| » Noisy spin cycle |
Model Number: 110.26292693 Brand: Kenmore Age: 5 - 10 years
I have a brand new screech-ie sort of noise that just began at start of spin cycle & continued throughout spin. Spin completed OK & I have not used since - don't want to destroy anything that is avoidable. Will appreciate suggestions on where to start to diagnose problem and correct as easily (and economically) as possible.
Only service in past 4 years - I replaced coupler (with some difficulty) a bit over a year ago. Thanks for any help you can offer |
Possible a foreign object in the drain pump.
Remove the cabinet, remove the drain pump, bypass the lid switch and run the spin cycle. If there is no noise - replace the drain pump. If it's still noisy - let us know and we will go further. - The part number for the drain pump is AP2907492 Gene. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
__________________
Thank you so much for your help, Gene. No noise on spin after I took the pump off the motor drive shaft. When I took the bottom hose off, a small 1" brad/nail fell into the catch-pan. The pump impeller looked good through the water connectors, so I washed pump out thoroughly (no more foreign objects), reinstalled with perfect, QUIET function. I suspect this may have shortened the life of pump impeller, but OK for now.
I will check my pockets on shirts & pants more carefully from now on. Again, my sincere thanks. Eli Last edited by ezonana1 : 02-02-2008 at 09:14 AM. |
Hi Eli,
I'm glad you were able to fix it. Gene.
__________________
| Display Modes | |
| noisy spin cycle | looz98 | Washer Repair | 1 | 04-08-2008 12:23 AM |
| Noisy Spin Cycle | psmith | Washer Repair | 1 | 12-10-2007 01:11 PM |
| noisy spin cycle | eddieb | Washer Repair | 1 | 11-23-2007 07:43 PM |
| Rotates slow in spin and noisy | rdapodaca69 | Washer Repair | 1 | 10-24-2007 09:49 PM |
| washer noisy during spin | djgabor | Washer Repair | 0 | 09-22-2007 01:03 PM |
