Discuss
washer just drains
 in
Washer Repair
my washer won't stop trying to drain. I cancelled the load, it drained and cotinued to drain even though it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer just drains
  #1 (permalink)
Old 11-19-2012, 09:28 PM
Junior Member
joseph 24 is on a distinguished road
Default washer just drains
Model Number: 21102011   Brand: Kenmore   Age: 1 - 5 years
my washer won't stop trying to drain. I cancelled the load, it drained and cotinued to drain even though it is empty.
Ads By Google
Related Models
Jenn-Air 21136 WALLOVEN- S/C ELE
Jenn-Air 21137 WALLOVEN- S/C ELE
Jenn-Air 21138 ELECTRIC WALL OVEN
Amana 212-2J ROOM AIR CONDITIONER
Amana 212-2J-1 ROOM AIR CONDITIONER
Amana 212-2JM ROOM AIR CONDITIONER
Amana 212-2SP ROOM AIR CONDITIONER
Amana 212-2SPF ROOM AIR CONDITIONER
Amana 212-2SPG ROOM AIR CONDITIONER
Amana 212-3J ROOM AIR CONDITIONER
Amana 212-3J-1 ROOM AIR CONDITIONER
Amana 212-3SP ROOM AIR CONDITIONER
Amana 212-3SPG ROOM AIR CONDITIONER
Hoover 2120
Hoover 2120-01
Jenn-Air 21238 WALLOVEN- S/C ELE
Jenn-Air 21239 WALLOVEN- S/C ELE
Roper 2126*0A Ranges, Electric*
Roper 2126X0A Ranges, Electric*
Frigidaire 2129A GAS RANGE
Frigidaire 2129B GAS RANGE
Frigidaire 2129C GAS RANGE
Amana 212D-3J ROOM AIR CONDITIONER
Amana 212D-3JH ROOM AIR CONDITIONER
Amana 212D-3JM ROOM AIR CONDITIONER
Amana 213-3B ROOM AIR CONDITIONER
Amana 213-3BH ROOM AIR CONDITIONER
Amana 213-3E ROOM AIR CONDITIONER
Amana 213-3F ROOM AIR CONDITIONER
Amana 213-3G ROOM AIR CONDITIONER
Amana 213-5B ROOM AIR CONDITIONER
Amana 213-5BH ROOM AIR CONDITIONER
Amana 213-5J ROOM AIR CONDITIONER
Amana 213-5JH ROOM AIR CONDITIONER
Amana 213-5SP ROOM AIR CONDITIONER
Amana 213-5SPF ROOM AIR CONDITIONER
Amana 213-5SPFH ROOM AIR CONDITIONER
Amana 213-5SPG ROOM AIR CONDITIONER
Amana 213-5SPGH ROOM AIR CONDITIONER
Amana 213-5SPH ROOM AIR CONDITIONER
Jenn-Air 21336 WALLOVEN- S/C MWAVE ELE
Roper 2136*0A Ranges, Electric*
Roper 2136X0A Ranges, Electric*
Amana 213D-3C ROOM AIR CONDITIONER
Amana 213D-3CH ROOM AIR CONDITIONER
Roper 2141*0E Ranges, Electric*
Roper 2141*1E Ranges, Electric*
Roper 2141W0E Ranges, Electric*
Roper 2141W1E Ranges, Electric*
Roper 2142*0E Ranges, Electric*
Roper 2142*1E Ranges, Electric*
Roper 2142W0E Ranges, Electric*
Roper 2142W1E Ranges, Electric*
Roper 2143*0F Ranges, Electric*
Roper 2143W0F Ranges, Electric*
Roper 2144*0F Ranges, Electric*
Roper 2144W0E Ranges, Electric*
Roper 2144W0F Ranges, Electric*
Hoover 215
Amana 215-3D ROOM AIR CONDITIONER
Amana 215-3DH ROOM AIR CONDITIONER
Amana 215-3EW ROOM AIR CONDITIONER
Amana 215-3F ROOM AIR CONDITIONER
Amana 215-3G ROOM AIR CONDITIONER
Amana 215-3J ROOM AIR CONDITIONER
Amana 215-3J-1 ROOM AIR CONDITIONER
Amana 215-3JH ROOM AIR CONDITIONER
Amana 215-3JM ROOM AIR CONDITIONER
Amana 215-3K ROOM AIR CONDITIONER
Amana 215-3N ROOM AIR CONDITIONER
Amana 215-3NE ROOM AIR CONDITIONER
Amana 215-3NH ROOM AIR CONDITIONER
Amana 215-3SP ROOM AIR CONDITIONER
