| » Frigidaire Washer stuck on wash cycle |
Model Number: FWT647GHSO Brand: Frigidaire Age: 5 - 10 years
My Frigidaire washing machine seems to be stuck on the wash cycle. The timer will advance as usual but no matter what setting it is on, all it will do is agitate. It wont drain the water or rinse the clothes, even if you move the dial manually. The tech papers that were taped to the inside of the machine only show wiring diagrams. Any suggestions?
Thank you, Allie Ads By Google Related Models |
Hi Allie,
What does it do when it comes to drain/spin? Here are the breakdown diagrams and Parts for Frigidaire FWT647GHS0 Washer - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
__________________
__________________
Time for plan B. I just installed the new timer, but no luck. The washer still wont drain the soapy water or spin. If I manually move the dial to the spin setting, the washer continues to agitate - no draining or spinning. Any more suggestions?
Perform the troubleshooting as described in the attached file and post the results.
__________________
My frigidaire washer is stuck on the wash cycle. The timer will run through its normal course but the washer will not drain or spin. No matter what setting it is on (wash, rinse, or spin) it will continue to agitate the soapy water. I have replaced the timer and that did not fix the problem so what should I try next?
Quote:
__________________
| Display Modes | |
| Washer Stuck in Wash Cycle | misti5768 | Washer Repair | 1 | 09-29-2011 06:39 PM |
| Whirlpool Washer Stuck in Wash Cycle | dansmith60 | Washer Repair | 1 | 10-25-2009 06:36 AM |
| washer stuck in wash cycle | sandracilia1@hotmail.com | Washer Repair | 0 | 02-10-2009 01:38 PM |
| washer stuck in wash cycle | sandracilia1@hotmail.com | Washer Repair | 0 | 02-10-2009 01:33 PM |
| Can not select wash cycle - stuck on scrub wash | luke | Dishwasher Repair | 0 | 08-20-2007 08:38 AM |
