Discuss
Maytag Bearing Repair
 in
Washer Repair
serial #11219755QY I replaced the tub bearing and now water is leaking out of the 6 channels / grooves in
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Bearing Repair
  #1 (permalink)
Old 10-29-2012, 03:39 PM
Junior Member
Timred is on a distinguished road
Default Maytag Bearing Repair
Model Number: LAT9306AAM   Brand: Maytag   Age: 5 - 10 years
serial #11219755QY I replaced the tub bearing and now water is leaking out of the 6 channels / grooves in the rubber part underneith the tub. I am not sure how tight to make the nut on top of the "seal kit"? (the accordian shaped round rubber thing with the spring inside). I have tried different tensions - the first time I tightened it as much as possible. I don't see any damage.
Ads By Google
Related Models
Maytag LAT9306AAM WASHER-TOP LOADING
Maytag LAT9306ABE WASHER-TOP LOADING
Admiral LAT9306AGE WASHER-TOP LOADING
Admiral LAT9306AKM WASHER-TOP LOADING
Admiral LAT9306AKQ WASHER-TOP LOADING
Admiral LAT9306BGE WASHER-TOP LOADING
Admiral LAT9306DAM WASHER-TOP LOADING
Admiral LAT9306DAQ WASHER-TOP LOADING
Admiral LAT9306EGE WASHER-TOP LOADING
Admiral LAT9306GGE WASHER-TOP LOADING
Maytag LAT9314AAE WASHER-TOP LOADING
Maytag LAT9314AAL WASHER-TOP LOADING
Maytag LAT9314AAM WASHER-TOP LOADING
Maytag LAT9314ABE WASHER-TOP LOADING
Maytag LAT9316AAE WASHER-TOP LOADING
Maytag LAT9316AAM WASHER-TOP LOADING
Maytag LAT9316ABE WASHER-TOP LOADING
Maytag LAT9316ABM WASHER-TOP LOADING
Maytag LAT9334AAE WASHER-TOP LOADING
Maytag LAT9334AAL WASHER-TOP LOADING
Maytag LAT9334AAM WASHER-TOP LOADING
Maytag LAT9334ABE WASHER-TOP LOADING
Maytag LAT9356AAE WASHER-TOP LOADING
Maytag LAT9356AAM WASHER-TOP LOADING
Maytag LAT9356AAQ WASHER-TOP LOADING
Maytag LAT9356ABE WASHER-TOP LOADING
Maytag LAT9356ABM WASHER-TOP LOADING
Maytag LAT9357AAE WASHER-TOP LOADING
Maytag LAT9357AAM WASHER-TOP LOADING
Maytag LAT9357AAQ WASHER-TOP LOADING
Maytag LAT9360AAE WASHER-TOP LOADING
Maytag LAT9390AAE WASHER-TOP LOADING
Maytag LAT9400AAE WASHER-TOP LOADING
Maytag LAT9400AAL WASHER-TOP LOADING
Maytag LAT9400AAW WASHER-TOP LOADING
Maytag LAT9400ABE WASHER-TOP LOADING
Maytag LAT9400ABL WASHER-TOP LOADING
Maytag LAT9400ABW WASHER-TOP LOADING
Maytag LAT9400AGL WASHER-TOP LOADING
Maytag LAT9400AGW WASHER-TOP LOADING
Maytag LAT9400DAL WASHER-TOP LOADING
Maytag LAT9400DAW WASHER-TOP LOADING
Maytag LAT9406AAE WASHER-TOP LOADING
Maytag LAT9406AAM WASHER-TOP LOADING
Maytag LAT9406ABE WASHER-TOP LOADING
Maytag LAT9416AAE WASHER-TOP LOADING
Maytag LAT9416AAM WASHER-TOP LOADING
Maytag LAT9416AAQ WASHER-TOP LOADING
Maytag LAT9420AAE WASHER-TOP LOADING
Maytag LAT9457AAE WASHER-TOP LOADING
Maytag LAT9457AAM WASHER-TOP LOADING
Maytag LAT9457AAQ WASHER-TOP LOADING
Maytag LAT9457BAE WASHER-TOP LOADING
Maytag LAT9520AAE WASHER-TOP LOADING
Maytag LAT9520AAQ WASHER-TOP LOADING
Maytag LAT9557AAE WASHER-TOP LOADING
Maytag LAT9557AAQ WASHER-TOP LOADING
Maytag LAT9593AAL WASHER-TOP LOADING
Maytag LAT9593AAW WASHER-TOP LOADING
Maytag LAT9593ABL WASHER-TOP LOADING
