Discuss
Center post bearing kit
 in
Washer Repair
Kenmore 70 series washing machine (model 11082673110) is leaking from the center of tub (drips onto clutch). I replaced the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Center post bearing kit
  #1 (permalink)
Old 11-04-2012, 10:12 AM
Junior Member
oldkenmore is on a distinguished road
Default Center post bearing kit
Model Number: 11082673110   Brand: Kenmore   Age: More than 10 years
Kenmore 70 series washing machine (model 11082673110) is leaking from the center of tub (drips onto clutch). I replaced the tub seal and basket drive block and it seemed to fix the problem for about 3-4 loads. The leak is back and the amount of leak increases with water level and size of load. At low water level and light load there appears to be no leak (operating with cover off and jumped out lid switch) Pulled the basket out again and noticed there is quite a bit of play between what I think is called the center post and the basket drive tube. Is this another potential source for a leak? You can see that the basket drive tube is pretty rusted. Or should I re-check how I installed the tub seal? Or perhaps be happy with 25 years of use and buy a new one. Thank you!
Ads By Google
Related Models
Kenmore 1108271972 BRAKE AND DRIVE TUBE
Kenmore 11083074130 WASHER
Kenmore 11083074230 WASHER
Kenmore 11083074430 WASHER
Kenmore 11083074630 WASHER
Kenmore 11083074830 WASHER
Kenmore 11083075120 SEARS ELECTRIC WASHER
Kenmore 11083075220 SEARS ELECTRIC WASHER
Kenmore 11083075420 SEARS ELECTRIC WASHER
Kenmore 11083075620 SEARS ELECTRIC WASHER
Kenmore 11083075820 SEARS ELECTRIC WASHER
Kenmore 11083150100 SEARS ELECTRIC WASHER
Kenmore 11083150110 SEARS ELECTRIC WASHER
Kenmore 11083151110 SEARS ELECTRIC WASHER
Kenmore 11083170100 SEARS ELECTRIC WASHER
Kenmore 11083170400 SEARS ELECTRIC WASHER
Kenmore 11083170600 SEARS ELECTRIC WASHER
Kenmore 11083170800 SEARS ELECTRIC WASHER
Kenmore 11083171110 SEARS ELECTRIC WASHER
Kenmore 11083171410 SEARS ELECTRIC WASHER
Kenmore 11083171610 SEARS ELECTRIC WASHER
Kenmore 11083171810 SEARS ELECTRIC WASHER
Kenmore 11083172100 SEARS ELECTRIC WASHER
Kenmore 11083172110 SEARS ELECTRIC WASHER
Kenmore 11083172130 WASHER
Kenmore 11083172200 SEARS ELECTRIC WASHER
Kenmore 11083172210 SEARS ELECTRIC WASHER
Kenmore 11083172230 WASHER
Kenmore 11083172400 SEARS ELECTRIC WASHER
Kenmore 11083172410 SEARS ELECTRIC WASHER
Kenmore 11083172430 WASHER
Kenmore 11083172600 SEARS ELECTRIC WASHER
Kenmore 11083172610 SEARS ELECTRIC WASHER
Kenmore 11083172630 WASHER
Kenmore 11083172800 SEARS ELECTRIC WASHER
Kenmore 11083172810 SEARS ELECTRIC WASHER
Kenmore 11083172830 WASHER
Kenmore 1108318272 GAS BURNER
Kenmore 1108318276 GAS BURNER
Kenmore 11083194100 SEARS ELECTRIC WASHER
Kenmore 11083194110 SEARS ELECTRIC WASHER
Kenmore 11083194120 SEARS ELECTRIC WASHER
Kenmore 11083194140 SEARS ELECTRIC WASHER
Kenmore 11083194200 SEARS ELECTRIC WASHER
Kenmore 11083194210 SEARS ELECTRIC WASHER
Kenmore 11083194220 SEARS ELECTRIC WASHER
Kenmore 11083194240 SEARS ELECTRIC WASHER
Kenmore 11083194400 SEARS ELECTRIC WASHER
Kenmore 11083194410 SEARS ELECTRIC WASHER
Kenmore 11083194420 SEARS ELECTRIC WASHER
Kenmore 11084050100 AUTOMATIC WASHER
Kenmore 11084050110 AUTOMATIC WASHER
Kenmore 11084050120 AUTOMATIC WASHER
Kenmore 11084070100 AUTOMATIC WASHER
Kenmore 11084070110 AUTOMATIC WASHER
Kenmore 11084070120 AUTOMATIC WASHER
Kenmore 11084070800 AUTOMATIC WASHER
Kenmore 11084070810 AUTOMATIC WASHER
Kenmore 11084070820 AUTOMATIC WASHER
Kenmore 11084090100 AUTOMATIC WASHER
Kenmore 11084090110 AUTOMATIC WASHER
