| » Maytag: Won't spin during draining unless lid is opened and shut again |
Model Number: mvwc6esww1 Brand: Maytag Age: 1 - 5 years
My Maytag washer won't spin after the wash cycle while the machine is draining. If you lift the lid you can hear it kick into gear and then it will spin. Spins fine in spin cycle. Replaced the timer and still have the problem. Any ideas?
Maytag: Won't spin unless lid is opened and shut again Read more: Maytag: Won't spin unless lid is opened and shut again http://forum.appliancepartspros.com Ads By Google Related Models |
It's not supposed to spin during the initial drain period right after agitate mode. The gearcase has a neutral drain mechanism that prevents spinning during drain. After drain, the motor should pause for a few seconds, and then start again. The pause releases the neutral drain. At that point, it should spin and continue draining. By opening/closing the lid, you are simulating the pause to release neutral drain.
Eric |
| Display Modes | |
| Maytag: Won't spin unless lid is opened and shut again | Kinsbutt | Washer Repair | 2 | 10-25-2012 03:14 PM |
| Oven does not shut off when door opened | volenti38 | Microwave Repair | 0 | 09-07-2012 07:12 PM |
| will not spin and drain until lid is opened and shut | jimmyb1966 | Washer Repair | 15 | 03-27-2012 02:23 PM |
| Kenmore washer won't spin unless lid is opened and shut | PamMortensen | Washer Repair | 3 | 07-10-2010 10:51 AM |
| Dryer continues to spin when door is opened!! | badtothebone | Dryer Repair | 4 | 10-12-2009 11:39 AM |
