Discuss
Washer Trips on Thermal? Video Link Inside
 in
Washer Repair
I bought this washer used. After I bought it, the belt around the water pump pulley got stuck and burned
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Trips on Thermal? Video Link Inside
  #1 (permalink)
Old 11-27-2012, 12:35 PM
Junior Member
page305 is on a distinguished road
Default Washer Trips on Thermal? Video Link Inside
Brand: GE   Age: 1 - 5 years
I bought this washer used. After I bought it, the belt around the water pump pulley got stuck and burned itself up. I replaced the belt (1/4" smaller in length than OEM).
While I was doing this I knocked the hose that allows the washer to sense the water level off and it leaked all over the place, I know that some of the electrical got wet (including the motor).
The washer has 2 spin speeds. Normal/Slow and Normal/Fast... I can not use the Normal/Fast as it tries to burn the belt again. But during the Normal/Slow spin I hear a repeated clicking in sync with the spring popping in and out on the tension pulley for the belt that wraps around the water pump (I'm assuming it's the drive belt also?). After 10 seconds or so the motor shuts off and I can smell a very slight electrical burning smell. I'm assuming this is a thermal overlaod? It does move water...
If any of the experience users could please listen to the operation in this youtube video, it would be much appreciated...
1127121418 - YouTube
Thanks,
Jim.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
what's my oven doing? (video link) bovardc Oven Repair (including Ranges and Cooktops) 0 11-28-2010 09:33 PM
thermal fuse trips, wont complete cycle kendunkelberger Dishwasher Repair 1 11-23-2010 05:42 AM
Thermal link & High Temp sensor Abnormal Norman Dryer Repair 3 05-26-2010 06:34 AM
GE Microwave making humming sound, trips trips fuse cadena16 Microwave Repair 1 07-07-2008 02:30 PM
