Discuss
Loose spin basket
 in
Washer Repair
The lock nut that holds the spin basket to the drive block broke. I could not buy a new one
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Loose spin basket
  #1 (permalink)
Old 11-12-2012, 08:13 AM
Junior Member
Trugab is on a distinguished road
Default Loose spin basket
Model Number: 110.21082000   Brand: Kenmore   Age: More than 10 years
The lock nut that holds the spin basket to the drive block broke. I could not buy a new one so I had it welded. I now can't get the spin basket level so that during the spin cycle it does not become off balanced. I am kind of believing that this (lock nut) isn't a serviceable item and I need to buy the whole drum. Any thoughts or help in getting the spin basket level?
Ads By Google
Related Models
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Washer - basket loose jemsw Washer Repair 1 02-21-2012 10:24 AM
loose spin basket jeff h. Washer Repair 4 03-08-2011 01:27 PM
Basket is loose socrking310 Dishwasher Repair 0 05-11-2010 08:23 AM
Kenmore 80 series basket loose and loud during spin cycle lsimpsongrl Washer Repair 3 12-03-2009 09:09 PM
GE washer loose basket? hawaan Washer Repair 3 09-22-2009 04:52 AM
