| » kenmore 80 series fills with water but wont agitate,spin,or drain |
Model Number: 23822100 Brand: Kenmore Age: 5 - 10 years
I have a Kenmore 80 series washer that all of a sudden fills with water but won't do anything after that the Nov moves and sort of hums that whole cycle but nothing is happening after it will please help
Hi.
So correct me if I'm wrong. The washer fills up with water and nothing happens at all? If that is right you need to check the water level switch. Contacts V - T should have continuity with the tub full of water.If no continuity - install the jumper wire if you can between those two wires. Washer should start agitating. In that case - replace the water level switch Part number: W10335056 Check the lid switch. Disconnect the lid switch plug inside the control panel and with lid closed you should have continuity between two outside contacts. No continuity - replace the switch Part number: 3949238 Use the video clip for instructions. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Washer fills, wont agitate, spin, or drain... | WeCanDoit | Washer Repair | 2 | 05-23-2011 10:29 AM |
| Kenmore 70 series washer wont agitate, spin, or drain | xiuzhiwu | Washer Repair | 1 | 07-18-2010 12:59 PM |
| washer kenmore 80 series top loader fills with water wont drain agitate or spin out | dwills | Washer Repair | 0 | 05-27-2010 09:24 PM |
| Kenmore 90 Series - NO spin, agitate, or drain | americanautomobile | Washer Repair | 1 | 08-23-2009 10:00 AM |
| kenmore washer 70 series wont spin and drain water | foster13019 | Washer Repair | 1 | 12-20-2008 01:05 PM |
