Discuss
clothes still wet after 1st spin cycle but dry after 2nd spin cycle
 in
Washer Repair
When first starting wash cycle, washer starts to agitate and fill at the same time. (prior to this problem i
Appliance Repair Forum > Appliance Repair Help > Washer Repair » clothes still wet after 1st spin cycle but dry after 2nd spin cycle
  #1 (permalink)
Old 11-10-2012, 02:28 PM
Junior Member
sscaduto is on a distinguished road
Default clothes still wet after 1st spin cycle but dry after 2nd spin cycle
Model Number: 11029822800   Brand: Kenmore   Age: 1 - 5 years
When first starting wash cycle, washer starts to agitate and fill at the same time. (prior to this problem i am about to explain it would fill 1st then agitate.) Dial is set for 1 rinse. At end of spin cycle clothes are still wet. I replaced the timer. Same problem. With new timer still in place i set the rinse dial for 2nd rinse. Washer starts again to agitate and fill at the same time but at the end of the 2nd rinse cycle clothes are dry enough to put in dryer. Do i need to also change the water sensor switch to solve the problem? On my model it appears that the corresponding dial on the panel is labeled fabric softener. Is this the correct part? Also did I have to get a new timer or was the problem only the water sensor switch all along. (does the water sensor switch have a tube connected to it ?)
Ads By Google
Related Models
Kenmore 11029842990 WASHER
Kenmore 11029842991 AUTOMATIC WASHER
Kenmore 11029852990 AUTOMATIC WASHER-GALAXY
Kenmore 11029852991 AUTOMATIC WASHER
Kenmore 11029852992 AUTOMATIC WASHER
Kenmore 11029882890 AUTOMATIC WASHER
Kenmore 11029882891 AUTOMATIC WASHER
Kenmore 11029884890 AUTOMATIC WASHER
Kenmore 11029884891 AUTOMATIC WASHER
Kenmore 11029892990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029894990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029962890 AUTOMATIC WASHER
Kenmore 11029962891 AUTOMATIC WASHER
Kenmore 1103348565 GEARCASE
Kenmore 110357116 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357177 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357970 BASKET DRIVE AND BRAKE ASM
Kenmore 110357972 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358364 BASKET DRIVE AND BRAKE ASM
Kenmore 110358365 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358371 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358483 GEARCASE ASM
Kenmore 110358484 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358485 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358487 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358507 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358795 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358841 GEARCASE AND SUPERSTRUCTURE
Kenmore 110359175 BASKET DRIVE & BRAKE ASM
Kenmore 110359178 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110359279 GEARCASE PARTS
Kenmore 110359517 BASKET DRIVE AND BRAKE PARTS
Kenmore 110359699 BASKET DRIVE AND BRAKE PARTS
Kenmore 110360093 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110360867 DOLE MIXING VALVE ASSEMBLY
Kenmore 110360868 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110362101 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362821 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362901 GEARCASE ASM
Kenmore 110363000 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363076 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363082 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364443 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364444 BASKET DRIVE AND BRAKE PARTS
Kenmore 110364446 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364494 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364760 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365011 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365012 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365013 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365014 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365196 GEARCASE AND SUPERSTRUCTURE
Kenmore 110365359 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365712 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365859 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365948 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366559 GEARCASE AND SUPERSTRUCTURE
Kenmore 110366660 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366990 BASKET DRIVE & BRAKE ASM
Kenmore 110367551 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110367593 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 1103733107 KENMORE PORTABLE AUTOMATIC WASHER
