASHER
Whirlpool WTW7800XB0 AUTOMATIC WASHER
Whirlpool WTW7800XB1 AUTOMATIC WASHER
Whirlpool WTW7800XB2 AUTOMATIC WASHER
Whirlpool WTW7800XB3 AUTOMATIC WASHER
Whirlpool WTW7800XB4 AUTOMATIC WASHER
Whirlpool WTW7800XL0 AUTOMATIC WASHER
Whirlpool WTW7800XL1 AUTOMATIC WASHER
Whirlpool WTW7800XL2 AUTOMATIC WASHER
Whirlpool WTW7800XL3 AUTOMATIC WASHER
Whirlpool WTW7800XL4 AUTOMATIC WASHER
Whirlpool WTW7800XW0 AUTOMATIC WASHER
Whirlpool WTW7800XW1 AUTOMATIC WASHER
Whirlpool WTW7800XW2 AUTOMATIC WASHER
Whirlpool WTW7800XW3 AUTOMATIC WASHER
Whirlpool WTW7800XW4 AUTOMATIC WASHER
Whirlpool WTW7990XG0 AUTOMATIC WASHER
Whirlpool WTW7990XG1 AUTOMATIC WASHER
Whirlpool WTW8200YW0 AUTOMATIC WASHER
Whirlpool WTW8240YW0 AUTOMATIC WASHER
Whirlpool WTW8600YW0 AUTOMATIC WASHER
Whirlpool WTW8800YC0 WASHER
  #2 (permalink)
Old 11-28-2012, 06:12 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Are you only using HE detergent? After normal cycle and you still have water in tub, select drain/spin mode. Will it fully drain and spin water out of clothes?
Eric
  #3 (permalink)
Old 11-28-2012, 04:17 PM
Junior Member
Default
Yes, I am using HE detergent for cold water. Tried the drain/spin mode, and it filled the tub while in that drain/spin mode. It is as if the processor got hung up and could not reset itself, and filled the tub while in the spin mode. I ended up unplugging the washer and letting it rest overnight.
Today I took the front control panel apart and looked to see of there were any loose connectors to the main control board, but they were OK. Pushed them down to be sure, made sure the water fill tube was connected securely, then put it through a full wash cycle and monitored it. All was OK.
I'm going to try other wash loads and monitor the progress, but it looks like a possible board issue if the water fills the tub in the spin mode, do you agree, or is there something else I have to look at?
Oh, do you know how to open the top of the washer? I tried looking for release clips in the front, but didn't find any, and tried prying it up a little, but nothing released easily so I didn't go any further.
Those two clips to release the front control panel are a real pain. Is there any easy way to release them other than pushing them in with a screwdriver?
Thanks.
  #4 (permalink)
Old 11-28-2012, 04:47 PM
Expert
APP Volunteer
Default
There have been lots of issues with this new Whirlpool design including erratic main control units. You might check the air dome on the lower right side of the outer tub. That's where the air hose from the MCU connects to and measures pressure based on water level. The air dome and hose can get gunked up giving false readings to the MCU. To open the top panel, remove the top screw of the hinge on each side on the back of the washer as well as remove the wiring harness cover next to one of the hinges. Then pull the top panel forward 1/2", up 1/4" and back 1/4". As far as those control panel clips, the prescribed method is to push back on the top corner of the panel while inserting putty knife under lower corner pushing into the clip. You can also try releasing them from underneath reaching over the top of the tub.
Eric
  #5 (permalink)
Old 12-10-2012, 02:32 PM
Junior Member
Default
After more diagnosis, I ordered and replaced the Actuator/Shifter, and this resolved the issue for me. It seems the actuator/shifter was not always moving the tub to the proper position, thus letting the control board know that the tub was not moving when it should be. That action also caused the Lid Lock light to blink at various times, adding to the mystery.
Anyway, the service guy I had come in did not carry this common part, and he confirmed what I thought about the actuator/shifter, so I ordered it on my own and replaced it, saving about $160 in additional repair costs.
Whirlpool part # W10006355 Shift Actuator
Thanks to those who responded to my situation, and I hope others will be able to use this information also.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer won't spin/drain properly michelle131 Washer Repair 3 10-28-2012 06:01 AM
Display erratic number display Billnfran Dishwasher Repair 0 01-23-2012 08:03 PM
Washer works properly at times and stops between wash and spin/pump cycles at times sawgrassusa Washer Repair 0 02-26-2011 08:02 AM
Erratic display & cycles irwinbrown Dishwasher Repair 0 09-04-2010 07:35 AM
washer did not drain completely, spin properly tashley Washer Repair 1 06-13-2009 04:36 PM
