| » Whirlpool Duet washer trouble |
Model Number: WFW9750WW01 Brand: Whirlpool Age: 1 - 5 years
Hoping you folks can help me out. I have a Whirlpool Duet washer that is basically dead. It worked Thursday night and Friday morning it would not do anything. I can hit the control lock button and it will light up and beep but there is nothing showing on the display. The model number is WFW9750WW01. I ordered a door latch assembly from Appliance Parts Pros as I was advised this was most likely the problem. It arrived this morning, I installed it, the washer is still dead. Any ideas on where to go from here?? PLEASE HELP. Hahaha
You may want to start the troubleshooting from verifying the power to the washer and to its control board.
Remove the top panel and check for 120 VAC at the power cord connection to the line filter. Then check for 120 VAC coming out of the line filter. If the readings are good, check for 120 VAC to the Central Control Unit at the IF2 connector. If the reading is correct, replace the CCU. - The CCU Part number: W10283461 - The line filter Part number: W10326464 Here are the breakdown diagrams and Parts for Whirlpool WFW9750WW01 Washer - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| whirlpool washer trouble please help! | nflguy | Washer Repair | 0 | 07-21-2012 06:01 PM |
| whirlpool washer trouble | mtthompson | Washer Repair | 1 | 06-01-2012 05:58 PM |
| Trouble with Whirlpool washer! | gamebird | Oven Repair (including Ranges and Cooktops) | 0 | 08-21-2011 10:44 PM |
| Whirlpool Duet trouble -draining | momofthre3 | Washer Repair | 0 | 05-24-2010 06:04 PM |
| whirlpool duet trouble | wildfire14032 | Washer Repair | 1 | 08-26-2009 12:26 PM |
