Discuss
Washer won't agitate or spin, can turn motor by hand
 in
Washer Repair
Hi I have exactly the same problem as you. I do not understand how you performed the test which lead
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't agitate or spin, can turn motor by hand
  #21 (permalink)
Old 07-26-2013, 01:05 PM
Junior Member
dzuloaga is on a distinguished road
Default
Hi I have exactly the same problem as you. I do not understand how you performed the test which lead you to the faulty switch. Do I have to disconnect the black cable from the motor and connect there the red cable coming from the capacitor?
  #22 (permalink)
Old 10-14-2014, 11:43 AM
Junior Member
Ccajk2 is on a distinguished road
Default Resolution?
Did you ever get this resolved? I have the same issue.
  #23 (permalink)
Old 11-14-2014, 08:35 AM
Junior Member
irishfan327 is on a distinguished road
Default
washer won't agitate or spin and buzzing sound and found a 2 inch metal pin with hole in the end and flat on 1 side..
  #24 (permalink)
Old 11-14-2014, 08:41 AM
Junior Member
Post
Quote:
hi where is my answer please
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer won't spin or agitate. Motor? Mode shifter? kzinti83 Washer Repair 2 09-01-2013 03:14 PM
Washer Won't Agitate or Spin - Motor Runs jsolo53 Washer Repair 2 11-21-2011 08:20 PM
Motor Hums But Washer Will Not Agitate Or Spin john@ljolson.com Washer Repair 1 10-24-2011 07:03 PM
Maytag Dependble - No Spin/Drain, Motr Hums - Belt Cn Be Rotatd by Hand 2 Start Motor bluestreak Washer Repair 12 12-06-2008 02:53 AM
Washer motor hums, but won't drain, agitate or spin redwood646 Washer Repair 2 09-11-2007 08:39 PM
