| » Tub spins while agitating |
Quote:
Thanks for the reply. The model number of the washer is LAT9706AAE |
Ok good
I think it is more likely the brakes. Warning, that brake spring is under 200 lbs of pressure and you need a special brake tool to remove and brake. Unfortunately I can no longer link you to a service manual, but you might find one you can download for very little money if you do a basic search.
__________________
I should be able to buy the whole brake assembly correct? It would be item #5 in this diagram 03-Clutch, Brake & Belts (9706) parts for Maytag LAT9706AAE - AppliancePartsPros.com
I think so, but I am a volunteer and not associated with the parts operations here. I would call them just to confirm things. And don't forget the special took and you really need a service manual.
__________________
| Display Modes | |
| tub spins while agitating | nenasfan | Washer Repair | 1 | 09-22-2011 08:57 AM |
| Washer basket spins while agitating | antoinegae | Washer Repair | 1 | 05-08-2010 03:55 AM |
| Maytag Washer spins instead of agitating | blur | Washer Repair | 2 | 03-04-2008 02:36 PM |
| Basket Spins While Agitating | RUGGY | Washer Repair | 1 | 01-18-2008 02:15 AM |
| Tub Spins While Agitating | icoetmartyp | Washer Repair | 0 | 12-07-2007 10:42 PM |
