Discuss
Help me diagnose problem
 in
Washer Repair
My washer wasn't spinning (but was agitating), and the general wisdom was a bad coupler. So I replaced the coupler
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Help me diagnose problem
  #1 (permalink)
Old 11-22-2012, 08:28 AM
Junior Member
twentw is on a distinguished road
Default Help me diagnose problem
Model Number: LSQ9560PW4   Brand: Whirlpool   Age: 1 - 5 years
My washer wasn't spinning (but was agitating), and the general wisdom was a bad coupler. So I replaced the coupler (the old one seemed to be in good condition), and I put it back together and started it up. At first it agitated fine, but I could hear it slowing down and after a minute or so it stopped agitating. And of course it does not spin. My next guess was the clutch (which I have ordered but not received yet), and I have already disassembled the washer. I have attached pictures, but you may not be able to tell anything from them.
My question is, does this sound like a clutch issue, or could it be something else (sticking brake shoes?).
Ads By Google
Related Models
Whirlpool LSQ9560PW4 Automatic Washer
Whirlpool LSQ9564JQ0
Whirlpool LSQ9564JQ1
Whirlpool LSQ9564JT0
Whirlpool LSQ9564JT1
Whirlpool LSQ9564JZ0
Whirlpool LSQ9564MQ0 Automatic Washer
Whirlpool LSQ9600JQ0
Whirlpool LSQ9600JQ1
Whirlpool LSQ9600JT0
Whirlpool LSQ9600JT1
Whirlpool LSQ9600LG0
Whirlpool LSQ9600LG1 Automatic Washer
Whirlpool LSQ9600LW0
Whirlpool LSQ9600LW1 Automatic Washer
Whirlpool LSQ9610JQ0
Whirlpool LSQ9610JQ1
Whirlpool LSQ9610JT0
Whirlpool LSQ9610JT1
Whirlpool LSQ9610LG0 Automatic Washer
Whirlpool LSQ9610LW0 Automatic Washer
Whirlpool LSQ9620LG0
Whirlpool LSQ9620LG1 Automatic Washer
Whirlpool LSQ9620LW0
Whirlpool LSQ9620LW1 Automatic Washer
Whirlpool LSQ9645KQ0
Whirlpool LSQ9645KQ1
Whirlpool LSQ9645KT0
Whirlpool LSQ9645KT1
Whirlpool LSQ9650PG0 Automatic Washer
Whirlpool LSQ9650PG1 Automatic Washer
Whirlpool LSQ9650PG2 Automatic Washer
Whirlpool LSQ9650PG3 Automatic Washer
Whirlpool LSQ9650PG4 Automatic Washer
Whirlpool LSQ9650PW0 Automatic Washer
Whirlpool LSQ9650PW1 Automatic Washer
Whirlpool LSQ9650PW2 Automatic Washer
Whirlpool LSQ9650PW3 Automatic Washer
Whirlpool LSQ9650PW4 Automatic Washer
Whirlpool LSQ9659LG0
Whirlpool LSQ9659LG1 Automatic Washer
Whirlpool LSQ9659LW0
Whirlpool LSQ9659LW1 Automatic Washer
Whirlpool LSQ9659PG0 Automatic Washer
Whirlpool LSQ9659PG1 Automatic Washer
Whirlpool LSQ9659PG2 Automatic Washer
Whirlpool LSQ9659PG3 Automatic Washer
Whirlpool LSQ9659PG4 Automatic Washer
Whirlpool LSQ9659PW0 Automatic Washer
Whirlpool LSQ9659PW1 Automatic Washer
Whirlpool LSQ9659PW2 Automatic Washer
Whirlpool LSQ9659PW3 Automatic Washer
Whirlpool LSQ9659PW4 Automatic Washer
Whirlpool LSQ9660PG0 Automatic Washer
Whirlpool LSQ9660PG1 Automatic Washer
Whirlpool LSQ9660PG2 Automatic Washer
Whirlpool LSQ9660PG3 Automatic Washer
Whirlpool LSQ9660PG4 Automatic Washer
Whirlpool LSQ9660PW0 Automatic Washer
Whirlpool LSQ9660PW1 Automatic Washer
Whirlpool LSQ9660PW2 Automatic Washer
Whirlpool LSQ9660PW3 Automatic Washer
Whirlpool LSQ9660PW4 Automatic Washer
Whirlpool LSQ9665JQ0
Whirlpool LSQ9665JQ1
Whirlpool LSQ9665JQ2
Whirlpool LSQ9665JQ3
Whirlpool LSQ9665JQ4
Whirlpool LSQ9665JT0
Whirlpool LSQ9665JT1
Whirlpool LSQ9665JT2
Whirlpool LSQ9665JT3
Whirlpool LSQ9665JT4
Whirlpool LSR4100HQ0
Whirlpool LSR4311DQ0
Whirlpool LSR5100HQ0
Whirlpool LSR5100KQ0
Whirlpool LSR5100LQ0
Whirlpool LSR5101LQ0
Whirlpool LSR5101LQ1 Automatic Washer
Whirlpool LSR5102LQ1 Automatic Washer
Whirlpool LSR5121HQ0
Whirlpool LSR5121JQ0
Whirlpool LSR5132AG0
Whirlpool LSR5132AN0
Whirlpool LSR5132AW0
Whirlpool LSR5132HQ0
Whirlpool LSR5132HQ1
Whirlpool LSR5132JQ0
Whirlpool LSR5132JQ2
Whirlpool LSR5132PQ0 Automatic Washer
Whirlpool LSR5132PQ1 Automatic Washer
Whirlpool LSR5132PQ3 Automatic Washer
Whirlpool LSR5132PQ4 Automatic Washer
Whirlpool LSR5232DW0
Whirlpool LSR5232LQ0
Whirlpool LSR5232LQ1 Automatic Washer
Whirlpool LSR5233AG0
Whirlpool LSR5233AN0
Whirlpool LSR5233AW0
Whirlpool LSR5233EQ0
Whirlpool LSR5233EQ1
Whirlpool LSR5233EQ2
Whirlpool LSR6132BN0
Whirlpool LSR6132BW0
Whirlpool LSR6132BW1
Whirlpool LSR6132DQ0
Whirlpool LSR6132DZ0
Whirlpool LSR6132EQ0
Whirlpool LSR6132EQ1
Whirlpool LSR6132EZ0
Whirlpool LSR6132EZ1
Whirlpool LSR6132HQ0
Whirlpool LSR6132HQ1
Whirlpool LSR6132HZ0
Whirlpool LSR6232JQ0
Whirlpool LSR6232JQ1
Whirlpool LSR6232JQ2 Automatic Washer
Whirlpool LSR6233BG0
Whirlpool LSR6233BN0
  #2 (permalink)
Old 11-22-2012, 06:28 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
The clutch and brake have nothing to do with agitate mode other than the brakes preventing the basket from rotating during agitation. Before the new problem of the motor slowing/stopping, did the washer drain ok? With the new problem, when the motor slows and stops, is it humming like it's trying to work?
