Discuss
GE washer overflow problem
 in
Washer Repair
I have a ten year old GE washer that is starting to overflow occasionally when it fills. It doesn't do
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer overflow problem
  #1 (permalink)
Old 11-18-2012, 10:59 AM
Junior Member
Doug Lassiter is on a distinguished road
Default GE washer overflow problem
Brand: GE   Age: 5 - 10 years
I have a ten year old GE washer that is starting to overflow occasionally when it fills. It doesn't do it all the time. In fact, although it often threatens to overfill on the first fill cycle, it usually doesn't threaten to overfill on the rinse cycle. I understand about the level pressure sensor, and the tube that connects it to the pressure dome. That tube seems to be clear and doesn't look like it's damaged, and blowing gently into the pressure sensor through that tube, I can hear the "click" of the pressure sensor. So should that suggest that the pressure sensor is working OK?
Actually, as an overflow is starting to happen, with load size set to "large", I quickly switch the load size to "small", and the fill stops. So at some level, the sensor is working.
What I'm trying to assess right now is whether I need to replace the pressure sensor ($25), or if there might be something else wrong I should check out first. I really don't want to replace that sensor, and keep having the same problem!
Advice appreciated.
Ads By Google
  #2 (permalink)
Old 11-18-2012, 01:22 PM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Since the problem is intermittent all you can do is replace the pressure switch and cross your fingers.
I would blow into the tube but in the tub direction.
Could be that there is a ball/mass of crud down there that partially plugs the tube once is a while. This would be a long shot.
__________________
  #3 (permalink)
Old 11-18-2012, 01:31 PM
Junior Member
Default
Thanks. The tube is clean between the pressure sensor and the dome. If I blow the tube in the plug direction, I'm just blowing into the dome. The dome (a little plastic box affixed to the side of the tub) isn't removable, and the walls of it are pretty opaque. So I have no idea what's going on in there. Perhaps it's full of crud. How do I check on that?
But you're right, it looks like I have to replace the pressure switch.
That being said, there is what looks like a small brass adjustment screw sticking out of the switch. Is that what I have to adjust to get the "full" level set on the new one? Can I assume that the switch, as bought, will already be set pretty close to how I need it to be set?
  #4 (permalink)
Old 11-19-2012, 01:06 AM
Senior Expert
APP Volunteer
Default
You have to pull the inner tub out which is a real pain. I would replace the pressure switch first.
It will be preset.
The tubing length is important as that effects the pressures but if the tubing is brittle etc. I would replace it. If the end that attaches to the pressure switch is stretched so it will not fit tightly on the new switch cut off about half an inch of it so it seats tightly.
__________________
  #5 (permalink)
Old 11-19-2012, 11:16 AM
Junior Member
Default
Great advice. Thank you. Will do. Looks like I can get a level sensor online for $20. The tube is actually in pretty good shape, so I'll just leave it be. Good point that the length of that tube is important. I hadn't though of that!
  #6 (permalink)
Old 11-23-2012, 07:48 AM
Junior Member
Default
OK, I figured it out. It was a bit trickier. Just a bit.
When you get an overflow, the first thing you think of is the pressure sensor. BUT, the thing to check first is the valves. That's what I should have done. Really trivial (which is why you should do that check first).
Start the fill cycle on WARM, so it's pulling both hot and cold water into the tank, and pull the plug. Pull the plug repeatedly. I just ran the line through an extension plug strip with switch. That made it easy to kill the power. If the fill stops every time you kill the power, your valves are OK. If the fill rate slows down suddenly, but doesn't stop when you pull the plug, you have a valve problem in one valve, and that's most likely what's making the overfill. In fact, that's what's most likely to happen if you have a valve problem, because it's very unlikely that both valves will fail together.
The valves should snap shut when power is killed.
That's what I did and, it appears my cold water valve is shot. What was confusing was that the fill stopped most of the time when I pulled the plug. But not all the time. That's not good enough! The fill has to stop EVERY SINGLE TIME you kill the power.