Kenmore 11084090120 AUTOMATIC WASHER
Kenmore 11084090130 AUTOMATIC WASHER
Kenmore 11084090200 AUTOMATIC WASHER
Kenmore 11084090210 AUTOMATIC WASHER
Kenmore 11084090220 AUTOMATIC WASHER
Kenmore 11084090230 AUTOMATIC WASHER
Kenmore 11084090400 AUTOMATIC WASHER
Kenmore 11084090410 AUTOMATIC WASHER
Kenmore 11084090420 AUTOMATIC WASHER
Kenmore 11084090430 AUTOMATIC WASHER
Kenmore 11084090600 AUTOMATIC WASHER
Kenmore 11084090610 AUTOMATIC WASHER
Kenmore 11084090620 AUTOMATIC WASHER
Kenmore 11084090630 AUTOMATIC WASHER
Kenmore 11084090800 AUTOMATIC WASHER
Kenmore 11084090810 AUTOMATIC WASHER
Kenmore 11084090820 AUTOMATIC WASHER
Kenmore 11084090830 AUTOMATIC WASHER
Kenmore 11084350100 ELECTRIC WASHER
Kenmore 11084370100 ELECTRIC WASHER
Kenmore 11084370110 ELECTRIC WASHER
Kenmore 11084370800 ELECTRIC WASHER
Kenmore 11084370810 ELECTRIC WASHER
Kenmore 11084390100 ELECTRIC WASHER
Kenmore 11084390110 ELECTRIC WASHER
Kenmore 11084390200 ELECTRIC WASHER
Kenmore 11084390210 ELECTRIC WASHER
Kenmore 11084390300 ELECTRIC WASHER
Kenmore 11084390310 ELECTRIC WASHER
Kenmore 11084390400 ELECTRIC WASHER
Kenmore 11084390410 ELECTRIC WASHER
Kenmore 11084390600 ELECTRIC WASHER
Kenmore 11084390610 ELECTRIC WASHER
Kenmore 11085155100 SEARS ELECTRIC WASHER
Kenmore 11085156100 SEARS ELECTRIC WASHER
Kenmore 11085165100 SEARS ELECTRIC WASHER
Kenmore 11085165400 SEARS ELECTRIC WASHER
Kenmore 11085165600 SEARS ELECTRIC WASHER
Kenmore 11085165800 SEARS ELECTRIC WASHER
Kenmore 11085166100 ELECTRIC WASHER
Kenmore 11085175100 SEARS ELECTRIC WASHER
Kenmore 11085175200 SEARS ELECTRIC WASHER
Kenmore 11085175400 SEARS ELECTRIC WASHER
Kenmore 11085175600 SEARS ELECTRIC WASHER
Kenmore 11085175800 SEARS ELECTRIC WASHER
Kenmore 11085185100 SEARS ELECTRIC WASHER
Kenmore 11085185400 SEARS ELECTRIC WASHER
Kenmore 11085185600 SEARS ELECTRIC WASHER
Kenmore 11085185800 SEARS ELECTRIC WASHER
Kenmore 11085257100 ELECTRIC WASHER
Kenmore 11085365100 WASHER
Kenmore 11085365200 WASHER
Kenmore 11085365400 WASHER
Kenmore 11085365600 WASHER
Kenmore 11085365800 WASHER
Kenmore 11086070200 ELECTRIC DRYER
Kenmore 11086070210 ELECTRIC DRYER
Kenmore 11086070400 ELECTRIC DRYER
Kenmore 11086070410 ELECTRIC DRYER
  #2 (permalink)
Old 11-05-2012, 02:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
There are two seals inside the basket drive and most likely this where the water is coming through. Unfortunately they are not sold separately and you have to replace the whole basket drive. APP sold it for $119.34 and I'm not sure if your washer is worth it.
- The basket drive assembly Part number: 285792
Part number: 285792
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-06-2012, 06:47 AM
Junior Member
Default
Thanks for the reply Gene! I believe you may be right that it probably isnt' worth it. But thanks again for taking the time to reply.
take care
  #4 (permalink)
Old 11-06-2012, 10:43 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Finely I found the part number for the seal and bearing kit to fix this problem. It cost much less than the new basket drive.
- The seal and bearing kit Part number: 285203
Part number: 285203
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Center Post getting hot Hershal Refrigerator & Freezer Repair 0 07-15-2011 07:37 PM
oil in center post?? wedrons Washer Repair 4 05-02-2011 03:47 AM
Please need advice on changing Center Post Gasket Phylow2 Washer Repair 0 02-23-2011 03:34 PM
Center post gasket leaking kvbehl Dishwasher Repair 0 10-02-2010 10:26 AM
How to replace spin bearing? How center post comes out? painternumero1 Washer Repair 1 10-26-2009 06:13 PM
