Discuss
GE Washer agitator not working and will not spin
 in
Washer Repair
I have retried washer and agitator is working.The machine doesn't spin, but water fills and pumps out.Could
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer agitator not working and will not spin
  #1 (permalink)
Old 02-01-2008, 10:40 AM
bobbertj bobbertj is offline
Junior Member
bobbertj is on a distinguished road
Default GE Washer agitator not working and will not spin
Model Number: WSKS2060T   Brand: GE   Age: 5 - 10 years
I have retried washer and agitator is working.The machine doesn't spin, but water fills and pumps out.Could this be a coupler hub assembly problem?
Last edited by bobbertj : 02-01-2008 at 12:16 PM. Reason: Retried washer and found it worked through cycles except spinning.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-01-2008, 03:38 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Unfortunately I do not have any experience with such washer.
Maybe somebody else on the forum can help you better.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-01-2008, 07:07 PM
Junior Member
Default
Gene thanks for trying.I hope that someone else might have worked on the smaller type washer.
  #4 (permalink)
Old 02-02-2008, 05:34 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
is this an apartment size washer that rolls to sink 110 volts? are you saying machine does fill + agitate +drain. the only thing it does not do is spin?l
__________________
  #5 (permalink)
Old 02-03-2008, 07:25 AM
Junior Member
Default
This is like the large washer.Is similiar to the stack units except it is just the washer. I have narrowed it down to a solinoid that shifts from spin to agitate cylces or a defective timer. I don't think it's the timer as it doesn't spin when you put it in the separate spin cycle.How do you test out a solenoid with the following specs?AC127V50/80,150mA.If you have any other suggestions I would like to get this running again.Thank You
  #6 (permalink)
Old 04-04-2008, 09:43 PM
bambiblaster bambiblaster is offline
Senior Expert
APP Volunteer
bambiblaster is on a distinguished road
Default
There is a tech sheet under the top .. it will have the testing and trouble shooting steps...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool upper agitator not working Roger-dodger Washer Repair 1 01-22-2008 09:06 PM
Admiral Washer Spin Cycle Not Working achetwood Washer Repair 3 12-17-2007 07:44 PM
Washer agitator jerry usry Washer Repair 0 12-03-2007 08:20 AM
Top agitator on duel agitator not working bigfoot Washer Repair 1 10-28-2007 06:34 AM
Agitator not spin, tub not spin russell Washer Repair 2 10-27-2007 03:38 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
