Discuss
Washer won't agitate or spin, can turn motor by hand
 in
Washer Repair
The washer won't won't agitate or spin. I've checked the pump, that seems OK (no visible clogs, and I can
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't agitate or spin, can turn motor by hand
  #1 (permalink)
Old 11-14-2012, 06:49 AM
Junior Member
englaisfitz is on a distinguished road
Default Washer won't agitate or spin, can turn motor by hand
Model Number: RAX4232JQ0   Brand: Roper   Age: 5 - 10 years
The washer won't won't agitate or spin. I've checked the pump, that seems OK (no visible clogs, and I can turn it by hand). I've checked the coupler, no signs of wear. I bypassed the timer switch and checked the motor, this hums but won't start, unless I turn it by hand, then it will kick in and continue the motion.
One suggestion was a bad motor capacitor, but I've checked that using a multimeter, and the range starts high, but then dwindles to almost zero, which is what it's supposed to do, right?
Another suggestion is a bad clutch. Is there any way I can check for this?
Or are there any other suggestions you may have as to the cause of the problem?
Many thanks guys!
Mark
Ads By Google
Related Models
Whirlpool RAX4232JQ0
Whirlpool RAX4232KQ0
Whirlpool RAX4232KQ1 Automatic Washer
Whirlpool RAX4232PQ0 Automatic Washer
Whirlpool RAX4232PQ1 Automatic Washer
Whirlpool RAX4232RQ0 Automatic Washer
Whirlpool RAX4232RQ1 Automatic Washer
Whirlpool RAX4232RQ3 Automatic Washer
Whirlpool RAX4232RQ4 Automatic Washer
Whirlpool RAX4233PQ0 Automatic Washer
Maytag RAX5000AXB Misc / Accessory
Maytag RAX5000CXB Misc / Accessory
Maytag RAX5100AXB Misc / Accessory
Whirlpool RAX5133AG0
Whirlpool RAX5133AL0
Whirlpool RAX5133AL1
Whirlpool RAX5133AW0
Whirlpool RAX5133AW1
Maytag RAX5200AXB Misc / Accessory
Maytag RAX5200CXB Misc / Accessory
Maytag RAX5300AXB Misc / Accessory
Maytag RAX5400AXB Misc / Accessory
Maytag RAX5500AXB Misc / Accessory
Maytag RAX5500CXB Misc / Accessory
Maytag RAX5600AXB Misc / Accessory
Maytag RAX5700AXB Misc / Accessory
Maytag RAX5700CXB Misc / Accessory
Whirlpool RAX6144EN0
Whirlpool RAX6144EN1
Whirlpool RAX6144EQ0
Whirlpool RAX6144EQ1
Whirlpool RAX6144EW0
Whirlpool RAX6144EW1
Whirlpool RAX7244EN0
Whirlpool RAX7244EN1
Whirlpool RAX7244EQ0
Whirlpool RAX7244EQ1
Whirlpool RAX7244EW0
Whirlpool RAX7244EW1
Whirlpool RAX7244JQ0
Whirlpool RAX7244KQ0
Whirlpool RAX7244KQ1 Automatic Washer
Whirlpool RAX7244KQ2 Automatic Washer
Whirlpool RAX7244PQ0 Automatic Washer
Whirlpool RAX7244PQ1 Automatic Washer
Whirlpool RAX7245AG0
Whirlpool RAX7245AL0
Whirlpool RAX7245AW0
Whirlpool RAX7245BL0
Whirlpool RAX7245BL1
Whirlpool RAX7245BQ1
Whirlpool RAX7245BW0
Whirlpool RAX7245BW1
Whirlpool RAX7245JQ0
Whirlpool RAX7245KQ0
Whirlpool RAX7245KQ1 Automatic Washer
Whirlpool RB1000XKW0
Whirlpool RB1000XKW1
Whirlpool RB1000XKW2
Whirlpool RB1000XVN0
Whirlpool RB1000XVN2
Whirlpool RB1000XVN3
Whirlpool RB1000XVW0
Whirlpool RB1000XVW2
Whirlpool RB1000XVW3
Whirlpool RB1005XYN0
Whirlpool RB1005XYN2
Whirlpool RB1005XYN3
Whirlpool RB1005XYN5
Whirlpool RB1005XYW0
Whirlpool RB1005XYW2
Whirlpool RB1005XYW3
Whirlpool RB1005XYW5
Whirlpool RB100PXK0
Whirlpool RB100PXK1
Whirlpool RB100PXK2
Whirlpool RB100PXV0
Whirlpool RB100PXV2
Whirlpool RB100PXV3
Whirlpool RB100PXYB0
Whirlpool RB100PXYB2
Whirlpool RB100PXYB3
Whirlpool RB100PXYB5
Whirlpool RB1200XKW0
Whirlpool RB1200XKW1
Whirlpool RB1200XKW2
Whirlpool RB1200XVN0
Whirlpool RB1200XVN2
Whirlpool RB1200XVW0
Whirlpool RB1200XVW2
Whirlpool RB120PXK0
Whirlpool RB120PXK1