Now, having done this, you can check the pressure sensor as well by just blowing into it while it's filling. If that makes the flow rate decrease or stop, it's working. If the flow rate just decreases but doesn't stop, it's because one valve was bad. The pressure sensor feeds BOTH valves, so it it's working with one, it's OK. If blowing into the pressure sensor has NO EFFECT on the fill rate, and especially if you don't hear the clicks from the pressure sensor switch when you do, then the pressure sensor is bad.
Oh, by the way, after doing this check of the pressure valve, empty the tank completely before you reconnect the pressure valve hose. If you reconnect it when the tank is full, your next load is guaranteed to overflow, because there is no pressure in it.
All this being said, I went to the web and found my valve. I am stunned at the range of prices. I can get one for $16 (including shipping) from one source, and I see prices of $40-50 at other sources. These are all alleged to be factory replacements. What's the catch?
  #7 (permalink)
Old 11-23-2012, 02:13 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
If you had told us that it was continuing to fill after starting agitation, we could have told you the water valve was bad.
Eric
  #8 (permalink)
Old 11-23-2012, 02:40 PM
Junior Member
Default
Actually, it wasn't that easy. The valve was flaky. Either after power cycling, or by itself after a few seconds, it would turn off. Once it went off, my agitation went fine, and the tub didn't flood. I never really had to close the knob on the house plumbing. If it was a situation where the valve always stayed open after the power went off, it would have been simple. It actually wasn't completely clear how long it should take for the valve to shut off. So when the valve shut off after a few seconds, I found myself saying "Well, OK." Of course, in retrospect, it should be immediate.
This is probably the most important lesson here. A valve may be flaky, and not behave reliably. Of course, it HAS to behave reliably. So all it takes is to see a valve failure once. That's a pointer that the valve needs to be replaced. If it "sorta" works, that won't cut it.
  #9 (permalink)
Old 11-23-2012, 04:04 PM
Expert
APP Volunteer
Default
Well, it is that simple. It was only overfilling after agitation started, which you didn't convey to us. Once agitation starts, there is no longer power to the water inlet valves. If it did overflow at any time before agitation started, then there is something wrong with the water level system.
After re-reading your original post, it appears that it was overfilling before agitation at one point.
Quote:
"Actually, as an overflow is starting to happen, with load size set to "large", I quickly switch the load size to "small", and the fill stops."
This indicates a problem with the water level system or control module if this is an electronic control washer. You never did give us the model number.
Eric
  #10 (permalink)
Old 11-23-2012, 05:38 PM
Junior Member
Default
Read more: http://forum.appliancepartspros.com/...xzz2D 6Dm1yc2
http://forum.appliancepartspros.com I never said it was overflowing after agitation started. In fact, I had the top open until the flow had stopped, because I didn't want to risk an overflow. With the top open, it won't agitate. Of course I don't know exactly where the timer was on enabling the agitation.
I never said it was only overfilling after agitation started. In fact, I kept the top open until the flow ceased, specifically to avoid an overfill. If the top is open, it isn't going to agitate. As a result, I had no idea if the timer had reached the point that it was commanding agitation. I didn't close the top until the valve managed to close itself, whether my waiting an extra few seconds, or by power cycling.
"If it did overflow at any time before agitation started, then there is something wrong with the water level system."
I don't get that. If the valve is stuck open during the fill cycle, it can easily overflow before agitation is commanded to start. If the timer tells the agitation to start, and kills the power on the valves, a stuck-open valve is going to stay open.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need Help with Washer Overflow WetChick Washer Repair 1 05-23-2012 07:55 AM
washer overflow burl830 Washer Repair 1 12-17-2011 03:28 PM
Washer keeps filling to overflow nzdw22 Washer Repair 1 02-11-2011 10:42 AM
Washer overflow nightglow1 Washer Repair 2 01-13-2010 01:36 PM
washer overflow R Creation Washer Repair 2 08-13-2009 02:10 PM
