| » Washer fills but won't agitate |
Model Number: Lsc6244aw0 Brand: Whirlpool Age: More than 10 years
Help please...
I have a whirlpool direct drive washing machine that will fill, but not begin agitation cycle. When I turn the knob to rinse or spin, nothing happens either. The motor, water pump, and motor coupling are new. When you remove the pump and manually rotate the motor shaft, it moves freely in both directions. When everything is hooked up, you can hear a humming noise when you pull knob out to begin a cycle. I removed the motor to watch it function outside the machine. The shaft does not turn and you can hear the humming noise. Is the timer bad? Any suggestions? Ads By Google Related Models |
Is it the motor humming or the timer? If motor, with it sitting on the floor, try spinning it by hand as fast as you can when it's humming. If it doesn't start, closely inspect the terminals at the motor connection for corrosion, burning or signs of overheating. Also inspect the connections at the timer. Can you provide an image of the wiring diagram? In most older Whirlpool models, the lid switch would only effect drain/spin mode but can't be sure without seeing the diagram.
Eric |
The motor is humming. I tried spinning it by hand and it did not start. I looked at the connection terminal and there appears to be a slight bit of corrosion on 3 of connections. I have attached a photo. The timer connections look fine. I have attached the wiring diagram. You are correct that the lid switch controls drain and spin only. The washer has always agitated with the lid open. I don't think the switch is the issue. What about the capacitor?
Connector picture isn't very clear but even so, I can see the corrosion. I assume the contacts inside the motor switch receptacle are bright and shiney since this is a new motor. Why was the motor replaced? Did the machine work ok after replacing the motor? The corrosion can definitely cause this problem. The capacitor is only used for starting the motor. If the motor was getting full voltage via the blue and white wires, you should be able to start it manually. The pins can be removed from the plastic plug for possible cleaning depending how bad it is. I't also possible moisture has wicked up into the wire and damaged it. The problem can also be caused by bad contacts in the timer. At this point, you really need to take some voltage measurements at the motor connector while it's plugged in and humming.
Eric |
Well, the difference between agitate and spin as far as the motor is concerned, is direction of rotation. This really has nothing to do with the motor itself as direction is determined by polarity of power applied to the start winding relative to run winding polarity, which is determined by the timer. If you have a multimeter, I can advise how to check voltages at the motor connector.
Eric |
Try to be quick about taking these measurments, it's not good for the motor to leave it humming like that. During agitate or spin mode check for 120 volts AC across the blue and white wires as well as across the red and yellow wires. Anything between 110vac and 125vac is good.
Eric |
Well, that didn't go so well. Tried twice to get a voltage reading. The red light on top of multimeter came on but the digital display jumped all over the place never settling on a reading. Probably user error, but did not want to try a third time for fear of damaging motor.
| Display Modes | |
| Washer fills but won't agitate | pansie | Washer Repair | 5 | 02-09-2012 05:37 PM |
| Washer fills, does not run through cycle or agitate. | sammbard | Washer Repair | 0 | 07-19-2010 04:46 AM |
| washer fills but no agitate | rkweld | Washer Repair | 3 | 08-11-2009 08:32 PM |
| washer fills but won't agitate | jamesamc | Washer Repair | 1 | 07-24-2007 02:42 PM |