Whirlpool RB120PXK2
Whirlpool RB120PXV0
Whirlpool RB120PXV1
Whirlpool RB120PXV2
Whirlpool RB120PXV3
Whirlpool RB120PXYB0
Whirlpool RB120PXYB2
Whirlpool RB120PXYB3
Whirlpool RB120PXYB5
Whirlpool RB1300XKW0
Whirlpool RB1300XKW1
Frigidaire RB130FA0 Frg(v5) / Electric Range
Frigidaire RB130FF0 Frg(v4) / Electric Range
Frigidaire RB130FH0 Frg(v6) / Electric Range
Frigidaire RB130FL0 Frg(v3) / Electric Range
Frigidaire RB130FM0 Frg(v2) / Electric Range
Frigidaire RB130FW0 Frg(v1) / Electric Range
Whirlpool RB130PXK0
Whirlpool RB130PXK1
Whirlpool RB130PXK2
Whirlpool RB130PXK3
Whirlpool RB130PXV0
Whirlpool RB130PXV1
Whirlpool RB130PXV3
Whirlpool RB130PXV4
Frigidaire RB131CA0 Frg(v1) / Electric Cooktop
Frigidaire RB131CA1 Frg(v1) / Built - in Electric Cooktop
Frigidaire RB131CF0 Frg(v2) / Electric Cooktop
  #2 (permalink)
Old 11-14-2012, 06:58 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Does it drain?
  #3 (permalink)
Old 11-14-2012, 08:51 AM
Junior Member
Default
It doesn't get that far, the motor hums for about half a minute, then the system shuts off.
  #4 (permalink)
Old 11-15-2012, 11:43 AM
Expert
APP Volunteer
Default
So, your saying with the motor on the floor, connected and everything else hooked up (timer), it will run if you start it by hand?
If your comfortable checking live 120vac with your multimeter, I can advise you further. Need to check for power at the motor harness connector.
You can check continuity of the motor windings and motor switch first. Check with connector unplugged. On the motor, you should have continuity between the terminals where the white and blue wires as well as between where the red and yellow wires connect. You should also have continuity between where the white wire connects and the violet wire coming out of the motor. These should read just a few ohms resistance. Then check from where the blue wire connects and the blue wire coming out of the motor, between where the red wire connects and the black wire coming out of the motor and between where the orange wire connects and the blue wire from the motor. These should be 0-.5 ohms. If these are all good, need to check for 120vac with the motor plugged in and running (or attempted running).
Eric
  #5 (permalink)
Old 11-18-2012, 10:30 PM
Junior Member
Default Washer won't agitate or spin...
Yes, that's exactly what I'm saying, with the motor on the floor, hooked up, even WITHOUT the timer (another guy gave me a way to bypass the timer, making a power cord with multiple connectors so we can simulate the cycles of the machine when the motor was in place, i.e. one direction spins the drum, the other direction moves the agitator post). So just power going into the motor, it hums, and waits for me to start it by hand, but will then continue.
-- When It does start (and stop, when I turn off the power), there is a reasonably loud click sound, like a switch activating.
Just to confirm, I'm checking wire locations ON THE MOTOR itself, where the harness plugs in, right, so I can remove the motor completely, set it aside from the washer, and check the wire connections with the multimeter, right? I'm not checking the harness end that is attached to the washer, I'm checking the motor terminals.
Results:
White to Blue = 1.1 ohms
Red to Yellow = 7.3 ohms
White to Violet = There is no violet wire
Blue in to Blue out = 0 ohms
Red in to Black out = 0.1 ohms
Orange in to Blue out = There is no orange wire
Haven't checked with power on yet, as I wasn't able to complete what you asked thus far.