Eric
  #3 (permalink)
Old 11-22-2012, 08:10 PM
Junior Member
Default
Yes, it drains fine. The motor appears to be working even when it is not agitating or spinning.
  #4 (permalink)
Old 11-23-2012, 05:16 AM
Expert
APP Volunteer
Default
So, in agitate mode, the agitator slows and stops but the motor is still running, not just stopped and humming? In agitate, with the pump off, you can see the motor shaft spinning? If this is the case, I would double check the coupler. With the motor off and half of the coupler still attached to the gearcase input shaft, you should be able to turn that input shaft CCW to cause agitation. Have someone observe the agitator while doing this (it will be slow of course). Turning the input shaft CW should make the basket spin.
Eric
  #5 (permalink)
Old 11-23-2012, 09:51 AM
Junior Member
Default
I took off the motor and found that my new coupler was broken - the plastic part had detached from the metal center ring on the gearcase input shaft. I still have the original which appears to be fine.
I'm not sure what I'm looking for when I turn the gearcase input shaft. Turning it CCW makes the spindle turn one direction, and turning it CW makes the spindle turn the other direction. The basket is not turning.
  #6 (permalink)
Old 11-23-2012, 01:34 PM
Expert
APP Volunteer
Default
When you turn it clockwise, the clutch hub should rotate. If it isn't, you have a gearcases problem. Is everything still apart or is it all back together?
Eric
  #7 (permalink)
Old 11-23-2012, 02:31 PM
Junior Member
Default
OK, just so I'm clear on what you're asking, I've posted a photo. I'm turning the three prong coupler part CW, and the clutch hub (the round silver thing) is supposed to move? When I first started moving it, the clutch hub was not moving. After about 20 turns, it started to move, and now moves all the time that I'm turning it CW, except that on occasion it appears to bind up making it difficult to turn the coupler. I can get past that point and then it turns normally. Turning the coupler CCW rotates the spindle back and forth in what I assume is a normal agitation movement.
  #8 (permalink)
Old 11-23-2012, 04:28 PM
Expert
APP Volunteer
Default
Sounds good except for the binding part. There's a large gear ratio between the input pinion gear and the main drive gear in the gearcase so it's a bit hard to simulate actual operation because the motor obviously spins much faster than just turning by hand. One thing to keep in mind is that the gearcase has a neutral drain mechanism. In normal operation, this mechanism is set during the first few seconds of the agitate mode. When the motor reverses for spin mode the neutral drain is engaged after a few seconds which prevents spin while draining. After drain, the motor pauses for a few seconds which releases the mechanism. Then the motor starts again which causes drain and spin. I would put it all back together and go directly to spin mode while watching the clutch hub. If it isn't spinning, open the lid to stop the motor for a couple seconds and then close it again to restart spin. If the hub still isn't spinning then the gearcase is bad or the coupler has broken again. If it is spinning and the basket is not, then the clutch is likely slipping and needs replaced. Another cause of the clutch hub spinning but basket not, is a bad drive block which can be partially inspected with the agitator removed.
Eric
  #9 (permalink)
Old 11-23-2012, 05:32 PM
Junior Member
Default
I received the new clutch today, so I went ahead and installed it and put it all back together. Everything seems to work fine now. I don't know whether the problem was actually the clutch but at least it's fixed. I really appreciate your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
diagnose dryer problem DonnaB1653 Dryer Repair 3 03-26-2012 04:08 PM
How to diagnose problem damnstove Oven Repair (including Ranges and Cooktops) 0 02-15-2012 07:54 PM
Need Help Diagnose the problem active1 Refrigerator & Freezer Repair 1 09-19-2010 08:33 PM
Help me diagnose the problem TotalRecall Refrigerator & Freezer Repair 7 01-19-2010 09:34 AM
Diagnose problem and how to fix it. ernest Washer Repair 0 06-24-2008 12:26 PM
