Discuss
Washer won't stop filling
 in
Washer Repair
This all started with the washer not agitating. I did some research online and found that it was either a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't stop filling
  #1 (permalink)
Old 11-08-2012, 04:19 PM
Junior Member
BeeK is on a distinguished road
Default Washer won't stop filling
Model Number: MAVT634AWW   Brand: Maytag   Age: 5 - 10 years
This all started with the washer not agitating. I did some research online and found that it was either a plastic piece or the transmission. So, I tore it apart. It was not the plastic piece. Since it would fill, drain, and spin, I knew it was the transmission. I had also came across, if the washer is not ten years old, the transmission is still covered under warrenty. So, the owners of the machine called someone to replace the tranny. I had installed another wash machine while we waited for it to be fixed. So the machine was not tested until tonight and the fill level switch is not working right. It is not the inlet, because it will stop when when you push the button in to stop it. When I tore it apart, I did remove all wires. I took pictures and made a couple movies in order to get them all back in the right spot. They are all in the same spot, the only one I'm not sure of is green ground wire. This wire comes up through the top metal piece in under the control panel. It then has a round metal loop that I know gets screwed to the top piece, it then continues to a metal clip. The clip seems as though it would slide over something. I would image it has to slide over a metal piece somewhere but I do not know where that piece is. Under the control panel there are plastic tabs sticking out that this clip fits on, but it won't stop filling and there is no need for the wire to continue past the metal loop if it does not connect to a metal piece, correct? I've looked at the wiring diagram, but I do not know how to read them, nor do I see that wire or where the last clip should go. There is no place for it on the level switch. The next thing I'm going to check is to make sure that the level sensor tube is not clogged with something. Any other ideas?
Ads By Google
Related Models
Maytag MAVT634AWW Washer, Atlantis
Maytag MAVT734EWW Washer, Atlantis
Maytag MAVT754EWW Washer, Atlantis
Maytag MAVT834AWQ Washer, Atlantis
Maytag MAVT834AWW Washer, Atlantis
Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot
International MB1927PEHB  Ref - Maytag Int'l Bot Mount
International MB1927PEHW  Ref - Maytag Int'l Bot Mount
International MB2216PUAW Ref - Bottom Mounts
International MB2227PEHB  Ref - Maytag Int'l Bot Mount
International MB2227PEHW  Ref - Maytag Int'l Bot Mount
Thermador MB245
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0
Whirlpool MB7120XYB1
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ  Ref - Bottom Mounts
Maytag MBB1952GRW  Ref - Bottom Mounts
Maytag MBB1952HEB Ref - Bottom Mounts
Maytag MBB1952HEQ Ref - Bottom Mounts
Maytag MBB1952HEW Ref - Bottom Mounts
Maytag MBB1954GEB  Ref - Bottom Mounts
Maytag MBB1954GEQ  Ref - Bottom Mounts
Maytag MBB1954GES  Ref - Bottom Mounts
Maytag MBB1954GEW  Ref - Bottom Mounts
Maytag MBB1954HEW Ref - Bottom Mounts
Maytag MBB1956GEB  Ref - Bottom Mounts
Maytag MBB1956GEQ  Ref - Bottom Mounts
Maytag MBB1956GES  Ref - Bottom Mounts
Maytag MBB1956GEW  Refrigerator
Maytag MBB1956HEB Ref - Bottom Mounts
Maytag MBB1956HEQ Ref - Bottom Mounts
Maytag MBB1956HES Ref - Bottom Mounts
Maytag MBB1956HEW Ref - Bottom Mounts
Maytag MBB2254GEB  Ref - Bottom Mounts
