Discuss
Washer stops in rinse cycle
 in
Washer Repair
We have a Maytag SAV3710AWW washer that stops at some point during the rinse cycle. When we return to the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer stops in rinse cycle
  #1 (permalink)
Old 11-11-2012, 05:13 PM
Junior Member
mhatch14 is on a distinguished road
Default Washer stops in rinse cycle
Model Number: SAV3710AWW   Brand: Maytag   Age: 5 - 10 years
We have a Maytag SAV3710AWW washer that stops at some point during the rinse cycle. When we return to the washer, we find a tub full of water and the timer shows it has finished all cycles. So even though the timer shows that the entire wash process has completed, it's clear that it has not because of the tub full of water.
Is this caused by a bad timer? Should I go ahead and order a new one? Washer is 8 years old.
Thanks in advance.
Mark
Related Models
Maytag SAV3710AWW WASHER-TOP LOADING
Maytag SAV405DAWW WASHER-TOP LOADING
Maytag SAV405DEWW WASHER-TOP LOADING
Maytag SAV4655AWQ WASHER-TOP LOADING
Maytag SAV4655AWW WASHER-TOP LOADING
Maytag SAV4655EWQ WASHER-TOP LOADING
Maytag SAV4655EWW WASHER-TOP LOADING
Maytag SAV4710AWW WASHER-TOP LOADING
Maytag SAV505DAWQ WASHER-TOP LOADING
Maytag SAV505DAWW WASHER-TOP LOADING
Maytag SAV515DAWW WASHER-TOP LOADING
Maytag SAV515DEWW WASHER-TOP LOADING
Maytag SAV5300AWW WASHER-TOP LOADING
Maytag SAV5401AWW WASHER-TOP LOADING
Maytag SAV5600AWW WASHER-TOP LOADING
Maytag SAV5701AWQ WASHER-TOP LOADING
Maytag SAV5701AWW WASHER-TOP LOADING
Maytag SAV5710AWW WASHER-TOP LOADING
Maytag SAV571EEWW WASHER-TOP LOADING
Maytag SAV5910AWW WASHER-TOP LOADING
Maytag SAV5910EWW WASHER-TOP LOADING
Maytag SAW25K3S WASHER-TOP LOADING
Whirlpool SAWB600HQ0 AUTOMATIC WASHER
Whirlpool SAWB600JQ0 WASHER
Whirlpool SAWB600JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800HQ0 AUTOMATIC WASHER
Whirlpool SAWS800JQ0 WASHER
Whirlpool SAWS800JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800JQ2 WASHER
Whirlpool SAWS800MQ0 AUTOMATIC WASHER
Whirlpool SAWS900HQ0 WASHER
Whirlpool SAWS900JQ0 WASHER - DIRECT DRIVE
Whirlpool SAWS900MQ0 AUTOMATIC WASHER
Whirlpool SAWX650JQ0 WASHER
Whirlpool SAWX650MQ0 AUTOMATIC WASHER
Whirlpool SAWX650MQ2 AUTOMATIC WASHER
Whirlpool SB1000SKN0 BUILT-IN GAS OVEN
Whirlpool SB100PEDB0 24" GAS BUILT-IN OVEN STANDARD CLEAN
Whirlpool SB100PEDB1 24" GAS BUILT-IN STANDARD CLEAN OVEN
Whirlpool SB100PEDB2 24" GAS BUILT-IN-OVEN STANDARD CLEAN
Whirlpool SB100PEDB4 GAS RANGE AND OVEN
Whirlpool SB100PEDB5 24" GAS SLIDE-IN RANGE
Whirlpool SB100PEK1 BUILT-IN GAS OVEN
Whirlpool SB100PER0 Range (gas)*
Whirlpool SB100PES0 Range (gas)*
Whirlpool SB100PES1 Range (gas)*
Whirlpool SB100PES2 Range (gas)*
Whirlpool SB100PES3 Range (gas)*
Whirlpool SB100PES4 GAS RANGES & OVENS
Whirlpool SB100PSK0 BUILT-IN GAS OVEN
Whirlpool SB100PSK1 BUILT-IN GAS OVEN
Whirlpool SB100PSR0 Range (gas)*
Whirlpool SB100PSR1 Range (gas)*
Whirlpool SB130PEDB0 24" GAS BUILT-IN OVEN CONTINUOUS CLEAN
Whirlpool SB130PEDB1 24" GAS BUILT-IN CONTINUOUS CLEAN OVEN
Whirlpool SB130PEDB2 24" GAS BUILT-IN-OVEN CONTINUOUS CLEAN
Whirlpool SB130PEK0 BUILT-IN GAS OVEN
Whirlpool SB130PER1 Range (gas)*
Whirlpool SB130PER2 Range (gas)*
Whirlpool SB130PER3 Range (gas)*
Whirlpool SB130PER4 GAS BUILT-IN OVEN
Whirlpool SB130PER5 24" GAS BUILT-IN OVEN ELECTRONIC IGNITION CONTINUOUS CLEAN OVEN
Whirlpool SB130PERW0 Range (gas)*
Whirlpool SB130PSK0 BUILT-IN GAS OVEN
Whirlpool SB160PEDB0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB2 24" BUILT-IN-OVEN
Whirlpool SB160PEDB4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ2 24" BUILT-IN-OVEN
Whirlpool SB160PEDQ4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEEB1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEB2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEB5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEB6 BUILT-IN GAS OVEN
Whirlpool SB160PEEB7 BUILT-IN GAS OVEN
Whirlpool SB160PEEB8 BUILT-IN GAS OVEN
Whirlpool SB160PEEB9 BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEQ2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEQ6 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ7 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ8 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ9 BUILT-IN OVEN, GAS
Whirlpool SB160PEXB0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ1 BUILT IN GAS OVEN
Amana SB21VE REF - SXS/I&W
Amana SB21VPSE REF - SXS/I&W
Amana SB21VW REF - SXS/I&W
Thermador SB2B
