Discuss
washer issue
 in
Washer Repair
I have a Kenmore Washer, i turn it on it fills, but then nothing. Nothing happens, the timer doesn't move.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer issue
  #1 (permalink)
Old 11-22-2012, 02:05 PM
Junior Member
whalefam is on a distinguished road
Default washer issue
Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore Washer, i turn it on it fills, but then nothing. Nothing happens, the timer doesn't move. I have a full tub and niothing.
What do i need to repair ??
Ads By Google
  #2 (permalink)
Old 11-22-2012, 06:33 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
We need the model number.
  #3 (permalink)
Old 11-22-2012, 07:02 PM
Junior Member
Default
Kenmore top load. Series 80.
Model # 110.2382210
  #4 (permalink)
Old 11-22-2012, 07:21 PM
Expert
APP Volunteer
Default
Assume there is one more trailing zero on that number? Will it drain and spin if you advance the timer manually? If so, you may have a bad water level pressure switch and would need to test it with multimeter.
Eric
  #5 (permalink)
Old 11-23-2012, 05:37 AM
Junior Member
Default
Quote:
Eric
No it will not drain or spin when moving the timer. I turned the dial to mulitple settings and nothing happened. I siphoned the water out of the tub. Turned the dial to wash and it begin to fill, nothing else.
  #6 (permalink)
Old 11-23-2012, 01:45 PM
Expert
APP Volunteer
Default
Could just be a bad lid switch. Check the switch with multimeter or just jump it out to see if it will work. Can you post a clear picture of the wiring diagram? To test or jump out the lid switch, open the control panel. You'll see a 3-wire jack and plug on the top right side of the cabinet. Unplug the connector and jump together the white and gray wires of the plug you just pulled out. To check with meter, check across the two outside pins of the jack in the cabinet. With lid closed, it should read a short circuit (0 ohms).
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer control issue moveeguru@comcast.net Washer Repair 1 10-26-2012 06:50 PM
GE Washer Issue Ed Friend Washer Repair 0 08-09-2012 12:07 PM
LG washer issue PAULBELANGER1960@GMAIL.CO Washer Repair 0 05-01-2012 05:50 PM
Inglis washer issue... Quentin Washer Repair 1 09-26-2010 01:30 PM
calyspo washer issue rjeazmom Washer Repair 1 06-16-2009 04:29 AM
