Discuss
problem completing spin cycle
 in
Washer Repair
this washer works fine but the spins cycle start and before the cycle finish the spin will just come to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » problem completing spin cycle
  #1 (permalink)
Old 11-04-2012, 09:18 PM
Senior Member
allen9258 is on a distinguished road
Default problem completing spin cycle
Model Number: s1070a3ww   Brand: GE   Age: 1 - 5 years
this washer works fine but the spins cycle start and before the cycle finish the spin will just come to a complete stop and it will not stop until about a minute or two then you can restart the spin cycle i replaced the motor with the same results any ideas on the cause?
Ads By Google
Related Models
General Electric S1070A4WW Washer
General Electric S1070A5WW Washer
Admiral S1070EH-KZ Range - F/s Std Gas
Admiral S1070EH-Z Range - F/s Std Gas
Admiral S1070EJ-KZ Range - F/s Std Gas
Admiral S1070EJ-Z Range - F/s Std Gas
Hoover S1071--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1071800 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1073--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1075--- Port - Slim Style,suitcase,power,compact
Hoover S1075033
Hoover S1075060 Port - Slim Style,suitcase,power,compact
Hoover S1077--- Port - Slim Style,suitcase,power,compact
Hoover S1077060 Port - Slim Style,suitcase,power,compact
Admiral S1078EH-KZ Range - F/s Std Gas
Admiral S1078H-KLVW Range - F/s Cont Clean Gas
Admiral S1078W-KLVW Range - F/s Cont Clean Gas
Hoover S1079--- Port - Slim Style,suitcase,power,compact
Hoover S1079060 Port - Slim Style,suitcase,power,compact
Hoover S1083--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1083100 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Admiral S1088H-CKZW Range - S/c S/i Gas
Admiral S1088J-TKZW Range - S/c S/i Gas
Hoover S1093
Hoover S1095
Jenn-Air S110 Range - S/i Std Ddraft Ele
Hoover S1101---
Hoover S1103--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1105--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1112--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1112050 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1114--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1117900 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1117981 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1120--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1120050 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1127--- Port - Slim Style,suitcase,power,compact
Hoover S1133--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1135--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1137--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1137980 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1141--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1147--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1147050 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1147900 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Admiral S1151L-30 Surface Unit - Ele
Admiral S1151L-36G Surface Unit - Ele
Hoover S1156--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Admiral S1171L-30 Surface Unit - Gas
Admiral S1171L-30K Surface Unit - Gas
Admiral S1171L-36GK Surface Unit - Gas
Admiral S1172L-30K Surface Unit - Gas
Jenn-Air S120 Range - S/c S/i Ddraft Ele
Jenn-Air S120-C Range - S/c S/i Ddraft Ele
Jenn-Air S121 Range - S/c S/i Ddraft Ele
Hoover S1211--- Port - Slim Style,suitcase,power,compact
Hoover S1215--- Port - Slim Style,suitcase,power,compact
Hoover S1221--- Port - Slim Style,suitcase,power,compact
Hoover S1223--- Port - Slim Style,suitcase,power,compact
Jenn-Air S125 Range - S/c S/i Ddraft Ele
Jenn-Air S125-C Range - S/c S/i Ddraft Ele
Hoover S1311--- Port - Slim Style,suitcase,power,compact
Hoover S1311020 Port - Slim Style,suitcase,power,compact
Hoover S1315--- Port - Slim Style,suitcase,power,compact
Hoover S1319--- Port - Slim Style,suitcase,power,compact
Hoover S1323--- Port - Slim Style,suitcase,power,compact
Hoover S1329--- Port - Slim Style,suitcase,power,compact
Hoover S1331--- Port - Slim Style,suitcase,power,compact
Hoover S1335--- Port - Slim Style,suitcase,power,compact
Hoover S1337--- Port - Slim Style,suitcase,power,compact
Hoover S1339--- Port - Slim Style,suitcase,power,compact
