Discuss
No cold water for wash cycle, but there is cold water on the rinse cycle
 in
Washer Repair
There's no cold water on the wash cycle, but on the rinse cycle there is plenty of cold water. I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » No cold water for wash cycle, but there is cold water on the rinse cycle
  #1 (permalink)
Old 11-18-2012, 04:30 PM
Junior Member
Cois Tine is on a distinguished road
Default No cold water for wash cycle, but there is cold water on the rinse cycle
Model Number: GLTF1040ASo   Brand: Frigidaire   Age: More than 10 years
There's no cold water on the wash cycle, but on the rinse cycle there is plenty of cold water. I just replaced the intake valve, but that didn't solve the problem. I'd appreciate any suggestions on what to try next. Thanks.
(This is a Frigidaire Galaxy front-loader).
Ads By Google
Related Models
Frigidaire GLTF1240AS0 Frtld Washer - Frig Gallery
Frigidaire GLTF1570ES0 Frigidaire/washer
Frigidaire GLTF1570ES1 Frigidaire/washer
Frigidaire GLTF1570FS0 Frigidaire/washer
Frigidaire GLTF1570FS1 WASHER
Frigidaire GLTF1570FS2 WASHER
Frigidaire GLTF1570FS3 WASHER
Frigidaire GLTF1670AS0 Frtld Wshr - Frigidaire Gal
Frigidaire GLTF1670AS1 Frigidaire/washer
Frigidaire GLTF2070CS0 Frigidaire/washer
Frigidaire GLTF2070DS0 Frigidaire/washer
Frigidaire GLTF2940EE0 Frigidaire/washer
Frigidaire GLTF2940ES0 Frigidaire/washer
Frigidaire GLTF2940ES1 Frigidaire/washer
Frigidaire GLTF2940ES2 Frigidaire/washer
Frigidaire GLTF2940ES3 Frigidaire/washer
Frigidaire GLTF2940FA2 WASHER
Frigidaire GLTF2940FE0 Frigidaire/washer
Frigidaire GLTF2940FE1 WASHER
Frigidaire GLTF2940FE2 WASHER
Frigidaire GLTF2940FS0 Frigidaire/washer
Frigidaire GLTF2940FS1 WASHER
Frigidaire GLTF2940FS2 WASHER
Frigidaire GLTF530DS0 Frigidaire/washer
Frigidaire GLTF530DS1 Frigidaire/washer
Frigidaire GLTR1670AS0 Frtld Wshr - Frigidaire Gallery
Frigidaire GLTR1670AS1 Frigidaire/washer
Frigidaire GLTR1670FS0 WASHER
Frigidaire GLTR1670FS1 WASHER
General Electric GLWN5050M0WS WASHER
General Electric GLWP2000M0WW WASHER
General Electric GLWP2000M1WW WASHER
Frigidaire GLWS1233AQ1 Washer - Frig Gallery
Frigidaire GLWS1233AQ2 Frigidaire/washer
Frigidaire GLWS1233AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1233AS1 Washer - Gallery
Frigidaire GLWS1233AS2 Frigidaire/washer
Frigidaire GLWS1233AS3 Frigidaire/washer
Frigidaire GLWS1339CC0 Frigidaire/washer
Frigidaire GLWS1339CS0 Frigidaire/washer
Frigidaire GLWS1339CS1 Frigidaire/washer
Frigidaire GLWS1339EC0 Frigidaire/washer
Frigidaire GLWS1339EC1 Frigidaire/washer
Frigidaire GLWS1339ES0 Frigidaire/washer
Frigidaire GLWS1339ES1 Frigidaire/washer
Frigidaire GLWS1349AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1349AS1 Washer - Frig Gallery
Frigidaire GLWS1439FC0 WASHER
Frigidaire GLWS1439FC1 WASHER
Frigidaire GLWS1439FC2 WASHER
Frigidaire GLWS1439FS0 WASHER
Frigidaire GLWS1439FS1 WASHER
Frigidaire GLWS1439FS2 WASHER
Frigidaire GLWS1649AS0 Washer - Frig Gallery
Frigidaire GLWS1649AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS2 Frigidaire/washer
Frigidaire GLWS1649AS4 Frigidaire/washer
Frigidaire GLWS1749AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1749AS2 Washer - Frig Gallery
Frigidaire GLWS1749AS4 Frigidaire/washer
Frigidaire GLWS1749AS5 Frigidaire/washer
Frigidaire GLWS1749FS0 WASHER
Frigidaire GLWS1749FS1 WASHER
Frigidaire GLWS1749FS2 WASHER
Frigidaire GLWS1939AS0 Frigidaire/washer
Frigidaire GLWS1939AS1 Frigidaire/washer
Frigidaire GLWS1979AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1979AS2 Washer - Frig Gallery
Frigidaire GLWS1979AS3 Frigidaire/washer
Frigidaire GLWY1343AS0 Frigidaire/washer
Frigidaire GLWY1343AS1 Frigidaire/washer
Gaggenau GM104-710
Gaggenau GM104-714
Admiral GM1110PRW RANGE- F/S STD GAS
Gaggenau GM215-721
Gaggenau GM215-760
Gaggenau GM215-761
Gaggenau GM286-710
Gaggenau GM286-720
Gaggenau GM286-760
