No spinning or Draining-- PLEASE HELP!
Brand: Roper Age: 1 - 5 years
My husband put a comforter in the washing machine before we left the house. When we got home, the washer was stopped in the middle of the rinse cycle and was full of water. When trying to remove the comforter from the washer, he noticed it part of the comforter was stuck under the agitator.
After removing the comforter completely, we tried to put it on spin. It wouldn't. So, I put it back on the rinse cycle and it started agitating. When I came back to check it again, it was stuck in the middle of the rinse cycle again.
I did some research and decided to check the drain pump. Upon doing so, I found puddles of water under and beside the washer. I drained the water from the tub and found the drain pump and hoses to be in good condition. I then decided to remove the agitator to be sure nothing was stuck underneath. It was clear. However, when I went to remove it, it was not spinning by hand in either direction.
I plan on checking the clutch and the motor coupler tomorrow. However, I wanted to get some feedback first. Since I didn't find anything wrong, I haven't tried to run it again, for fear of being stuck again with a washer full of water. Furthermore, I'm not sure if the blanket was just extremely dirty or not, but the water was FILTHY!
Any feedback would be GREATLY appreciated!
Thanks so much!
Tera
Ads By Google
