| » LG TROMM Washer Drain Pump |
Model Number: WM2487HWM Brand: -other- Age: 5 - 10 years
Hi everyone,
We've owned an LG TROMM for just over 5 years. It recently stopped draining, so I replaced the main control board. I tried running again and it still didn't drain so I measured the resistance of the drain pump. Resistance was 0 so I replaced the drain pump. I blew through the drain hose (using my lungs, not an air compressor) and it was clear. I hooked everything back up and the drain pump is still not running. Resistance across the new pump is 14 Ohms. I'm getting 110VAC across the motor connectors when they are disconnected, effectively 0VAC when they are connected (not surprising to me with such a small resistance). So, absolutely no idea what the problem is. The only thing I can possibly think of is that I damaged the new control board when I tried to run the burned out pump with it. Anyone have any ideas? I'm stumped & frustrated. Thanks! Timothy Ads By Google Related Models |
Pry the main control board away from the plastic cover and look for a bad ribbon, or blown solder connection by the power relay. Be carefull if it is static sensitive.
__________________
Hi there.
The PCB is sealed in the cover via some sort of gel or silicone. However, I don't see anything wrong with it, and I am getting 110V to the terminals of the pump when it is supposed to be running. Does that help? Thanks. |
| Display Modes | |
| LG Tromm Washer-Drain Motor Loud Grinding Noise | estanton | Washer Repair | 1 | 05-17-2013 02:04 AM |
| LG Washer OE need drain pump? | Diane Drum | Washer Repair | 0 | 05-30-2012 05:29 PM |
| LG Tromm code OE, no drain | DAC68 | Washer Repair | 1 | 02-23-2012 10:02 AM |
| LG Tromm Washer Drain Pump... | Imtiaz | Washer Repair | 1 | 01-26-2011 09:05 AM |
| New pump but washer will still not drain | FredPam | Washer Repair | 5 | 08-29-2009 04:01 PM |
