| » maytag washer no rinse cycle |
Model Number: PAVT920AWW Brand: Maytag Age: 5 - 10 years
Fills for rinse then loud noise ( sounds like dry bearing ) then nothing...noise continues until timer go,s intospin. All other cycles work
This is puzzling, since the rinse agitation is just a repeat of the wash agitation using cold water. If it works for the wash agitation it should work for the rinse.
I would try changing out the timer, this part here. Part number: AP4024934 and also operate it with the front panel off and see if you can see what is happening when it tries to agitate in the rinse cycle.
__________________
| Display Modes | |
| maytag washer does not spin fast after rinse cycle | pepito | Washer Repair | 10 | 07-20-2012 09:06 AM |
| Maytag Washer Stops At Rinse Cycle | DONNAMARIA | Washer Repair | 0 | 02-25-2012 04:01 PM |
| Maytag Neptune washer won't advance through rinse cycle | Colliefan | Washer Repair | 1 | 07-13-2011 05:58 PM |
| Maytag washer will not spin after the rinse cycle | kempf25 | Washer Repair | 1 | 04-01-2011 07:19 PM |
| Maytag Washer Water Doesn't Drain After Rinse Cycle | hkpsport | Washer Repair | 2 | 03-02-2010 02:29 AM |
