| » Where can I buy bearings? |
Model Number: MAH 700 AWW Brand: Maytag Age: 5 - 10 years
Where can I buy a tub bearing kit, or both bearings, shaft seal and tub seal? That is, without the tub half, I do not need the tub half.
I cannot find any info on the given model number.
Perhaps the following will help. Neptune Bearing Repair - Pic Tutorial I found it by using Advanced Search / Search in Forums / Washer Repair / "tub bearings" perhaps there are other posts in this search that my help you.
__________________
Quote:
I know the seal kit is probably available from AppliancePartsPros.
The reason I say probably is that I cannot find any info on the given model number. I even tried the Maytag site with no luck.
__________________
Typo on the model # MAH 6700 AWW. AppliancePartsPro shows the back half of the tub cover available (I suppose with bearings, but no bearing kit)
| Display Modes | |
| Where are the bearings? | ken P | Washer Repair | 31 | 02-01-2012 08:29 AM |
| tub bearings | steve legault | Washer Repair | 1 | 01-18-2011 11:47 AM |
| Tub Bearings | ronald014@ameritech.net | Washer Repair | 0 | 01-10-2011 07:17 AM |
| Bearings Bad | woodmiser | Washer Repair | 0 | 11-28-2010 07:58 PM |
| bearings going bad? | badbikers | Washer Repair | 3 | 05-17-2008 10:25 AM |