Hoover S1347--- Port - Slim Style,suitcase,power,compact
Hoover S1349--- Port - Slim Style,suitcase,power,compact
Hoover S1353--- Port - Slim Style,suitcase,power,compact
Jenn-Air S136 Range - S/c S/i Ddraft Ele
Jenn-Air S136-C Range - S/c S/i Ddraft Ele
Hoover S1361---
Jenn-Air S136B Range - S/c S/i Ddraft Ele
Jenn-Air S136B-C Range - S/c S/i Ddraft Ele
Jenn-Air S136W Range - S/c S/i Ddraft Ele
Jenn-Air S136W-C Range - S/c S/i Ddraft Ele
Hoover S1410--- Port - Slim Style,suitcase,power,compact
Hoover S1420--- Port - Slim Style,suitcase,power,compact
Hoover S1420050 Port - Slim Style,suitcase,power,compact
Amana S148CA01  Ref - SXS/I&W
Amana S148CA03  Ref - SXS/I&W
Amana S148DA01  Ref - Sxs
Amana S148DA03  Ref - Sxs
Jenn-Air S156 Range - S/c S/i Ddraft Ele
Jenn-Air S156-C Range - S/c S/i Ddraft Ele
Jenn-Air S156B Range - S/c S/i Ddraft Ele
Jenn-Air S156B-C Range - S/c S/i Ddraft Ele
Jenn-Air S156W Range - S/c S/i Ddraft Ele
Jenn-Air S156W-C Range - S/c S/i Ddraft Ele
Amana S16 Freezer - Vertical
Jenn-Air S160 Range - S/c S/i Ddraft Ele
Jenn-Air S160-C Range - S/c S/i Ddraft Ele
Jenn-Air S161 Range - S/c S/i Ddraft Ele
Jenn-Air S166 Range - S/c S/i Ddraft Ele
Jenn-Air S166-C Range - S/c S/i Ddraft Ele
Jenn-Air S166B Range - S/c S/i Ddraft Ele
Jenn-Air S166B-C Range - S/c S/i Ddraft Ele
Jenn-Air S166W Range - S/c S/i Ddraft Ele
Jenn-Air S166W-C Range - S/c S/i Ddraft Ele
Amana S16L Freezer - Vertical
Jenn-Air S176 Range - S/c S/i Ddraft Ele
Jenn-Air S176B Range - S/c S/i Ddraft Ele
Jenn-Air S176W Range - S/c S/i Ddraft Ele
Amana S19E Ref - SXS/I&W
Frigidaire S2-06B1E Kel(v0) / Room Air Conditioner
Amana S20 Freezer - Vertical
General Electric S2000D0WW Washer
General Electric S2000D2WW Washer
General Electric S2000D5WW Washer
Hoover S2001---
Hoover S2003--- Stick - Handy,broom,light Wt,compact
Hoover S2005--- Stick - Handy,broom,light Wt,compact
Hoover S2007--- Stick - Handy,broom,light Wt,compact
Hoover S2009--- Stick - Handy,broom,light Wt,compact
Hoover S2011--- Stick - Handy,broom,light Wt,compact
  #2 (permalink)
Old 11-05-2012, 05:55 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Don't understand what you mean by "the spin will just come to a complete stop and it will not stop until about a minute or two". Are you saying it stops spinning but the motor is still running or trying to run? When it spins, does it come up to full speed?
Eric
  #3 (permalink)
Old 11-05-2012, 05:55 PM
Senior Member
Default
It spins but stops before it completes the spin cycle then ithas to cool down I guess then you can get it to start spinning again
  #4 (permalink)
Old 11-05-2012, 06:46 PM
Expert
APP Volunteer
Default
Need to remove front panel to make some observations while spinning. Push putty knife into top groove of front panel on each side in line with lid opening to release the clips. Tilt front panel out and lift off. During spin, motor pulley, transmission pulley, belt and transmission should all be spinning. What's happening with these when it stops spinning?
Eric
  #5 (permalink)
Old 11-06-2012, 09:20 AM
Senior Member
Default
Everything stops belt clutch ect
  #6 (permalink)
Old 11-06-2012, 05:24 PM
Expert
APP Volunteer
Default
OK, well, there is no clutch. So, I'm getting that the motor is overheating and the motor internal overload is tripping? If you leave it alone without touching the timer, does it just come back on by itself?
With the washer uplugged, rotate the larger pulley by hand CW, looking from bottom, this should release the brake and you should be able to rotate it relatively easy. The whole transmission should turn. Have someone observe that the basket is turning. If it seems really tight, it could be clothing caught between the inner and outer tubs, the brake not releasing, seizing of the tub bearing or seizing of the lower transmission bearing.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer not completing cycle chrisgroves123 Washer Repair 1 06-03-2011 05:45 PM
Ice maker not completing cycle Baltimore Lou Refrigerator & Freezer Repair 3 06-03-2010 04:42 PM
Quiet 300 not completing cycle windowman Dishwasher Repair 9 07-01-2009 07:17 PM
whirlpool not completing cycle JOSH MANN Washer Repair 3 03-18-2008 02:00 PM
Not completing cycle eroocraw Dishwasher Repair 1 08-14-2007 01:10 PM