Kenmore 110386842 WATER SAVER
Kenmore 110387948 BRAKE AND DRIVE TUBE
Kenmore 110388951 BRAKE AND DRIVE TUBE
Kenmore 110388952 BRAKE AND DRIVE TUBE
Kenmore 110389246 GEARCASE PARTS
Kenmore 110395055 GEARCASE AND SUPERSTRUCTURE
Briggs & Stratton 110402-0180-E1 ENGINE
Kenmore 11049182992 WASHER
Kenmore 11049722990 AUTOMATIC WASHER
Kenmore 11049722991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049722992 COMPACT WASHER
Kenmore 11051115 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051140 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051309 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051730 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055592 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055593 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055594 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055610 WORM GEAR CASE ASSEMBLY
Kenmore 11055614 WORM GEAR CASE ASSEMBLY
Kenmore 11056171 WORM GEAR CASE ASSEMBLY
Kenmore 11056172 WORM GEAR CASE ASSEMBLY
Kenmore 11056464 WORM GEAR CASE ASSEMBLY
Kenmore 11057624 KENMORE PERMANENT INSTALLATION CONV KIT
Kenmore 11057929 KENMORE DUAL AGITATOR KIT
Kenmore 1105809106 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809500 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809502 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809503 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809702 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809703 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809704 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809800 KENMORE GAS CONBINATION WASHER-DRYER
Kenmore 1105907400 KENMORE GAS DRYER
Kenmore 1105907500 KENMORE GAS DRYER
Kenmore 1105907501 KENMORE GAS DRYER
Kenmore 1105907600 KENMORE GAS DRYER
Kenmore 1105907610 KENMORE GAS-DRYER
Kenmore 1105907700 KENMORE GAS DRYER
Kenmore 1105907710 KENMORE GAS DRYER
Kenmore 1105907720 KENMORE GAS DRYER
Kenmore 1105907721 KENMORE GAS DRYER
Kenmore 1105907730 KENMORE GAS DRYER
Kenmore 1105907800 KENMORE GAS DRYER
Kenmore 1105907801 KENMORE GAS DRYER
Kenmore 1105907802 KENMORE GAS DRYER
Kenmore 1105907950 KENMORE GAS DRYER
Kenmore 1105907951 KENMORE GAS DRYER
Kenmore 1105908000 KENMORE ELECTRIC DRYER
Kenmore 1105908100 KENMORE ELECTRIC DRYER
Kenmore 1105908300 KENMORE ELECTRIC DRYER
Kenmore 1105908400 KENMORE ELECTRIC DRYER
Kenmore 1105908500 KENMORE ELECTRIC DRYER
Kenmore 1105908501 KENMORE ELECTRIC DRYER
Kenmore 1105908600 KENMORE ELECTRIC DRYER
Kenmore 1105908700 KENMORE ELECTRIC DRYER
Kenmore 1105908710 KENMORE ELECTRIC DRYER
Kenmore 1105908711 KENMORE ELECTRIC DRYER
  #2 (permalink)
Old 11-10-2012, 03:48 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
This machine has the auto load detection system which has an integral pressure sensor and yes, that's what the fabric softener control attaches to. The part is a high failure item but I would first check the plastic hose where it attaches to the air dome at the bottom right side of the tub. Check the hose and air dome for gunk. There is also a flow meter that interfaces with this switch. The flow meter monitors water flow coming into the tub.
Eric
  #3 (permalink)
Old 11-10-2012, 05:04 PM
Junior Member
Default Checking/cleaning dome and tube
Eric
Thank you for responding. I assume I will have to remove the front in order to get at the dome. Is this correct? If this looks clean will replacing the water sensor solve the problem? Also did I really have to replace the timer switch after all or can I put the old one back in and return the new one for credit?
  #4 (permalink)
Old 11-10-2012, 06:17 PM
Expert
APP Volunteer
Default
The whole cabinet comes off in one piece after releasing the spring clips under the control panel. After releasing the clips and unplugging the lid switch plug, tilt the cabinet forward, pull the bottom forward a little and remove it. It's up to you to check the hose and air dome, it's probably ok and with the number of load sense switch problems with this model, it's most likely the problem. As far as returning the timer, you'll have to contact customer service.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Clothes are still very wet after spin cycle motown10 Washer Repair 1 08-22-2012 06:09 PM
Clothes still wet after spin cycle gbdad10 Washer Repair 3 04-05-2012 04:48 AM
wet clothes after spin cycle doitmayself Washer Repair 1 08-17-2011 01:35 PM
Front load washer won't spin water out of clothes on last spin cycle Tracey Finley Washer Repair 1 06-28-2011 05:10 PM
Clothes still wet after spin cycle JCarfi2011 Washer Repair 0 02-10-2011 02:45 PM
