| » Washer will not agitate, spin out in rinse cycle or drain |
Quote:
Where would I find this?? I looked all over the thing for a tag and all I have found is 2 seperate numbers on the back. First says Part No 3952302 White Second says 3952303 Almond That is on the back of the top panel. Down below that (I wrote this all down) it says Stolle then a B Further down on the back of the washer it has 3356472. I'm not a pro at this forgive me. |
Quote:
Although at least now I know who made it, its a whirlpool. This might help, an example would be 110.26844694 ![]() Last edited by glen65 : 09-25-2009 at 08:37 AM. |
Quote:
Golly, I'm thinking hard. Its been a while since it went out. had to spin it by hand I do know that...but it went on to the spin cycle on its own so it must have been doing something right. For a while it worked like this, then it stopped spinning entirely. Wouldn't drain the water either. A SEARS repairman told me he thought it sounded like a coupler, I think is what he said...Said it's a plastic piece that sometimes will break. But my hubby has never checked into it, so I'm just running on memory. If you think that might be it, then I might try to get in there and see for myself. I just can't figure out how to get in there where it is at.
The coupler could be bad but that would not keep the washer from
draining. You are going to have to run this unit through a cycle and take note as to what it does and doesn't do before I can go much further. |
Quote:
I will see if I can plug it back in and see what it does...We put it outside to put this OTHER one in here that has wound up doing the same thing. This is just the newer one I was hoping we could fix. I'll have to work on getting this thing hooked up somehow. If my husband doesn't help me, I may be at the end of this road cause I have no idea how to do it outside with hooking up water and such. Will be in touch. |
If you want to check it outside you could get a "Y" connector
(most hardware stores have them) ![]() Then hook both inlet hoses on your washer to it an then hook the other end to a garden hose. Just make sure the drain hose doesn't lay on the ground or the water will siphon out of the washer. Then just use a heavy extension cord for power. |
| Display Modes | |
| washer will not transition from agitate to drain & rinse | Mark S. Rubino | Washer Repair | 9 | 05-17-2011 10:18 AM |
| Rinse cycle , no hyper spin just slow + no drain | buffnern | Washer Repair | 1 | 01-15-2010 03:06 PM |
| Washer won't agitate during rinse cycle | bd2con | Washer Repair | 4 | 09-11-2009 07:18 PM |
| Washer goes to rinse cycle then spin back to rinse, stuck in this mod | Pat66 | Washer Repair | 1 | 05-08-2009 07:44 AM |
| Washer won't agitate or spin after rinse cycle | tickytutt | Washer Repair | 1 | 03-11-2008 10:31 AM |
