Discuss
hammering and intermittent water discharge during wash cycle from discharge pump
 in
Washer Repair
Once washer fills to proper level and wash cycle begins, there is a loud hammer and jerk of discharge hose
Appliance Repair Forum > Appliance Repair Help > Washer Repair » hammering and intermittent water discharge during wash cycle from discharge pump
  #1 (permalink)
Old 11-14-2012, 06:19 AM
Junior Member
kmichael is on a distinguished road
Default hammering and intermittent water discharge during wash cycle from discharge pump
Model Number: LA7680XM   Brand: Whirlpool   Age: More than 10 years
Once washer fills to proper level and wash cycle begins, there is a loud hammer and jerk of discharge hose as water is released for 1-2 seconds, then water stops discharging, then five seconds or so later it happens again. It continues to do this throughout wash cycle if I were to let it run. if I turn selector knob to drain position, it drains no problem. This only happens during wash cycle. Any help is greatly appreciated.
Ads By Google
Related Models
Whirlpool LA7680XMW0
Whirlpool LA7680XPW0
Whirlpool LA7680XPW1
Whirlpool LA7680XPW2
Whirlpool LA7680XSW0
Whirlpool LA7680XSW1
Whirlpool LA7680XTF0
Whirlpool LA7680XTF1
Whirlpool LA7680XTG0
Whirlpool LA7680XTG1
Whirlpool LA7680XTM0
Whirlpool LA7680XTM1
Whirlpool LA7680XTN0
Whirlpool LA7680XTN1
Whirlpool LA7680XTW0
Whirlpool LA7680XTW1
Whirlpool LA7681XSW0
Whirlpool LA7681XSW1
Whirlpool LA7685XKW0
Whirlpool LA7685XKW1
Whirlpool LA7685XMW0
Whirlpool LA7685XPW0
Whirlpool LA7685XPW1
Whirlpool LA7685XPW2
Whirlpool LA7700XPW0
Whirlpool LA7700XPW1
Whirlpool LA7700XPW3
Whirlpool LA7700XPW4
Whirlpool LA7700XPW5
Whirlpool LA7700XSW0
Whirlpool LA7700XWN0
Whirlpool LA7700XWW0
Whirlpool LA7780XSW0
Whirlpool LA7780XSW1
Whirlpool LA7780XSW2
Maytag LA7800 Washer - Top Loading
Whirlpool LA7800XKW0
Whirlpool LA7800XKW1
Whirlpool LA7800XKW2
Whirlpool LA7800XMW0
Whirlpool LA7800XPW0
Whirlpool LA7800XPW1
Whirlpool LA7800XSW0
Whirlpool LA7800XSW1
Whirlpool LA7800XSW2
Whirlpool LA7800XTF0
Whirlpool LA7800XTF1
Whirlpool LA7800XTG0
Whirlpool LA7800XTG1
Whirlpool LA7800XTM0
Whirlpool LA7800XTM1
Whirlpool LA7800XTN0
Whirlpool LA7800XTN1
Whirlpool LA7800XTW0
Whirlpool LA7800XTW1
Whirlpool LA7801XTF0
Whirlpool LA7801XTG0
Whirlpool LA7801XTM0
Whirlpool LA7801XTN0
Whirlpool LA7801XTW0
Whirlpool LA7805XKW0
Whirlpool LA7805XKW1
Whirlpool LA7899XPW3
Whirlpool LA7900XPW1
Whirlpool LA7900XSW0
Whirlpool LA7900XSW1
Whirlpool LA7900XSW2
Whirlpool LA7900XTF0
Whirlpool LA7900XTG0
Whirlpool LA7900XTG1
Whirlpool LA7900XTM0
Whirlpool LA7900XTN0
Whirlpool LA7900XTN1
Whirlpool LA7900XTW0
Whirlpool LA7900XTW1
Whirlpool LA7980XSW0
Frigidaire LA800AXD1 Wwh(v2) / 27 " Washer
Frigidaire LA800AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA800AXW1 Wwh(v1) / 27 " Washer
Frigidaire LA800AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA800JXD4 Wwh(v1) / Washer
Frigidaire LA800JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA800JXF4 Wwh(v2) / Washer
Frigidaire LA800JXH4 Wwh(v3) / Washer
Frigidaire LA800JXH5 Wwh(v2) / Top Load Washer
Frigidaire LA800JXV4 Wwh(v4) / Washer
Frigidaire LA800JXW4 Wwh(v5) / Washer
Frigidaire LA800JXW5 Wwh(v3) / Top Load Washer
Frigidaire LA800MXD1 Wwh(v9) / 27 " Washer
Frigidaire LA800MXD2 Wwh(v9) / 27 " Washer
Frigidaire LA800MXH1 Wwh(v8) / 27 " Washer
Frigidaire LA800MXH2 Wwh(v8) / 27 " Washer
Frigidaire LA800MXW1 Wwh(v7) / 27 " Washer
Frigidaire LA800MXW2 Wwh(v7) / 27 " Washer
Maytag LA806 Washer - Top Loading
Maytag LA806S Washer - Top Loading
Maytag LA810 Washer - Top Loading
Maytag LA8100 Washer - Top Loading
Whirlpool LA8100XWW0
Whirlpool LA8100XWW1
Maytag LA8120 Washer - Top Loading
Maytag LA8140 Washer - Top Loading
Maytag LA8200 Washer - Top Loading
Whirlpool LA8200XWW0
Whirlpool LA8200XWW1
Maytag LA8210 Washer - Top Loading
Maytag LA8240 Washer - Top Loading
Maytag LA8340 Washer - Top Loading
Amana LA83830.A Mwave - Family Size (60 Hz)
Whirlpool LA8400XWF0
Whirlpool LA8400XWF1
Whirlpool LA8400XWG0
Whirlpool LA8400XWG1
Whirlpool LA8400XWM0
Whirlpool LA8400XWM1
Whirlpool LA8400XWN0
Whirlpool LA8400XWN1
Whirlpool LA8400XWW0
Whirlpool LA8400XWW1
Maytag LA8420 Washer - Top Loading
  #2 (permalink)
Old 11-14-2012, 04:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad timer. Unfortunately this part is no longer available. Looks like it's time for a new washer.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-14-2012, 04:50 PM
Junior Member
Default Thanks so much for the reply.
I know its laughable I am trying to save this washer, but it is a secondary washer in basement and its like an old war horse, stable as can be. I hate to chuck it. So I'm guessing the timer is sending signal to open or close pump contacts? I am an electrician and saw no feed for pump on schematic. Thanks for your imput, let me know if timer regulates this for sure, otherwise it will have to be time for it to go. They dont build them like this anymore, everything is solid and no electronic controls, I would love to save it. Thanks again
  #4 (permalink)
Old 11-14-2012, 10:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Pull the washer out of the wall and remove the access panel on the back of the washer. You will see the part which calls "solenoid wig-wag" (#9 at the diagram). This part operates by the timer and turns the pump on and off. Run the washer and watch the wig-wag. Post the results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
noisy discharge pump stavros Dishwasher Repair 1 03-08-2012 02:34 PM
LG discharge pump motor mneuwirth Washer Repair 0 08-20-2011 01:40 PM
replacing discharge pump basssoul Washer Repair 1 05-01-2011 12:01 PM
Discharge pump McFadden Dishwasher Repair 2 03-21-2009 06:00 PM
Need to know how discharge pump is designed niddings Washer Repair 0 05-31-2008 09:01 AM
