Discuss
washer wont spin unless u open and close lid
 in
Washer Repair
kenmore 70 series washer goes though all cycles fine but when ir goes into rinse cycle it wont spin it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer wont spin unless u open and close lid
  #1 (permalink)
Old 10-25-2012, 08:25 PM
Junior Member
mttconway is on a distinguished road
Default washer wont spin unless u open and close lid
Model Number: 110.20712 990   Brand: Kenmore   Age: More than 10 years
kenmore 70 series washer goes though all cycles fine but when ir goes into rinse cycle it wont spin it drains water out but if u open and close lid it will spin ive replaced lid switch still same thing ive bye past lid switch
and when it goes into rinse cycle it starts to spin and stops right away and wont spin till u open lid again dont think its the timmer cause it goes though all the cycles it just wont spin during rinse or spin cycle it
agitates fine need help cant seem to find anyone that can answer this post!!!!
Ads By Google
Related Models
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
  #2 (permalink)
Old 10-26-2012, 09:49 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Based on the information you provided the timer need to be replaced.After washer drains out the water the timer pausing fora few seconds allowing the transmission to engage in the spin mode.
By opening and closing the lid you are pausing.
The timer Part number: 661636
Part number: 661636
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 11-07-2012, 01:12 PM
Junior Member
Thumbs down well thxs 4 wrong info
so i go out and spend $138 total for timer
now i still have same problem plus now out $138
  #4 (permalink)
Old 11-07-2012, 05:20 PM
Junior Member
Exclamation washer wont spin till u lift lid
ok replaced the timer ( $138 timer ! )
replaced lid switch ($24)
replaced clucth assembly ($51)
still have same problem every thing works great till it gets to rinse or spin cycle it drains ok it trys to start to spin then stops like the breaks stopped it
but if u open lid and close it it then starts to spin !!!
help please not much more i can replace if i new i was going to be $200++
into it i would have just bought new!!
  #5 (permalink)
Old 11-08-2012, 08:42 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Operate the machine with the cabinet removed and lid switch bypassed. The washer should fill, go into agitate, at end of agitate mode, motor pauses, starts up again in reverse direction. At this point, it should be draining and the clutch hub should not be rotating. Observe the clutch hub near end of agitation mode to be sure it doesn't start rotating when drain mode starts. After drain, motor should pause again for a few seconds. When it starts back up again the clutch hub should be rotating.
If the motor doesn't pause after agitation mode and drain mode, it's a timer issue.
If the clutch hub is spinning and the basket is not, it's a mechanical issue (clutch, brake, tub drive block, clothes between inner/outer tub,...etc.)
If after drain/pause/restart for spin, the clutch hub is not spinning, it's a gearcase issue.
Eric
  #6 (permalink)
Old 11-08-2012, 11:43 AM
Junior Member
Talking thx for your time and help eric got it working now!!
works great thx for your help
Eric
  #7 (permalink)
Old 11-08-2012, 12:29 PM
Expert
APP Volunteer
Default
What did you do to get it fixed???
  #8 (permalink)
Old 11-08-2012, 01:59 PM
Junior Member
Thumbs up
yes thx very much
  #9 (permalink)
Old 11-09-2012, 10:33 AM
Expert
Default
HI.
Do you mind to share with us what did you do to fix the problem?
Simon.
__________________
  #10 (permalink)
Old 11-09-2012, 11:14 AM
Junior Member
Default replace clutch
replacing clutch seed to fix my problem after it drains now it starts to spin
so the clutch was my problem thx 4 the help
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tub won't spin unless you open & close the lid jhonster Washer Repair 18 12-05-2012 10:06 AM
Whirlpool washer will agitate and drain, but won't spin unless open/close lid bnavarre Washer Repair 11 12-04-2012 05:57 PM
washer wont spin unless i open then close lid idrinkalone Washer Repair 3 08-22-2011 01:57 AM
ice door won't open or close wkames Refrigerator & Freezer Repair 1 09-01-2010 02:36 PM
Maytag Washing won't spin & drain unless open & close lid hull98 Washer Repair 1 09-19-2009 04:15 PM