Amana SB520K REF - SXS/I&W
Amana SB520SW REF - SXS/I&W
Amana SB520TW REF - SXS/I&W
Amana SBC24FX0 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FX5 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FXOW RANGE - ELECTRIC STD DELAWARE
Amana SBC26CK RANGE - ELECTRIC STD DELAWARE
Amana SBD20H REF - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K REF - SXS/I&W
Amana SBD20M REF - SXS/I&W
Amana SBD20MW REF - SXS/I&W
Amana SBD20NE REF - SXS/I&W
Amana SBD20NW REF - SXS/I&W
Amana SBD20Q2E REF - SXS/I&W
Amana SBD20Q2W REF - SXS/I&W
Amana SBD20S4E REF - SXS/I&W
Amana SBD20S4L REF - SXS/I&W
  #2 (permalink)
Old 11-12-2012, 03:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Mark,
Watch the washer during the cycle to find out at which point it stops. It's very important to figure out if the motor completely stopped and was silent or it was running but the washer did not drain.
Remove the bottom access panel and the front panel. Remove the hoses from the pump and make sure they are clean and there are no foreign objects inside the pump.
Here are the breakdown diagrams and Parts for Maytag SAV3710AWW Washer - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-12-2012, 10:06 PM
Junior Member
Default
Gene-
Thanks so much for your reply.
We just watched the entire wash process and noticed something very interesting. The washer stayed in wash/agitate mode the whole time until the timer got to the end. We heard pretty distinct clicks as the timer would pass locations where it should have moved on to other cycles such as rinse and spin, but it never actually moved on. Like I said, it stayed in wash/agitate mode the entire time.
Seems like this might point to something. We did check the hoses and they appeared to be fine. Also, once the process ends and the tub is full of water, we then turn the knob to "extended spin" and it correctly drains the water out and begins to spin. Not sure why it works when taken straight to the spin cycle.
Any thoughts?
Thanks, again.
Mark.
  #4 (permalink)
Old 11-13-2012, 03:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Mark,
In order to switch from agitation to spin and drain the motor has to change direction. If it does not do it then the problem more likely is a bad timer.
- The timer Part number: 27001113
__________________
  #5 (permalink)
Old 11-13-2012, 03:13 PM
Junior Member
Default
Thanks, Gene.
I went ahead and ordered that part. I'll let you know how it goes.
Thanks.
Mark
  #6 (permalink)
Old 11-13-2012, 05:37 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Does the washer drains before the rinse cycle?
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #7 (permalink)
Old 11-13-2012, 05:53 PM
Junior Member
Default
Well, if we leave the washer going from start to end it never actually drains. It just stays in the wash/agitate cycle the entire time.
At that point we turn the knob back around but straight to the "Extended Spin" cycle and start it from there. If we do that, it drains the water from the tub and starts to spin. However, this means that the rinse cycle never goes. To solve this, we turn on "Extra Rinse" so that when it reaches the end it starts the extra rinse. But once again the extra rinse does not end in a drain and spin. So once again we turn it to "Extended Spin" to get it to drain and spin one final time (with "Extra Rinse" now turned off).
So the system never drains and spins when it should. It's somewhat complicated so I hope I am explaining it well.
Does it seem that the timer I ordered would fix this kind of an issue?
Thanks.
Mark
  #8 (permalink)
Old 11-14-2012, 11:13 AM
Expert
Default
Hi.
It's a very good chance that it's the timer.
Simon.
__________________
  #9 (permalink)
Old 11-16-2012, 08:09 PM
Junior Member
Default
The timer fixed the problem. Thanks, guys!
  #10 (permalink)
Old 11-17-2012, 09:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Mark. We are glad to hear we could help you out. If there is anything else we can help you with, drop us a line.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer stops before Rinse cycle burrii Washer Repair 0 07-18-2012 10:09 AM
Maytag Washer Stops At Rinse Cycle DONNAMARIA Washer Repair 0 02-25-2012 04:01 PM
Whirlpool Washer stops at the rinse cycle Janemarie Washer Repair 1 10-16-2011 06:41 PM
washer stops in the rinse cycle carl taylor Washer Repair 1 12-22-2010 10:54 AM
Problem- Washer stops at rinse cycle zamana Washer Repair 1 01-25-2009 07:19 PM
