Discuss
Q re Speed Queen/Amana DA3211 Washer repair
 in
Washer Repair
Top loading Washing Machine: Speed Queen DA3211 I rarely find info pertaining to a Speed Queen DA3211 but do for
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Q re Speed Queen/Amana DA3211 Washer repair
  #1 (permalink)
Old 11-13-2012, 01:13 AM
Junior Member
ActionClaw is on a distinguished road
Default Q re Speed Queen/Amana DA3211 Washer repair
Model Number: DA3211   Brand: Speed Queen   Age: More than 10 years
I rarely find info pertaining to a Speed Queen DA3211 but do for Amana DA3211. My understanding is that Maytag, Amana, Speed Queen are made by the same manufacturer and also, based on an owners manual I found for the Amana DA3211, I'll assume they are the same.
[ul][li]Can anyone direct me to where a service/repair manual for an Amana/Speed Queen DA3211 might be available?
[li]My current problem is that it (sometimes does but) doesn't always drain properly. Haven't yet found any particular pattern. It seems to fill with rinse water though the wash water hasn't drained which, then, with the extra weight creates a vicious circle of not be able to spin up to speed sufficient to drain, etc..
I figured the first thing to do is check and, if necessary, clear the outlet hose, the hose leading to the pump or the pump itself. What is the best way to remove the hoses from the pump? The hose clamp location seems rather inaccessible. Is it suggested to first remove the pump in order to gain access to the attached hoses with the pump off? If so, what is the correct way to remove the pump?[/li]
[li]Also, how tight should the pump drive belt be? As is, I can, with thumb and finger, easily pinch together to touch each other. I havent yet seen a way to way to increase belt tension.[/li][/ul]
Thanks for any help
Related Models
Amana DA3211 WASHER-TOP LOADING
Amana DA3500 WASHER-TOP LOADING
Amana DA3501 WASHER-TOP LOADING
Amana DA3660 WASHER-TOP LOADING
Amana DA3661 WASHER-TOP LOADING
Amana DA3690 WASHER-TOP LOADING
Amana DA3691 WASHER-TOP LOADING
Amana DA3780 WASHER-TOP LOADING
Amana DA3781 WASHER-TOP LOADING
Amana DA3820 WASHER-TOP LOADING
Amana DA3821 WASHER-TOP LOADING
Amana DA6070 WASHER-TOP LOADING
Amana DA6071 WASHER-TOP LOADING
Amana DA6073 WASHER-TOP LOADING
Amana DA6100 WASHER-TOP LOADING
Amana DA6101 WASHER-TOP LOADING
Amana DA6111 WASHER-TOP LOADING
Amana DA6120 WASHER-TOP LOADING
Amana DA6121 WASHER-TOP LOADING
Amana DA6123 WASHER-TOP LOADING
Amana DA6191 WASHER-TOP LOADING
Amana DA6200 WASHER-TOP LOADING
Amana DA6201 WASHER-TOP LOADING
Amana DA6220 WASHER-TOP LOADING
Amana DA6221 WASHER-TOP LOADING
Amana DA6223 WASHER-TOP LOADING
Amana DA6250 WASHER-TOP LOADING
Amana DA6251 WASHER-TOP LOADING
Amana DA9000 WASHER-TOP LOADING
Amana DA9011 WASHER-TOP LOADING
Amana DA9041 WASHER-TOP LOADING
Amana DA9043 WASHER-TOP LOADING
Amana DA9101 WASHER-TOP LOADING
Amana DA9103 WASHER-TOP LOADING
Frigidaire DAFW3577KW0 WASHER
Frigidaire DAFW3577KW1 WASHER
Frigidaire DAQE7077KW0 ELECTRIC DRYER
Frigidaire DAQG7077KW0 GAS DRYER
Admiral DAV1200AWW WASHER-TOP LOADING
Admiral DAV2240AWA WASHER-TOP LOADING
Admiral DAV2240AWW WASHER-TOP LOADING
Frigidaire DB100PD1 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire DB100PW1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB110PW1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB120P1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB200PW1 Frg(v1) / 24 " Built - in Dishwasher
Amana DB2221N WASHER-TOP LOADING
 DB3710DB DISHWASHER- UNDERCOUNTER
 DB3710DW DISHWASHER- UNDERCOUNTER
