Discuss
Replace clutch too?
 in
Washer Repair
Washer makes unusual noises and sometimes doesn't drain. Moved it and saw oil stain. Suspected Gearcase. Removed Gearcase and can
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Replace clutch too?
  #1 (permalink)
Old 10-29-2012, 10:16 AM
Junior Member
stuffduff is on a distinguished road
Question Replace clutch too?
Model Number: Whirlpool LSV633AW0   Brand: Whirlpool   Age: More than 10 years
Washer makes unusual noises and sometimes doesn't drain. Moved it and saw oil stain. Suspected Gearcase. Removed Gearcase and can see leak. This machine is 19 years old, Whirlpool LSV633AW0. I'm thinking I should replace clutch also. Which Gearcase & Clutch do I need?
Ads By Google
Related Models
Whirlpool WHP1000SB1 Pedestal
Whirlpool WHP1000SK0 Pedestal
Whirlpool WHP1000SK1 Pedestal
Whirlpool WHP1000SL0 Pedestal
Whirlpool WHP1000SL1 Pedestal
Whirlpool WHP1000SQ0 Pedestal
Whirlpool WHP1000SQ1 Pedestal
Whirlpool WHP1000ST0 Pedestal
Whirlpool WHP1000ST1 Pedestal
Whirlpool WHP1000SU1 Pedestal
Whirlpool WHP1500SA0 Pedestal
Whirlpool WHP1500SA1 Pedestal
Maytag WHP1500SA1 Pedestal
Whirlpool WHP1500SB0 Pedestal
Whirlpool WHP1500SB1 Pedestal
Maytag WHP1500SB1 Pedestal
Whirlpool WHP1500SC0 Pedestal
Whirlpool WHP1500SC1 Pedestal
Maytag WHP1500SC1 Pedestal
Whirlpool WHP1500SL0 Pedestal
Whirlpool WHP1500SL1 Pedestal
Maytag WHP1500SL1 Pedestal
Whirlpool WHP1500SQ0 Pedestal
Whirlpool WHP1500SQ1 Pedestal
Maytag WHP1500SQ1 Pedestal
Whirlpool WHP1500ST0 Pedestal
Whirlpool WHP1500ST1 Pedestal
Maytag WHP1500ST1 Pedestal
Whirlpool WHP1500SU0 Pedestal
Whirlpool WHP1500SU1 Pedestal
Maytag WHP1500SU1 Pedestal
Whirlpool WHP32812 30" Electric Range Self Clean Oven
Whirlpool WHP54802 30" Electric Range Self Clean Oven
Whirlpool WHP54803 30" Electric Range Self Clean Oven
Whirlpool WHP83812 30" Electric Range Ceran Cooktop Self Clean
General Electric WHRE5260E0CC Washer
General Electric WHRE5260E0WW Washer
General Electric WHRE5260E1CC Washer
General Electric WHRE5260E1WW Washer
General Electric WHRE5260E6CC Washer
General Electric WHRE5260E6WW Washer
General Electric WHSB8000B0CC Washer
General Electric WHSB8000B0WW Washer
General Electric WHSB8000B1CC Washer
General Electric WHSB8000B1WW Washer
General Electric WHSB9000B0CC Washer
General Electric WHSB9000B0WC Washer
General Electric WHSB9000B0WW Washer
General Electric WHSE3100A0WB Washer
General Electric WHSE3100A2WB Washer
General Electric WHSE5240D0CC Washer
General Electric WHSE5240D0WW Washer
General Electric WHSE5240D1CC Washer
General Electric WHSE5240D1WW Washer
General Electric WHSE5240DCCC Washer
General Electric WHSE5240DCWW Washer
General Electric WHSR2070V2WB Washer
General Electric WHSR2070V3WB Washer
General Electric WICB103CV1WC Washer
Frigidaire WIDH3 Frg(v18) / Top Loading Washer
Frigidaire WIDH4 Frg(v3) / Top Load Washer
Frigidaire WIDL3 Frg(v19) / Top Loading Washer
Frigidaire WIDL4 Frg(v2) / Top Load Washer
Frigidaire WIDW3 Frg(v20) / Top Loading Washer
Frigidaire WIDW4 Frg(v1) / Top Load Washer
Frigidaire WILH1 Frg(v2) / 27 " Washer
Frigidaire WILL0 Frg(v2) / 27 " Washer
Frigidaire WILL1 Frg(v3) / 27 " Washer
Frigidaire WILW0 Frg(v1) / 27 " Washer
Frigidaire WILW1 Frg(v1) / 27 " Washer
Frigidaire WIMA1 Frg(v16) / Washer
Frigidaire WIMA2 Frg(v17) / Washer
Frigidaire WIMA3 Frg(v15) / Washer
Frigidaire WIMF1 Frg(v18) / Washer
Frigidaire WIMF2 Frg(v19) / Washer
Frigidaire WIMF3 Frg(v16) / Washer
Frigidaire WIMH1 Frg(v20) / Washer
Frigidaire WIMH2 Frg(v21) / Washer
Frigidaire WIMH3 Frg(v17) / Washer
Frigidaire WIML1 Frg(v22) / Washer
Frigidaire WIML2 Frg(v23) / Washer
Frigidaire WIML3 Frg(v18) / Washer
Frigidaire WIMW1 Frg(v24) / Washer