I really appreciate your help with this Eric, it seems to have stumped every other website I've been to. One guy said it was the capacitor, but when I checked that, the reading started high, then dwindled away to almost zero, which is what it's meant to do, right? Another guy suggested the clutch, but when I checked this by starting the motor by hand (installed), it functioned normally for both agitation and spin operations. I dropped the clutch down, there's no leakage of oil, and everything looks clean and new inside.
Should I repeat the above wire connectivity tests with the power on?
Now when you say "comfortable", what, exactly, should I not be comfortable about...
And can I do it using the bypass harness, so we're checking just the motor, or should I wire it back up to the washer to check?
Many thanks!
Mark
  #6 (permalink)
Old 11-19-2012, 06:30 AM
Expert
APP Volunteer
Default
I thought this was a 2-speed motor. 5 wires coming from motor is a single speed. Anyway, the readings are good although the start winding is on the high end of a 4-7ohms normal reading. I assume with your power cord setup, you are still using the capacitor in the circuit? The click you hear is the switch. The part on the motor that the wires are plugged into is a switch operated by a centrifugal mechanism inside the motor on the shaft. It opens contacts for the start winding when it gets up to speed as the start winding is not meant for continuous use. It also operates other contacts in a multi-speed motor.
The capacitor test you did is just a static test. It will tell you if it is shorted. The reading you get when the resistance starts out low and gradually comes up indicates it is not shorted and the capacitor is charging up but it is just a static test using low DC voltage from the meter. In operation the capacitor has 120vac across it. The static test doesn't give you the value of the capacitor either so the capacitor could still be bad. The capacitor provides a phase shift in the current applied between the run and start windings to produce a rotating magnetic field to get the motor going.
Testing the resistance of the switch contacts is also a static test using low dc voltage. It could read fine but break down when high current is passed through them. One other test you can do will bypass the start winding cutout switch. With your test setup, instead of connecting to where the red wire normally goes, disconnect the black wire from the motor and connect there. You'll need to make an adapter jumper wire. If the motor starts this way, turn it off right away as this bypasses the switch and you should not leave power applied to the start winding but for a second or two. If it still doesn't work, I would try another capacitor.
BTW, you can buy a suitable capacitor from Grainger for $6.31 Physical size may be slightly different so you may have to modify the mounting.
Eric
  #7 (permalink)
Old 11-20-2012, 03:37 PM
Junior Member
Default
Thanks Eric.
I hooked up the motor as you suggested, and it fired up immediately as I plugged it into the wall. Does this mean the capacitor is good (as I already ordered one from Grainger, thanks for that little bit of info! Talk about going the extra mile!)?
What's the next step, Sir?
Many thanks,
Mark
  #8 (permalink)
Old 11-20-2012, 04:08 PM
Expert
APP Volunteer
Default
Yes, capacitor is good. Bad motor switch. The switch is replaceable but I'm not sure which motor you have. The parts manual shows it as part number 661600 which is a 2-speed motor. The switch for that motor is part number 8529896. Can you provide a good clear photo of the wiring diagram on the tech sheet located behind the control panel or possibly somewhere inside the cabinet?
Eric
  #9 (permalink)
Old 11-22-2012, 11:55 AM
Junior Member
Default
Alas, there is no tech sheet or wiring diagram anywhere on the machine, nothing on the case, nothing anywhere near the controls, nor on the body itself. I can take a photo of the existing switch, so you can see where the wires are located...
I also found a manual parts list, showing the part number for the motor switch as 62850
Whirlpool Repair Part List - 8179518-007 - YouserGuide
Which seems to pass me to the same part number you list.
Thanks again, Eric, I'll take that photo and hopefully this will solve the whole problem.
Cheers,
Mark
  #10 (permalink)
Old 11-24-2012, 05:30 PM
Junior Member
Default
Here is the photo of the motor switch
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Won't Agitate or Spin - Motor Runs jsolo53 Washer Repair 2 11-21-2011 07:20 PM
Motor Hums But Washer Will Not Agitate Or Spin john@ljolson.com Washer Repair 1 10-24-2011 06:03 PM
GE washer won't spin or agitate. Motor? Mode shifter? kzinti83 Washer Repair 1 09-13-2011 07:00 PM
Maytag Dependble - No Spin/Drain, Motr Hums - Belt Cn Be Rotatd by Hand 2 Start Motor bluestreak Washer Repair 12 12-06-2008 01:53 AM
Washer motor hums, but won't drain, agitate or spin redwood646 Washer Repair 2 09-11-2007 07:39 PM