Amana 215-3SPF ROOM AIR CONDITIONER
Amana 215-3SPFH ROOM AIR CONDITIONER
Amana 215-3SPG ROOM AIR CONDITIONER
Amana 215-3SPGH ROOM AIR CONDITIONER
Amana 215-3W ROOM AIR CONDITIONER
Amana 215-5J ROOM AIR CONDITIONER
Amana 215-5N ROOM AIR CONDITIONER
Amana 215-5SP ROOM AIR CONDITIONER
Amana 215-5SPF ROOM AIR CONDITIONER
Amana 215-5SPG ROOM AIR CONDITIONER
Amana 215-5SPG-1 ROOM AIR CONDITIONER
Roper 2155188 Ice Maker Kits
Amana 2155K ROOM AIR CONDITIONER
Amana 2155N ROOM AIR CONDITIONER
Amana 215D-3HW ROOM AIR CONDITIONER
Amana 215D-3J ROOM AIR CONDITIONER
Amana 215D-3JH ROOM AIR CONDITIONER
Amana 215D-3JM ROOM AIR CONDITIONER
Amana 216-3B ROOM AIR CONDITIONER
Amana 216-3BH ROOM AIR CONDITIONER
Amana 216-5B-2 ROOM AIR CONDITIONER
Amana 216-5BH-2 ROOM AIR CONDITIONER
Roper 2176*0A Ranges, Electric*
Roper 2176W0A Ranges, Electric*
Amana 218-3D ROOM AIR CONDITIONER
Amana 218-3EW ROOM AIR CONDITIONER
Amana 218-3EWS ROOM AIR CONDITIONER
Amana 218-3F ROOM AIR CONDITIONER
Amana 218-3G ROOM AIR CONDITIONER
  #2 (permalink)
Old 11-20-2012, 06:13 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
So, the drain pump motor is running continuously?
Eric
  #3 (permalink)
Old 11-24-2012, 12:42 AM
Junior Member
Default
yes even though there is no water in it. i tried unplugging it but when i plug it back in it just starts up again.
  #4 (permalink)
Old 11-24-2012, 12:45 AM
Junior Member
Default
Quote:
Eric
yes it does
  #5 (permalink)
Old 11-24-2012, 06:50 AM
Expert
APP Volunteer
Default
The pump comes on as soon as you start the machine? I'd say you have a bad MCU (main control unit). The pump is driven directly by relay in the MCU based on timing and the status of the pressure switch which is an integral part of the MCU. You could try pulling the clear plastic hose off the back of the MCU to see if that stops the pump. There is a diagnostic mode on this machine to check for error codes and a calibrate function but I don't have the exact procedure for your specific model. I have a procedure for a similar model that has 7 indicator lamps but I believe your model only has 6.
Eric
  #6 (permalink)
Old 11-25-2012, 01:39 PM
Junior Member
Default
I tried pulling the hose off and plugged it back in and that seemed to work. I don't know if that was it or if it reset itself after being unplugged for 5 days. Either way thanks for the help.
  #7 (permalink)
Old 11-25-2012, 02:27 PM
Expert
APP Volunteer
Default
If pulling the hose was the cure, you may have a gunked up air dome or clogged hose at the air dome on the side of the outer tub.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer only spins and drains jperrot Washer Repair 3 05-07-2012 03:05 PM
Washer drains sometimes tculpepper Washer Repair 1 08-16-2010 12:34 PM
Washer only drains jianming Washer Repair 1 02-17-2010 09:13 AM
Washer drains up Goliathishere Washer Repair 12 10-05-2009 06:12 AM
Washer drains but won't spin KAP Washer Repair 3 11-09-2007 11:59 AM