Frigidaire WIMW2 Frg(v25) / Washer
Frigidaire WIMW3 Frg(v19) / Washer
Frigidaire WISCL2 Frg(v3) / Washer
Frigidaire WISCL3 Frg(v3) / Washer
Frigidaire WISCL5 Frg(v3) / Top Loading Washer
Frigidaire WISCL6 Frg(v4) / Top Load Washer
Frigidaire WISCLH1 Frg(v5) / 27 " Washer
Frigidaire WISCLL0 Frg(v4) / 27 " Washer
Frigidaire WISCLL1 Frg(v6) / 27 " Washer
Frigidaire WISCLL2 Frg(v2) / 27 " Washer
Frigidaire WISCLW0 Frg(v3) / 27 " Washer
Frigidaire WISCLW1 Frg(v4) / 27 " Washer
Frigidaire WISCLW2 Frg(v1) / 27 " Washer
Frigidaire WISCW2 Frg(v4) / Washer
Frigidaire WISCW3 Frg(v4) / Washer
Frigidaire WISCW5 Frg(v4) / Top Loading Washer
Frigidaire WISCW6 Frg(v3) / Top Load Washer
Frigidaire WISDH3 Frg(v6) / Top Load Washer
Frigidaire WISDL2 Frg(v21) / Top Loading Washer
Frigidaire WISDL3 Frg(v5) / Top Load Washer
Frigidaire WISDLH1 Frg(v8) / 27 " Washer
Frigidaire WISDLL0 Frg(v6) / 27 " Washer
Frigidaire WISDLL1 Frg(v9) / 27 " Washer
Frigidaire WISDLW0 Frg(v5) / 27 " Washer
Frigidaire WISDLW1 Frg(v7) / 27 " Washer
Frigidaire WISDW2 Frg(v22) / Top Loading Washer
Frigidaire WISDW3 Frg(v4) / Top Load Washer
General Electric WISQ416AT5WW Washer
General Electric WISQ416AT6WW Washer
General Electric WISQ416AT7WW Washer
General Electric WISQ416AT8WW Washer
General Electric WISQ416ATAWW Washer
General Electric WISQ416BT5WW Washer
General Electric WISQ416BT6WW Washer
General Electric WISQ416BT7WW Washer
General Electric WISQ416BT8WW Washer
General Electric WISQ416BTAWW Washer
  #2 (permalink)
Old 10-29-2012, 01:43 PM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
If the motor will not run at some places in the dial setting, you probably have a timer that is going bad. You could pull the cover off to check for burnt contacts.
This cost and a new transmission will be over $300 plus shipping. Probably not worth fixing considering it's age.
__________________
  #3 (permalink)
Old 10-30-2012, 05:19 AM
Junior Member
Default It's the noise
The last time i tried to run it was empty with the least water it could use and it started making noises that it had never been making. A gnashing of gears kind of sound. My desk is in the next room and I know what every cycle sounds like.
  #4 (permalink)
Old 10-30-2012, 05:27 AM
Junior Member
Default
richappy You OK in PA?
  #5 (permalink)
Old 10-30-2012, 05:57 AM
Senior Expert
APP Volunteer
Default
Ok here, thanks for the concern, just a short power interuption. Can keep the house warm with the woodburner. Pity the people in West Virginia, plenty of downed trees loaded with wet snow.
If your tranny is dumping oil out the top, you have internal parts failing. If the only failure, may be worth it to fix.
__________________
  #6 (permalink)
Old 10-31-2012, 03:19 PM
Junior Member
Default
Gearbox and clutch are in. But something is still wrong. Fills, washes and agitates, but no rinse or spin. It tries to spin, then stops and tries again. I hear clicking, like something in the clutch or brake shoe are off. Any ideas?
  #7 (permalink)
Old 11-01-2012, 01:18 AM
Senior Expert
APP Volunteer
Default
Pull pump and motor and turn the tranny coupler clockwise. If hard to turn when tranny enters spin, you either have a missing thrust washer on top of the tranny, jammed/bad brake shoes, or something jammed.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replace Clutch gate1 Washer Repair 1 01-29-2012 03:41 AM
Replace Dog Or Agitator Clutch halljb57 Washer Repair 3 09-06-2011 05:00 AM
How to replace retainer ring on clutch Brainiac Washer Repair 2 03-13-2011 12:57 PM
Maytag LAT9304gge clutch slip what part do i have to replace smithx Washer Repair 7 05-28-2010 12:27 PM
Replace clutch on top loading washer knobby Washer Repair 1 12-04-2009 03:33 PM
