Discuss
Kenmore washer No spin no rinse parts source
 in
Washer Repair
After much searching here and other sources, it appears that the problem with our washer is most likely the timer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer No spin no rinse parts source
  #1 (permalink)
Old 11-10-2012, 07:40 AM
Junior Member
mkc1962 is on a distinguished road
Default Kenmore washer No spin no rinse parts source
Model Number: 110.20702991   Brand: Kenmore   Age: More than 10 years
After much searching here and other sources, it appears that the problem with our washer is most likely the timer switch.
Started by not going into Spin cycle, unless you rotated knob again and put it there yourself. Now doing the same thing both in the rinse and spin cycle. Will do both if done manually but not automaticaly.
What is the best source for parts price wise? I see sears has the part # 661635 for $118. Not to say that is totally unreasonable, but kind of hard to justify putting that much into a 14 year old machine when I can get a new machine with same specs for around $300.
Thanks,
MIke in Alabama
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 11-10-2012, 09:50 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
If it spins in another cycle, but not the normally used one, the timer is probably bad. You can pull the cover off and check for burnt contacts to confirm.
__________________
  #3 (permalink)
Old 11-10-2012, 11:57 AM
Junior Member
Default
going into automatically it hasnt gone into the spin cycle for months. We can rotate the knob back to the spin start point and ONLY when done manually will it then spin and do so until cycle is complete. Just also recently started doing the same thing in the pre spin rinse cycle. Ive also tried using the other spin cycles, but it does the same in those as well.
I removed the timer several months ago looking for anything like a burnt contact but didnt find anything that looked obvious.
  #4 (permalink)
Old 11-10-2012, 02:37 PM
Senior Expert
APP Volunteer
Default
When the washer gets to the rinse point, if the motor runs, but it never spins during that period, but advances to the end without interuption, you have a bad timer, must interrupt motor for a short period to allow the clutch in the tranny to engage.
__________________
  #5 (permalink)
Old 11-10-2012, 03:33 PM
Junior Member
Default
Sounds exactly like what ours is doing....any suggestions for a replacement parts source that isnt so expensive? Ive found one source at $91 that aint that bad, but never hurts to ask where others might have found it at a best price.
Thanks,
Mike
  #6 (permalink)
Old 11-10-2012, 04:35 PM
Senior Expert
APP Volunteer
Default
There are sites that repaqir timers, but probably not worth doing as you have to ship out the old one. If you can do a Google search and find a rebuilt one, it might be worth doing.
__________________
  #7 (permalink)
Old 11-11-2012, 08:36 AM
Junior Member
Default
richappy,
thanks for the input. I would imagine all the shipping and repair service woudl no doubt also be in the $90 range. For that I might as well go with new.
Thanks again,
MIke
  #8 (permalink)
Old 11-11-2012, 10:57 AM
Senior Expert
APP Volunteer
Default
You are right there, they used to fix a lot of these, but the timers are now built better.
Forget about cleaning the contacts, a waste of time as they are worn and will still not work right.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 400 washer wont go into final rinse/spin cycle moneysaver804 Washer Repair 0 09-01-2012 09:44 AM
GE Pedastal parts source? knox.154 Dryer Repair 3 05-25-2012 07:42 AM
Kenmore washer doesnt rinse or spin balusamy Washer Repair 1 08-30-2011 06:56 PM
Kenmore 80 Series Washer makes a banging noise during rinse & spin cycles sixnovaceks Washer Repair 1 09-30-2010 05:04 PM
Kenmore washer wont go through rinse and spin cycle smolohon Washer Repair 0 08-06-2010 05:41 PM