Maytag LAT9593ABW WASHER-TOP LOADING
Maytag LAT9600AAL WASHER-TOP LOADING
Maytag LAT9600AAW WASHER-TOP LOADING
Maytag LAT9600ABL WASHER-TOP LOADING
Maytag LAT9600ABW WASHER-TOP LOADING
Maytag LAT9604AAE WASHER-TOP LOADING
Maytag LAT9604AAL WASHER-TOP LOADING
Maytag LAT9604AAM WASHER-TOP LOADING
Maytag LAT9604ABE WASHER-TOP LOADING
Maytag LAT9605AAE WASHER-TOP LOADING
Maytag LAT9605AAM WASHER-TOP LOADING
Maytag LAT9606AAE WASHER-TOP LOADING
Maytag LAT9606AAM WASHER-TOP LOADING
Maytag LAT9606ABE WASHER-TOP LOADING
Maytag LAT9606ABM WASHER-TOP LOADING
Admiral LAT9606AGE WASHER-TOP LOADING
Admiral LAT9606BGE WASHER-TOP LOADING
Admiral LAT9606GGE WASHER-TOP LOADING
Maytag LAT9614AAE WASHER-TOP LOADING
Maytag LAT9614AAL WASHER-TOP LOADING
Maytag LAT9614AAM WASHER-TOP LOADING
Maytag LAT9615AAE WASHER-TOP LOADING
Maytag LAT9615AAM WASHER-TOP LOADING
Maytag LAT9616AAE WASHER-TOP LOADING
Maytag LAT9616AAM WASHER-TOP LOADING
Maytag LAT9634AAE WASHER-TOP LOADING
Maytag LAT9634AAL WASHER-TOP LOADING
Maytag LAT9634AAM WASHER-TOP LOADING
Maytag LAT9634ABE WASHER-TOP LOADING
Maytag LAT9635AAE WASHER-TOP LOADING
Maytag LAT9635AAM WASHER-TOP LOADING
Maytag LAT9700AAL WASHER-TOP LOADING
Maytag LAT9700AAW WASHER-TOP LOADING
Maytag LAT9700ABL WASHER-TOP LOADING
Maytag LAT9700ABW WASHER-TOP LOADING
Maytag LAT9700DAL WASHER-TOP LOADING
Maytag LAT9700DAW WASHER-TOP LOADING
Maytag LAT9704AAE WASHER-TOP LOADING
Maytag LAT9704AAL WASHER-TOP LOADING
Maytag LAT9704AAM WASHER-TOP LOADING
Maytag LAT9704ABE WASHER-TOP LOADING
Maytag LAT9704ABL WASHER-TOP LOADING
Maytag LAT9704ABM WASHER-TOP LOADING
Admiral LAT9704AGE WASHER-TOP LOADING
Admiral LAT9704BGE WASHER-TOP LOADING
Maytag LAT9704DAL WASHER-TOP LOADING
Maytag LAT9704DAM WASHER-TOP LOADING
Admiral LAT9704GGE WASHER-TOP LOADING
Maytag LAT9706AAE WASHER-TOP LOADING
Maytag LAT9706AAM WASHER-TOP LOADING
Maytag LAT9706AAQ WASHER-TOP LOADING
Maytag LAT9706ABE WASHER-TOP LOADING
Maytag LAT9714AAE WASHER-TOP LOADING
Maytag LAT9714AAL WASHER-TOP LOADING
Maytag LAT9714AAM WASHER-TOP LOADING
Maytag LAT9734AAE WASHER-TOP LOADING
Maytag LAT9734AAL WASHER-TOP LOADING
Maytag LAT9734AAM WASHER-TOP LOADING
Maytag LAT9734ABE WASHER-TOP LOADING
Maytag LAT9757AAE WASHER-TOP LOADING
  #2 (permalink)
Old 10-30-2012, 12:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Have you replaced just the tub bearing 6-2040130?
It must be replaced together with the seal kit 6-2095720. If you did not do it, that's why most likely it's leaking.
- The seal kit Part number: 6-2095720
BTW, in order to unscrew and/or tight the spanner nut you will need a special spanner wrench Part number: TJ90TB123A
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Neptune Bearing Repair - Pic Tutorial crystal368 Washer Repair 25 07-01-2012 09:28 AM
motor bearing repair pilato1 Dryer Repair 0 11-04-2010 06:36 PM
Amana seal and bearing repair rustyballs_69 Washer Repair 10 02-27-2009 06:29 AM
Won't spin high speed after bearing repair lotsoflaundry Washer Repair 11 12-14-2008 07:35 PM
Duet Bearing Repair mt813 Washer Repair 2 03-12-2008 06:25 PM
