Discuss
Kenmore Washer Noise
 in
Washer Repair
My washer has recently started making a loud squeaking noise. It only makes the noise while agitating and while draining.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Washer Noise
  #1 (permalink)
Old 10-27-2012, 10:07 AM
Junior Member
fox408 is on a distinguished road
Default Kenmore Washer Noise
Model Number: 110226232100   Brand: Kenmore   Age: 5 - 10 years
It only makes the noise while agitating and while draining. Nothing while filling or or spinning.
I have no idea what it is, and so far haven't found anything on the web about it.
Things that may be important to know about it..
I did replace the pump a few months ago with a fairly inexpensive one off ********.
Also lately I've had to give it a push to get it spinning on the spin cycle (bad clutch, right?)
Thanks a lot for your time,
the washer is my moms and I'm trying to get it up and going for her
Ads By Google
Related Models
Kenmore 11022632100 WASHER
Kenmore 11022642100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022652100 COMPACT WASHER
Kenmore 11022662100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692101 AUTOMATIC WASHER
Kenmore 11023012100 AUTOMATIC WASHER
Kenmore 11023012101 AUTOMATIC WASHER
Kenmore 11023012102 AUTOMATIC WASHER
Kenmore 11023014100 AUTOMATIC WASHER
Kenmore 11023014101 AUTOMATIC WASHER
Kenmore 11023014102 AUTOMATIC WASHER
Kenmore 11023022100 AUTOMATIC WASHER
Kenmore 11023022101 AUTOMATIC WASHER
Kenmore 11023022102 AUTOMATIC WASHER
Kenmore 11023024100 AUTOMATIC WASHER
Kenmore 11023024101 AUTOMATIC WASHER
Kenmore 11023024102 AUTOMATIC WASHER
Kenmore 11023032100 WASHER
Kenmore 11023032101 AUTOMATIC WASHER
Kenmore 11023032102 AUTOMATIC WASHER
Kenmore 11023034100 WASHER
Kenmore 11023034101 AUTOMATIC WASHER
Kenmore 11023034102 AUTOMATIC WASHER
Kenmore 11023036100 WASHER
Kenmore 11023036101 AUTOMATIC WASHER
Kenmore 11023036102 AUTOMATIC WASHER
Kenmore 11023652200 AUTOMATIC WASHER
Kenmore 11023662200 AUTOMATIC WASHER
Kenmore 11023692200 AUTOMATIC WASHER
Kenmore 11023712200 AUTOMATIC WASHER
Kenmore 11023722200 AUTOMATIC WASHER
Kenmore 11023732200 AUTOMATIC WASHER
Kenmore 11023812100 AUTOMATIC WASHER
Kenmore 11023822100 AUTOMATIC WASHER
Kenmore 11023832100 AUTOMATIC WASHER
Kenmore 11023902200 AUTOMATIC WASHER
Kenmore 11023902201 AUTOMATIC WASHER
Kenmore 11023904200 AUTOMATIC WASHER
Kenmore 11023904201 AUTOMATIC WASHER
Kenmore 11023912100 AUTOMATIC WASHER
Kenmore 11023912101 AUTOMATIC WASHER
Kenmore 11023912102 AUTOMATIC WASHER
Kenmore 11023922200 AUTOMATIC WASHER
Kenmore 11023922201 AUTOMATIC WASHER
Kenmore 11023924200 AUTOMATIC WASHER
Kenmore 11023924201 AUTOMATIC WASHER
Kenmore 11023932200 WASHER
Kenmore 11023934200 WASHER
Kenmore 11024082200 AUTOMATIC WASHER
Kenmore 11024084200 AUTOMATIC WASHER
Kenmore 11024086200 AUTOMATIC WASHER
Kenmore 11024422300 AUTOMATIC WASHER
Kenmore 11024432300 AUTOMATIC WASHER
Kenmore 11024442300 AUTOMATIC WASHER
Kenmore 11024622300 AUTOMATIC WASHER
Kenmore 11024632300 AUTOMATIC WASHER
