| » Fault code F09 |
Model Number: GHW9100LW1 Brand: Whirlpool Age: 5 - 10 years
Replaced inlet valve on back of machine for hot and cold water, replaced drain pump and black ball and bottom tub hose. Just started using machine again, and it is fine but then the 09 code appears, and have to reset to start again, upon starting again, it dumps the softener into the machine and then finishes washing.
Checked the drain hose, good, drain pump filter, clean(and brand new), supply hoses, no kinks, what else could it be? help, Jim Ads By Google Related Models |
| Display Modes | |
| fault code | crowderp | Washer Repair | 0 | 09-13-2012 01:58 PM |
| fault code F5 E3 | cgo | Oven Repair (including Ranges and Cooktops) | 0 | 08-21-2011 10:34 AM |
| Fault Code F- | BorisLetus | Oven Repair (including Ranges and Cooktops) | 1 | 07-08-2011 11:06 AM |
| f50 fault code | Mrhaneync | Washer Repair | 1 | 06-17-2010 09:00 PM |
| 5ab fault code | jalexkerr | Oven Repair (including Ranges and Cooktops) | 1 | 04-16-2010 12:26 PM |