Gaggenau GM288-710
Gaggenau GM288-714
Admiral GM3110MPAW RANGE- F/S STD GAS
Admiral GM3110MXAW RANGE- F/S STD GAS
Admiral GM3110PRAM RANGE- F/S STD GAS
Admiral GM3110PRWM RANGE- F/S STD GAS
Admiral GM31113WAM RANGE- F/S STD GAS
Admiral GM31113WAV RANGE- F/S STD GAS
Admiral GM3111GXAW RANGE- F/S STD GAS
Admiral GM3111SXAW RANGE- F/S STD GAS
Admiral GM31211XAW RANGE- F/S STD GAS
Admiral GM3167WUA RANGE- F/S STD GAS
Admiral GM3167WUV RANGE- F/S STD GAS
Admiral GM3210MXAW RANGE-F/S CONT CLEAN GAS
Admiral GM3211GXAA RANGE-F/S CONT CLEAN GAS
Admiral GM3211GXAW RANGE-F/S CONT CLEAN GAS
Admiral GM3211SXAA RANGE-F/S CONT CLEAN GAS
Admiral GM3211SXAW RANGE-F/S CONT CLEAN GAS
Admiral GM3216WRWM RANGE-F/S CONT CLEAN GAS
Admiral GM32211XAW RANGE-F/S CONT CLEAN GAS
Admiral GM3267WUAM RANGE-F/S CONT CLEAN GAS
Admiral GM3267WUWM RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUA RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUAM RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUW RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUWM RANGE-F/S CONT CLEAN GAS
Gaggenau GM335-760
Maytag GM3468XUW-X RANGE- S/C F/S GAS
Admiral GM3510PRW RANGE- F/S STD ELE
Admiral GM3531WUV RANGE- S/C F/S ELE
Admiral GM3531WUW RANGE- S/C F/S ELE
Admiral GM3631XUA RANGE- F/S STD ELE
Admiral GM3631XUW RANGE- F/S STD ELE
Admiral GM3862XUW RANGE- S/C F/S ELE
Admiral GM3868XUA RANGE- S/C F/S ELE
Admiral GM3868XUW RANGE- S/C F/S ELE
Maytag GM4151WTA RANGE- F/S STD GAS
Maytag GM4151WTW RANGE- F/S STD GAS
Maytag GM4251WTA RANGE-F/S CONT CLEAN GAS
Maytag GM4251WTW RANGE-F/S CONT CLEAN GAS
  #2 (permalink)
Old 11-21-2012, 05:31 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Since the intake valve opens for the rinse cycle this would seem to be a problem with the temp selection switch or the control unit. You will probably have to try changing both to see which one is the problem, but if you buy the parts from this site you can return the one you don't need.
__________________
  #3 (permalink)
Old 11-22-2012, 01:38 PM
Junior Member
Default
Thanks so much for your help, Sid. I'm new to this, so I hope you'll pardon the following dumb questions:
1. The temp selection switch -- That's the part labeled '13' on the control panel chart, right? (part #1483044 / AP4365631 / mfg 134904500)
2. Nothing comes back when I search for 'control unit', and I don't find it on the diagrams. Does it go by another name? Do you happen to have a part number for it?
  #4 (permalink)
Old 11-22-2012, 04:52 PM
Senior Expert
APP Volunteer
Default
The control unit is the timer, this part here
Part number: AP5184476
Good luck
__________________
  #5 (permalink)
Old 11-29-2012, 11:27 AM
Junior Member
Default Temperature switch and receptacle burned out.
Thanks, the problem was the temperature switch. It looks like one of the prongs shorted out and melted part of the white plastic wiring receptacle the switch plugs into.
I don't see that white receptacle in the parts diagram. Is it available?
How hard is it to replace that white receptacle?
Thanx again.
  #6 (permalink)
Old 11-29-2012, 05:21 PM
Senior Expert
APP Volunteer
Default
Not have that model in front of me I don't know if the receptacle is replaceable, and it probably is not.
If you are even slightly handy with wiring I would wire it direct using either wire nuts or a crimp connector.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Machine stops during rinse cycle, and cold water comes in very slowly Lloydster18 Washer Repair 2 09-04-2012 12:19 AM
My washer fills so slowly with cold water & stops before rinse cycle JennH Washer Repair 6 07-29-2012 10:20 AM
Front load washer, no cold water on wash cycle only David62 Washer Repair 1 01-23-2011 11:29 AM
No cold water and no rinse cycle jhead Dishwasher Repair 1 02-22-2010 08:03 AM
no cold water on cold/cold cycle rpbmd Washer Repair 1 08-28-2009 10:04 AM
