Discuss
Spins sometimes, sometimes doesn't
 in
Washer Repair
My Estate (15 months old) washer seems to work correctly much of the time. BUT, sometimes it will not spin
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Spins sometimes, sometimes doesn't
  #1 (permalink)
Old 11-06-2012, 10:11 AM
Junior Member
Joseph42 is on a distinguished road
Default Spins sometimes, sometimes doesn't
Model Number: ETW4400XQ0   Brand: Estate   Age: 1 - 5 years
My Estate (15 months old) washer seems to work correctly much of the time. BUT, sometimes it will not spin on one of the spin cycles (wash or rinse)....
1- Usually fails on rinse spin cycle.
2- All other functions are normal.
3- When it fails to spin, the motor continues to run and sounds like it is still pumping though there is no water left in the tub.
4- Water level switch and timer were replaced.
5- Spin cycle times out normally and the machine goes into the next cycle.
6- There is no drain obstruction.
7- Lid switch is ok
8- May be more apt to not spin when load is heavier.
9- Seems to be louder with a muted knock as it agitates
What is most likely the problem?
Thank you for this great help for those of us who find it very hard to pay the repair costs today. Will definitely buy parts from you!
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 11-06-2012, 01:21 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Most likely it's the clutch slipping, less likely a bad drive block/spin tube tabs. Replacing the clutch requires removing the gearcase. Inspecting the drive block requires removing the agitator.
Eric
  #3 (permalink)
Old 11-06-2012, 01:45 PM
Junior Member
Default Thanks
Thanks Eric. I have done a lot of mechanics but not much on washers. I would have expected a clutch but didn't think this direct drive machine had one. I couldn't find much on the way of machine operation, just parts diagrams. Are you talking about a clutch inside the transmission case?
  #4 (permalink)
Old 11-06-2012, 03:38 PM
Expert
APP Volunteer
Default
The clutch is on the outside of the gearcase. You'll have to take the agitator off first to be able to pull the gearcase so you might as well inspect the drive block first. The drive block fits over the spin tube and has two slots in it that engage two tabs on the spin tube. The inner tub fits over the drive block and is held tightly in place by the spanner nut. Remove the top cover of the agitator to gain access to a bolt down in there to remove the agitator. This is what the drive block should look like.
Just make sure the tabs and slots are in good shape and the nut is tight. You should be able to turn the basket by hand against the brake to ensure the the basket, drive block and spin tube are turning in unison and not slipping. If it looks good, suggest you search on youtube for procedure to replace the clutch. Just search on Whirlpool Clutch. Your Estate washer is made by Whirlpool. Being mechanically inclined, it should be a piece of cake for you.
Another thing you can do if this is happening pretty regular is to operate it with the cabinet removed and lid switch defeated. This will allow you to observe the clutch hub when the basket should be spinning but isn't. The clutch hub is driven directly by the gearcase and should be spinning if this is a slipping clutch issue. If the motor is spinning in spin mode and the clutch hub is not, then you have gearcase or drive coupler issues.
Eric
  #5 (permalink)
Old 11-07-2012, 07:39 PM
Junior Member
Default Thanks again!
Thank you. I won't have the opportunity to work on it for about a week but this is tremendous. I am sure the trouble can be found with your info. I had thought of taking the cover off to inspect it but never thought i could operate it with the cover off. This is my first chore. When I get the problem solved I'll get back to you. Your information is great.
  #6 (permalink)
Old 11-08-2012, 05:02 AM
Expert
APP Volunteer
Default
Ok, one more thing to be aware of when you go to observe the clutch hub. Right after agitation stops, the motor pauses for a few seconds and then starts back up in the opposite direction to start draining. The clutch hub should not be turning during this drain period. After a couple minutes of drain, the motor pauses again. Then it starts back up again in the same direction as during drain and this is when the clutch hub should start spinning. Now the washer is draining and spinning at the same time.
Eric
  #7 (permalink)
Old 11-20-2012, 09:08 AM
Junior Member
Default
Eric,
Thanks for all your help. I removed the cabinet and watched it through several loads of wash for a week, both small and large loads. It is working normally. I cannot find a thing wrong. It works as you said it should. I guess I'll wait for it to quit and then try again. Now that I know the workings of the thing it seems to be a pretty simple mechanism to troubleshoot. I have only one more question. The clutch seems to be a centrifugal clutch, right? Is the motor multi-speed? My info doesn't make it too clear. If so and it doesn't hit high speed, no spin right? Switch has been changed by the repair service 3 times...no changes. Could there be a problem with motor speed causing this (bad connections on the motor connector because I did take it off and re-plug it). Fixed it? Whatever it is seems to be something that works/ed sometimes and not at others. Thanks again for all your help. I WILL get it sooner or later if it wasn't the plug.
  #8 (permalink)
Old 11-20-2012, 10:16 AM
Expert
APP Volunteer
Default
The clutch is not centrifugally operated. A spring keeps the clutch lining against the clutch hub at all times. The motor is 2-speed and spin should occur at either speed. You said the motor was still operating when spin wasn't working so I don't think its a wiring connection issue.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
spins out sometimes lyinhard Washer Repair 0 08-24-2012 01:45 PM
Spins only low RPM cgrbm45 Washer Repair 1 09-16-2011 06:55 PM
spins when it wants... 1000chuck Washer Repair 3 01-22-2010 07:11 AM
Sometimes spins caymanada Washer Repair 5 01-11-2010 01:30 AM
Spins with a little help Alphadog Washer Repair 1 05-23-2009 06:37 PM