Frigidaire DB400A1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB400PW1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB418PW1 Frg(v1) / 18 " Built - in Dishwasher
Frigidaire DB418PW2 Frg(v1) / 18 " Built - in Dishwasher
 DB5710DT DISHWASHER- UNDERCOUNTER
Frigidaire DB664RBR0 Wwh(v0) / 24 " Built - in Dishwasher
Frigidaire DB700AW1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB700P1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB700P1-00 Tap(v7) / 24 " Built - in Dishwasher
Frigidaire DB700P1-23 Tap(v8) / 24 " Built - in Dishwasher
Frigidaire DB700PD1 Wwh(v4) / 24 " Built - in Dishwasher
Frigidaire DB700PL1 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire DB700PW1 Frg(v1) / 24 " Built - in Dishwasher
Amana DB7111N WASHER-TOP LOADING
Amana DB7221N WASHER-TOP LOADING
Amana DB8181N WASHER-TOP LOADING
Amana DB8201N WASHER-TOP LOADING
General Electric DBB3300EA0AA Electric dryer
General Electric DBB3300EA0WW Electric dryer
General Electric DBB3300EA1AA Electric dryer
General Electric DBB3300EA1WW Electric dryer
General Electric DBB3300GA0AA Gas dryer
General Electric DBB3300GA0WW Gas dryer
General Electric DBB3300GA1AA Gas dryer
General Electric DBB3300GA1WW Gas dryer
General Electric DBB3300GA2AA Gas dryer
General Electric DBB3300GA2WW Gas dryer
General Electric DBB5000EF0GG Electric dryer
General Electric DBB5000GF0GG Gas dryer
General Electric DBB5000GF1GG Gas dryer
General Electric DBL333EA0AA Electric dryer
General Electric DBL333EA0CC Electric dryer
General Electric DBL333EA0WW Electric dryer
General Electric DBL333EA1CC Electric dryer
General Electric DBL333EA1WW Electric dryer
General Electric DBL333EB0CC Electric dryer
General Electric DBL333EB0WW Electric dryer
General Electric DBL333EB1CC Electric dryer
General Electric DBL333EB1WW Electric dryer
General Electric DBL333EB3CC Electric dryer
General Electric DBL333EB3WW Electric dryer
General Electric DBL333EB4CC Electric dryer
General Electric DBL333EB4WW Electric dryer
General Electric DBL333EB6CC Electric dryer
General Electric DBL333EB6WW Electric dryer
General Electric DBL333EY0AA Electric dryer
General Electric DBL333EY0WW Electric dryer
General Electric DBL333GA0AA Gas dryer
General Electric DBL333GA0CC Gas dryer
General Electric DBL333GA0WW Gas dryer
General Electric DBL333GA1CC Gas dryer
General Electric DBL333GA1WW Gas dryer
General Electric DBL333GB0CC Gas dryer
General Electric DBL333GB0WW Gas dryer
General Electric DBL333GB1CC Gas dryer
General Electric DBL333GB1WW Gas dryer
General Electric DBL333GB4CC Gas dryer
General Electric DBL333GB4WW Gas dryer
General Electric DBL333GB5CC Gas dryer
General Electric DBL333GB5WW Gas dryer
General Electric DBL333GB6CC Gas dryer
General Electric DBL333GB6WW Gas dryer
General Electric DBL333GB8CC Gas dryer
General Electric DBL333GB8WW Gas dryer
General Electric DBL333GY0AA Gas dryer
General Electric DBL333GY0WW Gas dryer
General Electric DBLR333EE0CC Electric dryer
General Electric DBLR333EE0WW Electric dryer
General Electric DBLR333EE1CC Electric dryer
General Electric DBLR333EE1WW Electric dryer
General Electric DBLR333EE2CC Electric dryer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Speed Queen dryer repair Bill Seelhammer Dryer Repair 2 01-28-2012 07:11 AM
Fix Amana/Speed Queen or replace? JoelR Washer Repair 1 04-29-2011 05:55 AM
i need the speed queen (amana) washer schematic motor wiring hemigreg Washer Repair 0 03-24-2010 12:24 PM
Amana Speed Queen Washer tonee74 Washer Repair 1 04-14-2009 03:28 PM
Speed Queen/Amana not pumping out Roj Washer Repair 0 03-29-2009 10:01 PM
