Maytag Neptune Washer - No Spin Cycle
Model Number: MAH4000AWW Brand: Maytag Age: More than 10 years
Ok, I just received this free washer from my friend because he couldn't get the spin to work, and I have had some issues. Basically, instead of beginning the spin cycle, the machine oscillates back and forth (as in the 'wash' cycle) for several minutes before stopping movement altogether and just humming (the humming is coming from the pump). Here's what I've done/checked so far:
1. Wax motor didn't work, R11 was blown. I replaced the wax motor, R11 and Q6 triac. Wax motor now works great and engages both limit switches.
2. I looked over the motor control board and noticed no problems (fuse was clean with continuity and there were no burn marks on the usual board places
3. I have checked a few of the main control board voltages
a. P5 (neutral) to P2, wire 4 (orange, out-of-balance) reads 25VDC
b. P5 (neutral) to P3, wire 7 (yellow, spin-enable) reads 25VDC
This makes me believe that the out-of-balance is fine and the spin-enable limit switch doesn't need replacing.
Now, here are a few other thoughts/concerns I've had:
1. This testing has all been done with a completely empty washer that is disconnected from the water supply. I took it apart and rigged something so I could trick it into thinking the door is closed so I can watch the door lock mechanism and the interior during these tests (like I said, door lock mechanism working fine). However, it still "sounds" like there is water in it, sloshing around while it spins. I'm not sure if this is counterweight water that is sealed. I considered that the pump was clogged but jiggled some of the tubes around the pump and felt no water inside. Is there internal water in the tub as a counterweight?
2. I saw on a forum to disconnect the P4 connection at the motor controller board (accessed from the front) to test if the motor controller is busted. However, I can't seem to find the P4 at the motor controller board. I know about the P4 at the main control board...I disconnected that and plugged in the washer. I engaged my "door close" and pushed on and it did its usual stalling, no 50rpm or anything. If that's the right test (could you re-describe it to me, as well?) then that may prove it's the motor controller. Otherwise let me know.
3. Probably doesn't matter, but the light bulb on the door (next to the lock mechanism) is missing. I will replace it if I get other things to work, and figure that's meaningless information but wanted to share it anyway.
Any suggestions for more things to check? Your help is greatly appreciated!
Keith
Ads By Google
Related ModelsMaytag MAH4000AWW WASHER- HORIZONTAL AXIS Maytag MAH4000BWQ WASHER- HORIZONTAL AXIS Maytag MAH4000BWW WASHER- HORIZONTAL AXIS Maytag MAH5500AWQ WASHER- HORIZONTAL AXIS Maytag MAH5500AWW WASHER- HORIZONTAL AXIS Maytag MAH5500BWQ WASHER- HORIZONTAL AXIS Maytag MAH5500BWW WASHER- HORIZONTAL AXIS Maytag MAH55FLBWQ WASHER- HORIZONTAL AXIS Maytag MAH55FLBWW WASHER- HORIZONTAL AXIS Maytag MAH6500AWQ WASHER- HORIZONTAL AXIS Maytag MAH6500AWW WASHER- HORIZONTAL AXIS Maytag MAH6700AWM WASHER- HORIZONTAL AXIS Maytag MAH6700AWW WASHER- HORIZONTAL AXIS Maytag MAH7500AWQ WASHER- HORIZONTAL AXIS Maytag MAH7500AWW WASHER- HORIZONTAL AXIS Admiral MAH7550AAW WASHER- HORIZONTAL AXIS Admiral MAH7550AGW WASHER- HORIZONTAL AXIS Maytag MAH8700AWM WASHER- HORIZONTAL AXIS Maytag MAH8700AWW WASHER- HORIZONTAL AXIS Maytag MAH9700AWM WASHER- HORIZONTAL AXIS Maytag MAH9700AWQ WASHER- HORIZONTAL AXIS Maytag MAH9700AWW WASHER- HORIZONTAL AXIS Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner Maytag MAL1800AXM MISC / ACCESSORY Maytag MAL1800AXQ MISC / ACCESSORY Maytag MAL1800AXW MISC / ACCESSORY Maytag MAL2000AXQ MISC / ACCESSORY Maytag MAL2000AXW MISC / ACCESSORY Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner Maytag MAT10CSAAL MANUAL, PARTS (WASHER) Maytag MAT10CSAAW MANUAL, PARTS (WASHER) Maytag MAT10CSAGL MANUAL, PARTS (WASHER) Maytag MAT10CSAGW MANUAL, PARTS (WASHER) Maytag MAT10CSEGL MANUAL, PARTS (WASHER) Maytag MAT10CSEGW MANUAL, PARTS (WASHER) Maytag MAT10DAAAL MANUAL, PARTS (WASHER) Maytag MAT10DAAAW MANUAL, PARTS (WASHER) Maytag MAT10DAABL MANUAL, PARTS (WASHER) Maytag MAT10DAABW MANUAL, PARTS (WASHER) Maytag MAT10PDAAL MANUAL, PARTS (WASHER) Maytag MAT10PDAAW MANUAL, PARTS (WASHER) Maytag MAT10PDABL MANUAL, PARTS (WASHER) Maytag MAT10PDABW MANUAL, PARTS (WASHER) Maytag MAT10PDEGW MAYTAG LAUNDRY (COMM.EXPORT) (WASHER) Maytag MAT10PSAAL MANUAL, PARTS (WASHER) Maytag MAT10PSAAW MANUAL, PARTS (WASHER) Maytag MAT10PSAGL MANUAL, PARTS (WASHER) Maytag MAT10PSAGW MANUAL, PARTS (WASHER) Maytag MAT11CSBKL MANUAL, PARTS (WASHER) Maytag MAT11MNAAW MANUAL, PARTS (WASHER) Maytag MAT11MNAGW MANUAL, PARTS (WASHER) Maytag MAT11MNEGW MANUAL, PARTS (WASHER) Maytag MAT11PDAAL MAYTAG LAUNDRY (WASHER) Maytag MAT11PDAAW MAYTAG LAUNDRY (WASHER) Maytag MAT11PDABL MAYTAG LAUNDRY (WASHER) Maytag MAT11PDABW MAYTAG LAUNDRY (WASHER) Maytag MAT12CSAAL MANUAL, PARTS (WASHER) Maytag MAT12CSAAQ MANUAL, PARTS (WASHER) Maytag MAT12CSAAW MANUAL, PARTS (WASHER) Maytag MAT12CSAGW MANUAL, PARTS (WASHER) Maytag MAT12CSAKL MANUAL, PARTS (WASHER) Maytag MAT12CSAKQ MANUAL, PARTS (WASHER) Maytag MAT12CSDAQ MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12CSDAW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12CSDGW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12CSEGW MANUAL, PARTS (WASHER) Maytag MAT12CSFWQ COMMERCIAL LAUNDRY (WASHER) Maytag MAT12CSFWW COMMERCIAL LAUNDRY (WASHER) Maytag MAT12CSLGW MAYTAG COMMERCIAL WASHER (WASHER) Maytag MAT12CSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER) Maytag MAT12CSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER) Maytag MAT12PDAAL MANUAL, PARTS (WASHER) Maytag MAT12PDAAW MANUAL, PARTS (WASHER) Maytag MAT12PDABL MANUAL, PARTS (WASHER) Maytag MAT12PDABW MANUAL, PARTS (WASHER) Maytag MAT12PDAGW MANUAL, PARTS (WASHER) Maytag MAT12PDBAL MANUAL, PARTS (WASHER) Maytag MAT12PDBAQ MANUAL, PARTS (WASHER) Maytag MAT12PDBAW MANUAL, PARTS (WASHER) Maytag MAT12PDBBL MANUAL, PARTS (WASHER) Maytag MAT12PDBBQ WASHER-TOP LOADING Maytag MAT12PDBBW MANUAL, PARTS (WASHER) Maytag MAT12PDCBL MAYTAG LAUNDRY (WASHER) Maytag MAT12PDCBQ MAYTAG LAUNDRY (WASHER) Maytag MAT12PDCBW MAYTAG LAUNDRY (WASHER) Maytag MAT12PDDAQ MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12PDDAW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12PDDBW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12PDDGW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12PDEGW MANUAL, PARTS (WASHER) Maytag MAT12PDLAQ MAYTAG LAUNDRY (WASHER) Maytag MAT12PDLAW MAYTAG LAUNDRY (WASHER) Maytag MAT12PDLGW COMMERCIAL LAUNDRY (WASHER) Maytag MAT12PDSAW MANUAL,PARTS (WASHER) Maytag MAT12PRAAW MANUAL, PARTS (WASHER) Maytag MAT12PRAEW MANUAL, PARTS (WASHER) Maytag MAT12PRBAW MANUAL, PARTS (WASHER) Maytag MAT12PRDAW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12PRSAW MANUAL, PARTS (WASHER) Maytag MAT12PSAAW MANUAL, PARTS (WASHER) Maytag MAT12PSAGW MANUAL, PARTS (WASHER) Maytag MAT12PSBAW MANUAL, PARTS (WASHER) Maytag MAT12PSDAW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12PSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER) Maytag MAT12PSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER) Maytag MAT13MNAAW MANUAL, PARTS (WASHER) Maytag MAT13MNAGW MANUAL, PARTS (WASHER) Maytag MAT13MNDAW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT13MNDGW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT13MNEGW MANUAL, PARTS (WASHER) Maytag MAT13PDAAW MANUAL, PARTS (WASHER) Maytag MAT13PDBAW MANUAL, PARTS (WASHER) Maytag MAT13PNAEW MAYTAG LAUNDRY (WASHER) Maytag MAT13PNDEW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT13PRBWW MAYTAG LAUNDRY (WASHER) Maytag MAT14CSAGW0 COMMERCIAL AUTOMATIC WASHER Maytag MAT14CSAWW0 COMMERCIAL AUTOMATIC WASHER Maytag MAT14CSBGW0 COMMERCIAL AUTOMATIC WASHER Maytag MAT14PDAWW0 COMMERCIAL AUTOMATIC WASHER Whirlpool MAT14PDAXW0 COMMERCIAL AUTOMATIC WASHER
