Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Kenmore washer not spinning or agitating, just "humming" (http://forum.appliancepartspros.com/washer-repair/504382-kenmore-washer-not-spinning-agitating-just-humming.html)
dschar 10-25-2012 09:26 AM
I have a Kenmore washer (#11020712991) that fills up but does not spin or agitate. The motor just hums like it wants to work but something's jamming it. I checked the motor coupler and that is fine. I also checked the pump to make sure that wasn't holding the motor up... it was fine too. What am I missing and need to check? Thank you for your help!
Simon / APP Team 10-25-2012 10:35 AM
Hi.
First check the wire harness and connections from the motor and start capacitor to the timer and selector switch.
Check the capacitor (you'll need a multimeter). The info is on the capacitor.
Part number: 8572720
Post the results.
Simon.
