Discuss
Whilpool Washer - WON'T AGITATE!
 in
Washer Repair
Washer fills and empties ok, BUT it will NOT agitate! The motor is running and IF there is NO clothes
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whilpool Washer - WON'T AGITATE!
View Poll Results: Whirlpool washer- WON'T AGITATE!
motor runs- no agitation. 0 0%
oil under washer 0 0%
how expensive to repair 0 0%
difficult repair? 0 0%
Voters: 0. You may not vote on this poll
  #1 (permalink)
Old 11-25-2012, 11:48 AM
Junior Member
sic-pupy is on a distinguished road
Unhappy Whilpool Washer - WON'T AGITATE!
Model Number: LSQ8543JTO   Brand: Whirlpool   Age: 5 - 10 years
Washer fills and empties ok, BUT it will NOT agitate! The motor is running and IF there is NO clothes in washer it will agitate VERY slowly unless you touch it gently with your finger. Then, it will stop! Pulled washer out from its normal spot and found a patch of OIL about 4" - 5" in diameter under it. Can anyone PLEASE help in pin pointing my problem or what I can do to pin point my problem?????? Thank-You!
Related Models
Whirlpool LSQ8543JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JZ1 WASHER
Whirlpool LSQ9010KQ0 WASHER
Whirlpool LSQ9010KT0 WASHER
Whirlpool LSQ9010LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LG1 AUTOMATIC WASHER
Whirlpool LSQ9010LG2 AUTOMATIC WASHER
Whirlpool LSQ9010LG3 AUTOMATIC WASHER
Whirlpool LSQ9010LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LQ1 AUTOMATIC WASHER
Whirlpool LSQ9010LQ2 AUTOMATIC WASHER
Whirlpool LSQ9010LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LW1 AUTOMATIC WASHER
Whirlpool LSQ9010LW2 AUTOMATIC WASHER
Whirlpool LSQ9010LW3 AUTOMATIC WASHER
Whirlpool LSQ9010PG0 AUTOMATIC WASHER
Whirlpool LSQ9010PG1 AUTOMATIC WASHER
Whirlpool LSQ9010PG2 AUTOMATIC WASHER
Whirlpool LSQ9010PG3 AUTOMATIC WASHER
Whirlpool LSQ9010PG5 AUTOMATIC WASHER
Whirlpool LSQ9010PG6 AUTOMATIC WASHER
Whirlpool LSQ9010PW0 AUTOMATIC WASHER
Whirlpool LSQ9010PW1 AUTOMATIC WASHER
Whirlpool LSQ9010PW2 AUTOMATIC WASHER
Whirlpool LSQ9010PW3 AUTOMATIC WASHER
Whirlpool LSQ9010PW5 AUTOMATIC WASHER
Whirlpool LSQ9010PW6 AUTOMATIC WASHER
Whirlpool LSQ9030PQ0 AUTOMATIC WASHER
Whirlpool LSQ9030PQ1 AUTOMATIC WASHER
Whirlpool LSQ9030PQ2 AUTOMATIC WASHER
Whirlpool LSQ9030PQ4 AUTOMATIC WASHER
Whirlpool LSQ9030PQ5 AUTOMATIC WASHER
Whirlpool LSQ9110KQ0 WASHER
Whirlpool LSQ9110KQ1 WASHER
Whirlpool LSQ9110LG0 WASHER
Whirlpool LSQ9110LG1 AUTOMATIC WASHER
Whirlpool LSQ9110LW0 WASHER
Whirlpool LSQ9110LW1 AUTOMATIC WASHER
Whirlpool LSQ9110PW0 AUTOMATIC WASHER
Whirlpool LSQ9110PW1 AUTOMATIC WASHER
Whirlpool LSQ9110PW2 AUTOMATIC WASHER
Whirlpool LSQ9110PW3 AUTOMATIC WASHER
Whirlpool LSQ9110PW4 AUTOMATIC WASHER
Whirlpool LSQ9200KQ0 WASHER
Whirlpool LSQ9200KT0 WASHER
Whirlpool LSQ9200LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9200LQ1 AUTOMATIC WASHER
Whirlpool LSQ9200LQ2 AUTOMATIC WASHER
Whirlpool LSQ9200LQ3 AUTOMATIC WASHER
Whirlpool LSQ9200LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9200LT1 AUTOMATIC WASHER
Whirlpool LSQ9200LT2 AUTOMATIC WASHER
Whirlpool LSQ9200LT3 AUTOMATIC WASHER
Whirlpool LSQ9200PQ0 AUTOMATIC WASHER
Whirlpool LSQ9200PQ1 AUTOMATIC WASHER
Whirlpool LSQ9200PQ3 AUTOMATIC WASHER
Whirlpool LSQ9200PQ4 AUTOMATIC WASHER