Kenmore 11024642300 AUTOMATIC WASHER
Kenmore 11024652300 AUTOMATIC WASHER
Kenmore 11024692300 AUTOMATIC WASHER
Kenmore 11024812200 AUTOMATIC WASHER
Kenmore 11024812201 AUTOMATIC WASHER
Kenmore 11024822200 AUTOMATIC WASHER
Kenmore 11024822201 AUTOMATIC WASHER
Kenmore 11024832200 AUTOMATIC WASHER
Kenmore 11024832201 AUTOMATIC WASHER
Kenmore 11024892300 AUTOMATIC
Kenmore 11024894300 AUTOMATIC
Kenmore 11024902200 AUTOMATIC WASHER
Kenmore 11024902201 AUTOMATIC WASHER
Kenmore 11024904200 AUTOMATIC WASHER
Kenmore 11024904201 AUTOMATIC WASHER
Kenmore 11024922200 AUTOMATIC WASHER
Kenmore 11024922201 AUTOMATIC WASHER
Kenmore 11024924200 AUTOMATIC WASHER
Kenmore 11024924201 AUTOMATIC WASHER
Kenmore 11024932200 AUTOMATIC WASHER
Kenmore 11024932201 AUTOMATIC WASHER
Kenmore 11024934200 AUTOMATIC WASHER
Kenmore 11024934201 AUTOMATIC WASHER
Kenmore 11024942300 AUTOMATIC WASHER
Kenmore 11024944300 AUTOMATIC WASHER
Kenmore 11024946300 AUTOMATIC WASHER
Kenmore 11024952300 AUTOMATIC WASHER
Kenmore 11024954300 AUTOMATIC WASHER
Kenmore 11024956300 AUTOMATIC WASHER
Kenmore 11024962300 AUTOMATIC WASHER
Kenmore 11024964300 AUTOMATIC WASHER
Kenmore 11024966300 AUTOMATIC WASHER
Kenmore 11024972300 AUTOMATIC WASHER
Kenmore 11024974300 AUTOMATIC WASHER
Kenmore 11024982300 AUTOMATIC WASHER
Kenmore 11024992300 AUTOMATIC WASHER
Kenmore 11024994300 AUTOMATIC WASHER
Kenmore 11024996300 AUTOMATIC WASHER
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
Kenmore 11026292693 AUTOMATIC WASHER
Kenmore 11026292694 WASHER
Kenmore 11026292695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026294690 AUTOMATIC WASHER
Kenmore 11026294691 AUTOMATIC WASHER
Kenmore 11026294692 AUTOMATIC WASHER
Kenmore 11026294693 AUTOMATIC WASHER
Kenmore 11026294694 WASHER
Kenmore 11026294695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026702694 AUTOMATIC WASHER
Kenmore 11026722690 WASHER
Kenmore 11026801690 AUTOMATIC WASHER
Kenmore 11026812690 WASHER
Kenmore 11026814690 WASHER
Kenmore 11026822690 WASHER
Kenmore 11026824690 WASHER
Kenmore 11026824692 AUTOMATIC WASHER
Kenmore 11026832690 AUTOMATIC WASHER
Kenmore 11026832694 AUTOMATIC WASHER
Kenmore 11026834690 WASHER
Kenmore 11026834694 AUTOMATIC WASHER
Kenmore 11026842690 WASHER
  #2 (permalink)
Old 10-28-2012, 01:21 AM
gabe_1981's Avatar
Senior Expert
APP Volunteer
gabe_1981 is on a distinguished road
Default
You may try removing the pump from the motor and while leaving the hoses attached move the pump back and running it to see if the noise goes away ... If so I would blame the pump for the noise
__________________
Case Appliance Repair College Station,Texas-
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer,loud banging noise ceking60 Washer Repair 2 11-22-2011 10:38 AM
kenmore washer making a humming noise delmanjo Washer Repair 1 10-08-2010 02:19 AM
Kenmore washer noise trctrc Washer Repair 0 08-22-2010 07:13 AM
Kenmore Washer=Terrible Noise OkieChic Washer Repair 6 11-10-2009 11:21 AM
Kenmore Elite Washer making noise julie1971us Washer Repair 1 09-03-2008 04:05 AM