Maytag MBB2254GEQ  Ref - Bottom Mounts
Maytag MBB2254GES  Ref - Bottom Mounts
Maytag MBB2254GEW  Ref - Bottom Mounts
Maytag MBB2256GEB  Ref - Bottom Mounts
Maytag MBB2256GEQ  Ref - Bottom Mounts
Maytag MBB2256GES  Ref - Bottom Mounts
Maytag MBB2256GEW  Ref - Bottom Mounts
Maytag MBF1956HEB Ref - Bottom Mounts
Maytag MBF1956HEQ Ref - Bottom Mounts
Maytag MBF1956HES Ref - Bottom Mounts
Maytag MBF1956HEW Ref - Bottom Mounts
Maytag MBF1956KEB Ref - Bottom Mounts
Maytag MBF1956KEQ Ref - Bottom Mounts
Maytag MBF1956KEW Ref - Bottom Mounts
Maytag MBF2254HEB Ref - Bottom Mounts
Maytag MBF2254HEB14 Refrigerator
Maytag MBF2254HEQ Ref - Bottom Mounts
Maytag MBF2254HEQ14 Refrigerator
Maytag MBF2254HES White Westinghouse/refrigerator
Maytag MBF2254HEW Ref - Bottom Mounts
Maytag MBF2254HEW14 Refrigerator
Maytag MBF2255KEB Ref - Bottom Mounts
Maytag MBF2255KEB11 Refrigerator
Maytag MBF2255KEQ Ref - Bottom Mounts
Maytag MBF2255KEQ11 Refrigerator
Maytag MBF2255KEW Ref - Bottom Mounts
Maytag MBF2255KEW11 Refrigerator
Maytag MBF2256HEB Ref - Bottom Mounts
Maytag MBF2256HEQ Ref - Bottom Mounts
Maytag MBF2256HES Ref - Bottom Mounts
Maytag MBF2256HEW Ref - Bottom Mounts
Maytag MBF2256KEB Ref - Bottom Mounts
Maytag MBF2256KEB11 Refrigerator
Maytag MBF2256KEQ Ref - Bottom Mounts
Maytag MBF2256KEQ11 Refrigerator
Maytag MBF2256KEW Ref - Bottom Mounts
Maytag MBF2256KEW11 Refrigerator
Maytag MBF2258HEB Ref - Bottom Mounts
Maytag MBF2258HEQ Ref - Bottom Mounts
Maytag MBF2258HES Ref - Bottom Mounts
Maytag MBF2258HEW Ref - Bottom Mounts
Maytag MBF2262HEB Ref - Bottom Mounts
Maytag MBF2262HEB13 Refrigerator
Maytag MBF2262HEQ Ref - Bottom Mounts
Maytag MBF2262HEW Ref - Bottom Mounts
Maytag MBF2262HEW13 Refrigerator
Maytag MBF2556HEB Ref - Bottom Mounts
Maytag MBF2556HEQ Ref - Bottom Mounts
Maytag MBF2556HES Ref - Bottom Mounts
Maytag MBF2556HEW Ref - Bottom Mounts
Maytag MBF2556HSW Ref - Bottom Mounts
Maytag MBF2556KEB Ref - Bottom Mounts
Maytag MBF2556KEQ Ref - Bottom Mounts
Maytag MBF2556KEW Ref - Bottom Mounts
Maytag MBF2558HEB Ref - Bottom Mounts
Maytag MBF2558HEQ Ref - Bottom Mounts
Maytag MBF2558HES Ref - Bottom Mounts
Maytag MBF2558HEW Ref - Bottom Mounts
Maytag MBF2562HEB Ref - Bottom Mounts
Maytag MBF2562HEQ Ref - Bottom Mounts
Maytag MBF2562HEW Ref - Bottom Mounts
Maytag MBL1952KES Ref - Bottom Mounts
Maytag MBL1956HES Ref - Bottom Mounts
Maytag MBL1956KES Ref - Bottom Mounts
Maytag MBL2255KES Ref - Bottom Mounts
Maytag MBL2255KES12 Refrigerator
Maytag MBL2256KES Ref - Bottom Mounts
Maytag MBL2256KES12 Refrigerator
Maytag MBL2262HES Ref - Bottom Mounts
Maytag MBL2262KES Ref - Bottom Mounts
Maytag MBL2262KES12 Refrigerator
Maytag MBL2556KES Ref - Bottom Mounts
Maytag MBL2562HES Ref - Bottom Mounts
Maytag MBL2562KES 5 Qt. Stand Mixer
Maytag MBQ30 Gas Grill - B/i Stainless St
Maytag MBQ42 Gas Grill - B/i Stainless St
International MBR1415AGS Range - F/s Std Ele
International MBR1415AGW Range - F/s Std Ele
Maytag MBR1952KES Ref - Bottom Mounts
Maytag MBR1956HES Ref - Bottom Mounts
Maytag MBR1956KES Ref - Bottom Mounts
Maytag MBR1980AAB Small Appliances
Maytag MBR1980AAG Small Appliances
Maytag MBR2255KES Ref - Bottom Mounts
Maytag MBR2255KES12 Refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will not stop filling Chad993 Washer Repair 3 06-29-2012 10:51 AM
washer won't stop filling kimbovia Washer Repair 1 06-01-2011 09:58 AM
Washer won't stop filling up CarlaS Washer Repair 4 02-23-2011 05:55 AM
GE Washer won't stop filling ddavis263 Washer Repair 1 07-27-2010 10:15 AM
GE Washer won't stop filling scrabs Washer Repair 2 07-06-2009 07:26 PM