Whirlpool LSQ9200PT0 AUTOMATIC WASHER
Whirlpool LSQ9200PT1 AUTOMATIC WASHER
Whirlpool LSQ9200PT3 AUTOMATIC WASHER
Whirlpool LSQ9200PT4 AUTOMATIC WASHER
Whirlpool LSQ9210HQ0 AUTOMATIC WASHER
Whirlpool LSQ9210HZ0 AUTOMATIC WASHER
Whirlpool LSQ9211KQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9244EQ0 AUTOMATIC WASHER
Whirlpool LSQ9244EZ0 AUTOMATIC WASHER
Whirlpool LSQ9264HQ0 AUTOMATIC WASHER
Whirlpool LSQ9264HZ0 AUTOMATIC WASHER
Whirlpool LSQ9500LQ0 WASHER
Whirlpool LSQ9500LT0 WASHER
Whirlpool LSQ9510JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9510LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9544KQ0 WASHER
Whirlpool LSQ9544KT0 WASHER
Whirlpool LSQ9549LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LG1 AUTOMATIC WASHER
Whirlpool LSQ9549LG2 AUTOMATIC WASHER
Whirlpool LSQ9549LG3 AUTOMATIC WASHER
Whirlpool LSQ9549LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LQ1 AUTOMATIC WASHER
Whirlpool LSQ9549LQ2 AUTOMATIC WASHER
Whirlpool LSQ9549LQ3 AUTOMATIC WASHER
Whirlpool LSQ9549LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LW1 AUTOMATIC WASHER
Whirlpool LSQ9549LW2 AUTOMATIC WASHER
Whirlpool LSQ9549LW3 AUTOMATIC WASHER
Whirlpool LSQ9549PG0 AUTOMATIC WASHER
Whirlpool LSQ9549PG1 AUTOMATIC WASHER
Whirlpool LSQ9549PG2 AUTOMATIC WASHER
Whirlpool LSQ9549PG3 AUTOMATIC WASHER
Whirlpool LSQ9549PG5 AUTOMATIC WASHER
Whirlpool LSQ9549PG6 AUTOMATIC WASHER
Whirlpool LSQ9549PW0 AUTOMATIC WASHER
Whirlpool LSQ9549PW1 AUTOMATIC WASHER
Whirlpool LSQ9549PW2 AUTOMATIC WASHER
Whirlpool LSQ9549PW3 AUTOMATIC WASHER
Whirlpool LSQ9549PW5 AUTOMATIC WASHER
Whirlpool LSQ9549PW6 AUTOMATIC WASHER
Whirlpool LSQ9550PW0 AUTOMATIC WASHER
Whirlpool LSQ9550PW1 AUTOMATIC WASHER
Whirlpool LSQ9550PW2 AUTOMATIC WASHER
Whirlpool LSQ9550PW3 AUTOMATIC WASHER
Whirlpool LSQ9550PW4 AUTOMATIC WASHER
Whirlpool LSQ9560PW0 AUTOMATIC WASHER
Whirlpool LSQ9560PW1 AUTOMATIC WASHER
Whirlpool LSQ9560PW2 Residential Washer
Whirlpool LSQ9560PW3 AUTOMATIC WASHER
Whirlpool LSQ9560PW4 AUTOMATIC WASHER
Whirlpool LSQ9564JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JZ0 AUTOMATIC WASHER, COMPACT A/W
  #2 (permalink)
Old 11-25-2012, 12:55 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Does it spin? If not, you probably have a bad motor to gearcase drive coupler. If it spins ok, then remove the agitator and observe the splined agitator shaft during agitation. Is it going back and forth? Can you stop it by grabbing it? If it's ok, look up into the bottom of the agitator and you'll probably find the plastic splines that mate with the splines on the shaft stripped out.
Eric
  #3 (permalink)
Old 11-25-2012, 02:53 PM
Junior Member
Default
fairbank 56 "Thank-You" for the response! No, it does NOT spin so, tomorrow I will take it apart and check the "coupler!" I'll let you know...OK! Jack
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whilpool washer won't work with clothes in it cabellabbott Washer Repair 1 12-21-2011 07:51 PM
Whilpool topload washer out of bal on spin tmkmill Washer Repair 4 05-15-2011 04:05 PM
Whilpool Gold Ultimate Care Washer mrsbeasleycharter Washer Repair 5 04-16-2011 06:03 AM
Whilpool Washer Jkruege Washer Repair 2 09-15-2009 06:48 PM
Whilpool washer leaks jdkiah Washer Repair 1 05-30-2009 06:34 PM
